| Re: How fast is my F18?
[Re: John Williams]
#86575 10/13/06 05:20 PM 10/13/06 05:20 PM |
Posts: 12,310 South Carolina | I usually put a GPS in a drybag and tape that to the boom on the Nacra 20 when we're distance racing. I've found that it receives very well as long as the boat is upright! The max speeds and such are very reliable. If you use the larger garmin units, you can even see the displays from the outboard positions of the boat.
Herendeen bought two Garmin Geckos (very simple GSP units) and used electrical tape to attach them to each shroud. You can still program in waypoints and for less than the cost of one fancy unit, he's got two neatly placed and accessible.
Jake Kohl | | | Re: How fast is my F18?
[Re: John Williams]
#86576 10/13/06 07:09 PM 10/13/06 07:09 PM |
Posts: 1,403 | Garmin makes a good, reliable rugged product, and the Vista with the compass is quite useable for cat racing. And the customer service they offer is World Class. I have returned a few items to them that were replaced and/or repaired with no problems. Also as an FYI, you can get updates on the unit software etc... from their website. | | | Re: How fast is my F18?
[Re: jimi]
#86580 10/14/06 03:14 PM 10/14/06 03:14 PM |
Posts: 1,383 Kingston SE South Australia | I dont have time to let a sinker over the bow and time the knots in the line over <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />. Can you give me your better way of accurately measuring boat speed Jimmi? <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> I will have an F18 and it would be nice to see accurate data from top crew races to help understand the strengths and weaknesses of the different brands of F18 regards
[Re: JeffS]
#86581 10/15/06 08:58 AM 10/15/06 08:58 AM |
Posts: 87 Trondheim, Norway | Well, my dad and I use a hand held gps receiver and compared it to the speedometer in our car while driving. And as expected the speedometer showed a few knots faster than the gps, however the difference was not 73 knots and other crazy numbers as mentioned here on the forum. We therefore conclude the gps to be quite accurate (I know some will want to shoot me after writing this, but living in Oslo, Norway with an entire ocean to cross for most of the forum users, I'll take my chances:)). Up hill we have done 13,7 knots in our Taipan 5.7 in around 12 knots of wind with zero waves. Down hill we have done around 20 knots, wind strength 15 to 18 knots. We did not fly the chute, so I reckon it is possible for a more experienced crew to go quite a bit faster while flying the kite. Opinions? Regards Jimi | | | Re: How fast is my F18?
[Re: jimi]
#86582 10/15/06 10:03 AM 10/15/06 10:03 AM |
Posts: 2,921 Michigan | Guys, this thread was originally about how fast the F18 actually is, not how reliable gps-receivers are. So let's have it, how fast is the F18!?:) Uphill, around 14 knots? Downhill around 25 knots? What do you think? I figure 14-15 up and 20 or so down in good wind. Probably faster if you have the guts to go all out downwind in high wind stuff. This is what i do in my 6.0 and I can't sail it worth a crap so I figure an f18 sailed average should go that fast! maybe I am wrong, but I haven't sailed in too long. this despite being on an island 1 mile from water in perfect weather. | | | Re: How fast is my F18?
[Re: jimi]
#86583 10/15/06 10:17 AM 10/15/06 10:17 AM |
Posts: 6,049 Sebring, Florida. | A GPS unit will be pretty accurate as long as it can see the satelites and you don't jerk it around too much. Unfortunately, when you are on a catamaran going upwards of 20 knots, you will be jerking it around and it will not have a good look at the satelites all the time.
I once threw my handheld from one side of my cat to the other (on the beach while rigging, to my crew) and it registerd 53 mph. I just tossed it easy, underhand, so I know it wasn't going over maybe 10, but because it tumbled I think it decided it must have gone 53? The point is, in your car going down a smooth road in a straight line, sure it works great. But on a picthing cat on a rolling sea, not so accurate.
Here is what you can do: Have your crew hold the GPS unit somehow that the antenae will have a good look at the sky for a few minutes while you sail upwind, bear off and set the kite, now have him get out on the wire with the kite sheet in one hand and the GPS in the other (better tie it to him) and now you heat it up and get it going as fast as you can for as long as you can, and have your crew read off the speeds as you go. You might see 20 knots on an F18, just before you swim. (insert picture of the Hobie Tiger pitchpole during the speed run in the French Ditch). I have found a handheld GPS will only give you accurate numbers in a steady state. Once you start tacking and gybing if the boat is bouncing all over the place in waves, the "max speed" number is no good. At the end of the day you can use the distance and time it records and do your own math but that also includes all the slow sailing while tacking.
