| Any F14 Builders Plans? #85553 09/27/06 04:21 AM 09/27/06 04:21 AM |
Joined: Sep 2006 Posts: 9 Buffalo, NY, /Northern, CA nic579 OP
Posts: 9 Buffalo, NY, /Northern, CA | Any one know about Plans/Designs that can be purchased for F14 Stitch-N-Glue or composite over foam and stringers might be ok on a small boat like this too. Preferably a modern design. I was just looking as i want to build something small light and fun to race + solo for regular recreation. i am like 5'5" 150 lbs\ and want something i can handle on my own.
Thanks for any help.
Also anyone have an opinion on the quattro 14? Sail one raced against one its ability to race competitively? as this is the only plan I have found so far.
| | | Re: Any F14 Builders Plans?
[Re: nic579]
#85556 09/27/06 09:47 PM 09/27/06 09:47 PM |
Joined: Feb 2004 Posts: 1,012 South Australia Darryl_Barrett
Posts: 1,012 South Australia | Apart from the older “established” 14’ cats (most, if not all of which were designed for ply and dating back several decades), all of the, so called, “performance” hull designs for 14’ cats (and most other sized ones as well) have, through necessity for their performance, “compound curves” in their hull shape that make their manufacture out of ply virtually impossible. There is just so far you can “torture” ply before it fractures. This means that if you were to “home build” a set of 14’ hulls, the only options that you have are to go with the less efficient, older style ones. I suppose it all boils down to just what you want from the cat that you sail on? If it is just to get out there and sail/race, then it doesn’t really matter what you sail if you race only on handicap or in a one design class, but if you are looking for the “latest, fastest” performing F14 (or F16) in the world, first start with a set of hulls that you know have the potential. I am sure that most if not all manufactures of “high performance” 14’ and 16’ cats will sell you just the hulls and then the rest of the build would be up to you | | | Re: Any F14 Builders Plans?
[Re: Seeker]
#85559 09/28/06 12:42 PM 09/28/06 12:42 PM |
Posts: 105 | http://www.mckeewildthings.com/video/itza.movThe link above is exactly what you're talking about. 25 years old, a bit ghetto, but the idea is sound. A planing hull out of 4mm ply, with modern tech, and real hulls (albeit very low freeboard) might make a boat lighter than an A-class that could be built for a couple of grand and that would be an easier build than the tortured ply narrow hulls. Four feet shorter boat, a shorter/cheaper mast (maybe even pocket luff), all seem interesting. When I get a chance, I'm linking this on Bateau.com - maybe the designer there would be willing to put out a set of plans. Long shot, but... Anyway, if you download the freeware for Hullform (design program) I'll send you the design for what I have in mind. | | | Re: Any F14 Builders Plans?
[Re: michael C]
#85560 09/28/06 04:41 PM 09/28/06 04:41 PM |
Joined: Apr 2002 Posts: 695 Ft. Pierce, Fl. USA Seeker
Posts: 695 Ft. Pierce, Fl. USA | Interesting...so it has already been done in a primitive way...I was thinking if you could make the hulls pivot at the beam attachment points so that the leeward hull could stay flat on the water as the windward hull left the water. It would make it a lot faster...seems from the video that he is cooking along nicely until the leeward hull goes from flat to angled, which is no surprise since the fastest way to sail a sailboard is keeping the hull flat as possible. Now if you could some how steer the craft with modified sailboard fin and get rid of the rudder and centerboard it would be even better/faster. It is a huge rush to be going 30-40 mph on a sailboard standing up…if you could approach those speeds sitting down, with the water so close….it would be unreal.
Michael why use plywood?...Why not make it out of Styrofoam/Divinicell/epoxy just like windsurfers? You won’t be limited by the bending ability of the materials and it will be super light. A 9’ slalom board is sub 15 lbs. As long as you are not going to have too much hull volume it would be a viable alternative.
Might have to form another forum heading for cats 12’ and under…LOL
Regards, Bob
[Re: Seeker]
#85561 09/29/06 08:09 AM 09/29/06 08:09 AM |
Posts: 105 | Michael why use plywood?...Why not make it out of Styrofoam/Divinicell/epoxy just like windsurfers?
$ <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" /> All joking aside, the reason for ply was that my designs I've been playing around with have been somewhat more traditional (in the loosest sense). Really good 4mm ply taped with carbon is the best material I can afford on that scale. At 13 pounds for a 4x8 section, it's not too much heavier than the alternatives. If it works, then I'll look at the pricey stuff, and just swap the rig. I was thinking of heavily canted boards to convert heel to lift, should solve the excessive hull-flying and let it plane easier (semi-foil). Somewhat more traditional hulls would also be less affected by slight heel. I'd even considered using the longest windsurfing fins I could find for rudders. Of course, you could just shape two 12' paddleboard blanks, cover with epoxy and carbon, fabricate 2" x 8' carbon crossbars, raid a 12 meter windsurfing sail, add a layer of carbon to the mast, use skegs for rudders and daggers, and be in the water really quick - don't think I haven't considered it <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" /> | | | Re: Any F14 Builders Plans?
