| Re: prindle 16
[Re: prindle16man]
#85825 10/02/06 08:38 PM 10/02/06 08:38 PM |
Posts: 168 San Diego | sounds good for free. If you plan on trailering I think I would trade the utility trailer for an actual catamaran trailer. Used hobie 16 trailers should work and are everywhere, often for very cheap. Or since it looks like you have the crossbars already if they can be detached then just put them on any small boat trailer frame in the right spots.
| | | Re: prindle 16
[Re: hokie]
#85826 10/02/06 09:49 PM 10/02/06 09:49 PM |
Posts: 12,310 South Carolina | look closely - the utility trailer is carrying the cat trailer. Smart...given the fact that the condition of the cat trailer is suspect at the moment.
The Prindle is a very nice boat. They did have a problem with the forward decks getting pretty soft. There are a lot of people here with a good deal of experience with them and they will probably chime in.
Jake Kohl | | | Re: prindle 16
[Re: prindle16man]
#85831 10/04/06 03:02 PM 10/04/06 03:02 PM |
Posts: 321 Albuquerque NM | Maybe some of the blocks and sheets (not to be confused with sails), but probably not the expensive stuff like masts, rudders or tramp probably not sails either.
[b] Sail Like you have a Pair
| | | Re: prindle 16
[Re: Banzilla]
#85832 10/04/06 06:48 PM 10/04/06 06:48 PM |
Posts: 122 | Speaking of ebay, this seller has new Prindle Escape mains for very cheap. http://tinyurl.com/m7etnThe Escape was essentially a P18 with a P16 mast and new sails. The Escape main is going to be a tad bigger than the stock P16 main and you'd still need a jib, but it just might be an interesting project. And the price is certainly right! jimbo | | | Re: prindle 16
[Re: Jimbo]
#85833 10/04/06 07:11 PM 10/04/06 07:11 PM | Anonymous
| Anonymous
Unregistered | Speaking of ebay, this seller has new Prindle Escape mains for very cheap. http://tinyurl.com/m7etnThe Escape was essentially a P18 with a P16 mast and new sails. The Escape main is going to be a tad bigger than the stock P16 main and you'd still need a jib, but it just might be an interesting project. And the price is certainly right! jimbo I believe that sail is for the Escape playcat designed by Morrelli and Melvin, not the prindle. | | |
3,695
guests, and 114
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online4,027 1 hour ago | | |