Blade F16 #777
[Re: Rolf_Nilsen]
#86587 10/15/06 01:11 PM 10/15/06 01:11 PM |
Posts: 87 Trondheim, Norway | Hei Rolf, satt og ventet på når du skulle slenge deg inn i diskusjonen!:) 14-16 knop er utrolig bra på kryss da! For ikke å snakke om 25 nedover! Får frysninger av å tenke på det!:) Far og jeg har et stykke igjen til sånne hastigheter, det står i alle fall ikke på båten. Som nevnt over er alle "topphastighetene" våre satt i nokså små briser, vi må bare bygge opp rutine og ferdighet (og baller) til å dra utpå når det blåser spiker. Dessverre er vi bare ca 150 kg på ripa, og med styrketrening kun to til tre ganger i uka over stusselig studentkost, ser det ikke akkurat ut til at jeg kommer til å rase opp i vekt den nærmeste tiden:) Taipanen var jo designet til å ta tunge mannskap på 150 kg+ så riggen er kraftfull og har oss begge i trapes innnen 3-5 m/s. Ettersom vi nå endelig har fått ordnet ordentlig snuffer til båten, er vi nå også mer tent på å kjøre mer gennaker. Vi hadde en super tur sist helg, da jeg tok en langhelg fri fra studiene for å få seilt litt og pakket ned båten. Logget over 16 knop i 4-5 m/s med gennaker, vanvittig gøy å fly ett skrog nedover vinden! Skikkelig booster for motivasjon til studiene med sånne turer! Hold oss oppdatert på hastighetsmålinger da. Geir Magnus | | | Re: How fast is my F18?
[Re: jimi]
#86588 10/15/06 01:42 PM 10/15/06 01:42 PM |
Posts: 4,451 West coast of Norway | Geir Magnus, 150kg er da gode greier det. Skulle ønske vi også hadde det, så kanskje vi virkelig kunne få opp farten. Jeg mener det er en større fordel å kunne kjøre depower enn å lesse på med vekt <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> Å seile i mye vind er bare en vanesak, man må komme seg utpå og tøye grensene litt så blir man fort vant til det. Vi seiler med GPS kun i distanseseilaser for tiden, og da som et navigasjonsinstrument. Vi brukte den tidligere til å finne de beste vinklene for VMG, og det var i den perioden vi logget de hastighetene jeg refererte til. Vi er ikke så opphengte i hva slags fart vi gjør, så lenge vi kommer i mål før de andre tornadoene <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" /> Dette har blysvingerne her store problemer med å forstå, de tror vi seiler båten kun for fartens skyld, mens det er samspillet og å få båten "in the groove" vi setter mest pris på. I think we should keep to english on the forum, out of courtesy to all our friends here. They are probably very curious about what we are discussing in our quite "off the mainstream" language. Hope to get to sail with you next season (or this season, boat will not be put in storage for 14 days, so if you want to visit us in Molde..). | | | Re: How fast is my F18?
[Re: Rolf_Nilsen]
#86589 10/15/06 02:12 PM 10/15/06 02:12 PM |
Posts: 87 Trondheim, Norway | Actually my class visited Molde two weeks ago, but only for half a day as we were on a trip with "hurtigruta" to do an assignement in "marine tech.", one of my courses at NTNU. However, we mostly drank beer and chill out instead of working on the project while in Molde. As you said, my dad and I need to get more comfortable in strong winds. Problem is, there really is not stable, good breezes in the inner Oslo fjord, so when the wind picks up, it usually is extremely gusty. But more experience and balls will give us confidence to go out in the big stuff as well. I think we are getting closer, so next year... I totally understand what you meant about getting the boat "in the groove". It truly is a wonderful feeling looking up at the rig, all tell-tails are flying, and the windward hull just kissing the water. However, I don't think there's anything wrong in wanting to go fast in a straight line as well! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Regards Jimi | | | Re: How fast is my F18?
[Re: Stein]
#86592 10/15/06 10:14 PM 10/15/06 10:14 PM |
Posts: 6,049 Sebring, Florida. | I think the single biggest obstacle to going faster than about 20 knots on a beach cat is the sea state. In order to get going that fast on a typical beach cat, you need at least 15-20 knots of wind, which will kick up some waves wich will keep you from going much faster. That is why the French built the ditch for speed runs, to keep the waves to a minimum.
Blade F16 #777
| | | Speed Limit
[Re: Timbo]
#86593 10/15/06 11:53 PM 10/15/06 11:53 PM |
Posts: 851 US Western Continental Shelf | In the ocean where there are already "seas" and you find wind waves to add to the seas, a 20' beachcat has a lot of trouble getting past any SUSTAINED speeds of 18 knots.
I have had bursts to 22 knots. I have had short moments of sustaining 18-19 knots. (no spinnaker in either case)
I am always happy if I can maintain an average upwind plus downwind speed of 10+ knots. As a cruiser, I am pretty pleased if my speed is above 8 knots in any direction.
My Mystere 6.0 (Whisk) will probably never go faster than 24 knots unless she is riding on a body of water that is not being affected by the wind, the same wind that is pulling her along at such high speeds. (ditch run?)
Whisk won't go faster than 24 knots in the six years that I've sailed her on the ocean. Gross weight = (minimum) 615 pounds to (approx. maximum) 1175 pounds.
GARY
Santa Monica Bay Mystere 6.0 "Whisk" <--- R.I.P. | | |
20,780
guests, and 1,475
