Lewmar VF Racing Blocks? #85712
09/28/06 01:30 PM
09/28/06 01:30 PM
CT Shoreline
Wet1 Offline OP
Wet1  Offline OP
CT Shoreline
I was looking at my original 1985 blocks on my H16 the other day thinking they should be updated over the winter... which was reinforced by a friend (thanks Jeff).
I did some searching and found a Lewmar VF Racing 60mm Vf Triple Ratchet Block with becket & cam and matching 60mm VF Racing triple for under $270 for the pair. I'm assuming these blocks are similar to the 57mm Harken Carbo blocks? I like the idea of going with the larger 60mm 6:1 blocks as I'd like to use a 10mm or even 7/16" main sheet.
Does anyone know anything about the Lewmar VF Racing blocks or see any reason why this system wouldn't work well on a H16?
Re: Lewmar VF Racing Blocks? [Re: Wet1] #85713
09/28/06 06:36 PM
09/28/06 06:36 PM
New Hampshire, USA
windswept Offline
windswept  Offline
New Hampshire, USA
I replaced my Harken with Lewmar a few years ago and love them on my Tornado. Lighter, with no issues so far.
Tom Siders
A-Cat USA-79
Tornado US775
Re: Lewmar VF Racing Blocks? [Re: windswept] #85714
09/29/06 12:18 PM
09/29/06 12:18 PM
Hollister CA, Plano TX
avalondarlyn Offline
I use lewmar r60's and 90's. they are very nice. for x-tra line dia. you can inter change the side plate's and then use a large size cam cleat. i use 5/8 reggata braid on my main. very easy on the hands. after 3 failures of ronstan blocks i have had no problems with the lewmar. very smooth
Re: Lewmar VF Racing Blocks? [Re: windswept] #85715
09/30/06 10:48 PM
09/30/06 10:48 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
Are you using 10 to 1 on the T? So which blks from Lewmar are you using? Mainsheet tapered? Thanks!
Dave
Re: Lewmar VF Racing Blocks? [Re: Wet1] #85716
10/01/06 11:47 AM
10/01/06 11:47 AM
Yardley PA
DanWard Offline
DanWard  Offline
Yardley PA
I have used the Lewmar blocks and they are very nice but the Harken ratchomatic blocks are better IMHO. They pay out much faster because the ratchet automatically switches off when the line is released.
Re: Lewmar VF Racing Blocks? [Re: Wet1] #85717
10/03/06 08:06 AM
10/03/06 08:06 AM
Houston
carlbohannon Offline
Houston
I have used Lewmar and the only problem I had was parts. I could get parts but it always took a week or 2
I now use Harken ratchomatic carbo which is by far the best thing I have ever seen. It's almost as big of an improvement over the old harken's as harken's were over Seaway in the 80's.
0 registered members (), 297 guests, and 42 spiders.
