| Looking for builders plans for F16 F14. #85644 09/27/06 02:50 PM 09/27/06 02:50 PM |
Joined: Sep 2006 Posts: 9 Buffalo, NY, /Northern, CA nic579 OP
Posts: 9 Buffalo, NY, /Northern, CA | Any one know about Plans/Designs that can be purchased for F14 Stitch-N-Glue or composite over foam and stringers might be ok on a small boat like this too. Preferably a modern design. I was just looking as i want to build something small light and fun to race + solo for regular recreation. i am like 5'5" 150 lbs\ and want something i can handle on my own.
Thanks for any help.
Also anyone have an opinion on the quattro 14? Sail one raced against one its ability to race competitively? as this is the only plan I have found so far.
| | | Re: Looking for builders plans for f14.
[Re: nic579]
#85651 09/28/06 03:55 AM 09/28/06 03:55 AM |
Posts: 1,449 | Nick, If your thinking of building an article appeared in Catsailor Mag a while back that walks you through the process. It may be worth reading. Also it may pay to checkout the slide show on Thebeachcats.com web site. Blade F16 Building Slideshow It shows a lot of the processes. Alternatively if you would prefer a 14 ft cat you wouldn't go wrong asking Darryl if he would sell you a set AOF14 hulls and building up an F14. You would be surprised at how much work and fun there is involved in getting a boat just the way you want it even after you have the hulls. Regards, Phill
[Re: nic579]
#85653 09/28/06 06:35 AM 09/28/06 06:35 AM |
Ask phill for details, if the 16's are too big for you then ask Phill about arrows, mosquito's and other smaller Australian homebuild cat designs.
WOuter
| | | Re: Looking for builders plans for f14 or f16
[Re: nic579]
#85654 09/28/06 06:46 AM 09/28/06 06:46 AM |
Posts: 1,449 | Nic, I try to stay out of the photos. But I have been caught in a couple. Any F16 can be sailed one up or two up safely. The added luxury of being able to use a carbon mast if you can source one at the right price can make it even easier but not really required.
The alumiumium mast used is quite light compared to typical aluminium mast sections you would find on other 16 ft cats.
I can take my boat off the trailer,rig, sail, unrig and put it back on the trailer by myself. I did sail with my children when they had more time but these days with them working weekends I mostly sail by myself. Mind you all of this also applies to a 14 ft boat.
Regards, Phill
[Re: phill]
#85657 09/28/06 03:05 PM 09/28/06 03:05 PM | Anonymous
| Anonymous
Unregistered | Phill,
can you give us as idea of what its would cost to build a ply Blade? Whose mast extrusions are you using? | | | Re: Looking for builders plans for f14 or f16
[Re: ]
#85658 09/28/06 06:48 PM 09/28/06 06:48 PM |
Posts: 1,449 | Scarecrow, As your an F18 sailor I'm not sure what you are asking as there is both an F16 and F18 design. I've not decided if I will sell F18 plans. I'll make that decision once the F18 is in full production. So I'll just talk in general terms for people who can source F16 and F18 plans from others.
You would build an F16 platform for around $2000 or less and an F18 platform for $3000. This depends a lot on how you source materials and how careful you are.
Instead of a mould and foam the F18 uses the ply as a self shaping core when it is tortured. A glass laminate is aplied to both sides. This yields a hull twice as heavy as the F16. While this produces an incredibley strong an stiff platform the added materials bump up the building cost compared to the F16.
The very nature of the F16 and F18 class means the fitout on both vary so much you really need to decide on your personal prefernces and then price them.
Building is only for those who want to build. If you want to save money get a part time job and buy your platform. Given the time it takes to build this would be the better financial option.
In my opinion the AHPC superwing is currently the best available aluminium section on the market. They offerred its use to the F16 class so the Blade F16 uses the Superwing.
Alternatively anyone sailing one up can do what Gary Maskiell did on Altered and source a carbon A class section. Install a centre web which will bring it up to the min tip weight of the F16 class and have a bullet proof carbon mast for one up spinaker sailing.
I hope this gives a bit of a general idea.
Regards, Phill
[Re: phill]
#85659 09/29/06 08:51 AM 09/29/06 08:51 AM |
Posts: 778 Houston | I agree with Phil, you will not save any money by building your own boat.
I built a 14. I had all of the expensive parts (Carbon mast, sails, lines, blocks) already and most of the construction materials (Fiberglass, Carbon, kevlar, etc). I spent $1500-$2000 on just little stuff. I estimate I would have spent ~$6000-7000 if I had to purchase everything at full price.
Keep in mind there will be a big difference in final cost between a 14, 16, and a 18. Look at the factory prices. Unless you have some parts laying around, you will not spend much less.
In terms of time, I would estimate the platform represents less than 1/2 the total time. If you include integration and getting things to work, building and finishing the platform is about 1/3 of the total time.
I sail a 14 and a A-Class. I like the 14 because I never feel that I am overpowered by it. Even in 25+ kt winds I never felt overpowered. I was in danger of being beaten to death by the ocean but I had control of the boat. Compared to the 14, the A-Class is a luxary rocket ship. There is no comparison in performance and I can do everything without help. I do start feeling out of control at 15-18 kts and it takes a lot more effort to sail than the 14.
If I didnt want to build and wanted a boat I could sail by myself I would consider an older A-Class with a high wind/reduced area sail. | | | Re: Looking for builders plans for f14.
[Re: phill]
#85663 10/03/06 06:25 PM 10/03/06 06:25 PM |
Posts: 461 Sydney Australia | Nick, If your thinking of building an article appeared in Catsailor Mag a while back that walks you through the process. It may be worth reading. Also it may pay to checkout the slide show on Thebeachcats.com web site. Blade F16 Building Slideshow It shows a lot of the processes. Alternatively if you would prefer a 14 ft cat you wouldn't go wrong asking Darryl if he would sell you a set AOF14 hulls and building up an F14. You would be surprised at how much work and fun there is involved in getting a boat just the way you want it even after you have the hulls. Regards, Phill OR: Berny for a pair of 430 hulls!!!!! http://www.imagestation.com/album/?id=4287241557 | | |
1,216
guests, and 35
