| Wild guess ...
[Re: phill]
#86416 10/09/06 03:12 PM 10/09/06 03:12 PM |
Just a wild guess.
The water is coming into the mast through the T-terminals slots just below the hound fitting. Very early on it was recognized that these slots could never be made fully watertight and that a better (cheaper and quicker) alternative was to just pop rivet SS endplates to the mast (these CAN be made watertight). Of course some people just knew better.
From experience I know for certain that when the boat capsizes that the diamond wire end fittings WILL go below the watersurface. Not for all time but definately long enough to let water in. Most likely situation in this is when you are still hooked on after the capsize or when standing on the boom to free your leg of something. The boat will not turtle because of this but it will put the diamond wire end fittings under.
My mainbeam was made from a old Taipan mast section and the amound of sealant around a T-terminal opening suggested that this issue was already discovered on the Taipans well before the F16's were build in larger numbers. At least I knew this when I builded up my mast several years ago, so others must have known as well.
| | | Re: Water in Mast
[Re: bobcat]
#86417 10/09/06 04:05 PM 10/09/06 04:05 PM |
Joined: May 2002 Posts: 1,037 Central California ejpoulsen
Posts: 1,037 Central California | Bobcat,
I've faced this same issue after long capsizes. I use an awl or flat head screwdriver to poke a hole between the mast wall and the plug and push the plug back as the water drains out (lay the mast so the base is up higher). Then I just put a dab of silicone sealant in the hole I made and that's it.
430
guests, and 54