[Re: michael C]
#85562 10/03/06 06:04 PM 10/03/06 06:04 PM |
Posts: 461 Sydney Australia | Michael why use plywood?...Why not make it out of Styrofoam/Divinicell/epoxy just like windsurfers?
$ <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" /> All joking aside, the reason for ply was that my designs I've been playing around with have been somewhat more traditional (in the loosest sense). Really good 4mm ply taped with carbon is the best material I can afford on that scale. At 13 pounds for a 4x8 section, it's not too much heavier than the alternatives. If it works, then I'll look at the pricey stuff, and just swap the rig. I was thinking of heavily canted boards to convert heel to lift, should solve the excessive hull-flying and let it plane easier (semi-foil). Somewhat more traditional hulls would also be less affected by slight heel. I'd even considered using the longest windsurfing fins I could find for rudders. Of course, you could just shape two 12' paddleboard blanks, cover with epoxy and carbon, fabricate 2" x 8' carbon crossbars, raid a 12 meter windsurfing sail, add a layer of carbon to the mast, use skegs for rudders and daggers, and be in the water really quick - don't think I haven't considered it <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" /> I've already done it. I have the machine laying in my yard behind the shed. It consists of two glassed paddle boards for hulls with a 'Hobie like tramp/frame, the legs of which have pivots at the base to allow them to maintain a flat attitude. It has a big sailboard rig with fixed wire side stays, a wire forestay with bridle but with a big bungy to allow fore and aft rig angle adjustment by a std mainsheet off the wishbone, for steering like a windsurfer. Didn't work because the side thrust on the fins cranks the hulls/boards, over on their side. I was going to try wings from which the legs would reach the hull sides to offset the tendancy but it all got too hard and I abandoned the project. | | | Re: Any F14 Builders Plans?
[Re: Seeker]
#85566 01/14/07 09:37 PM 01/14/07 09:37 PM |
Posts: 1,012 South Australia | Hi Bob, the approximate dimensions of the Alpha Omega F14 hull are 8” wide at its widest point on the deck, 9.5” wide at it’s widest point on the bottom of the hull, and 17.5” deep at it’s deepest point. The term “rocker” is used by most people to describe any and all directional “shape” change along the horizontal line of a hull, but that can be a little misleading as not all directional changes act, in the true sense, as “rocker”. The aft rocker on the Alpha, as you call it, is in reality designed to release energy at, or near, the same percentage rate that has been put into the water by the entry of the hull. When the bow “parts” the water it displaces a certain amount of water starting at zero at the bow, and gradually increasing that displacement all the way to the hulls maximum width/displacement point. The displacement is then relatively constant until there is a release of that “energy/displacement” towards the rear of the hull. An ideal scenario is to release that energy at the same rate and in the same way that it was put into the water thereby creating a very “clean” transition through the water. Unless the hull is double ended it is impossible to release that stored energy in the same way as it was put into the water. I.E. the bows are fine and deep and the transom is not. Therefore that energy release is primarily obtained by the underwater transitional shape of the aft section of the hull to the transom. That is as simply as I can put it without going into some very complex mathematics. What most people refer to, as “rocker” is simply the curve put along a hull bottom to allow it to tack easier than it would if it was a straight line from the stem to the stern of the hull bottom. Strangely enough a lot of boats are designed with little regard as to where the rocker is placed for maximum efficiency but instead are only concerned with the actual amount of rocker for a given hull length and displacement. | | | Re: Any F14 Builders Plans?
[Re: Darryl_Barrett]
#85569 01/15/07 09:57 PM 01/15/07 09:57 PM |
Posts: 695 Ft. Pierce, Fl. USA | Darryl can't claim those are used in my everyday life… but my father law is a senior design engineer working on the next generation Space Craft to replace the Shuttle program. My wife works at United Space Alliance in the ground support design engineering group out at Kennedy Space Center. So I would hope I could find someone to help me understand any area that I might be lacking…LOL…
I do have a working knowledge of Block Coefficients, Prismatic Coefficients, Water plane Coefficient (coefficient of fineness) and curve of areas. How much farther does your method take it beyond the curve of areas? If I am following you correctly you are taking about minimizing eddy making resistance at the transom.
I have often heard that the wise surround themselves with great minds….I try to work in that direction… thank you for all your help Darryl…
Best Regards, Bob
1,109
guests, and 40
