| Re: Which is best?
[Re: Tony_F18]
#86759 10/16/06 06:11 PM 10/16/06 06:11 PM |
Joined: Nov 2005 Posts: 337 Victoria, Australia C2 Mike
Posts: 337 Victoria, Australia | If given the choice, Would you go for a 1 year old boat with its original sails? Or a 3 year old boat with new sails? (Boat of same make/model). Depends on how many miles the 3yo boat has done. My experience with tigers - 3yo boat driven by a pussy and well maintained will be fine. Same age boat (even well maintained) but pushed hard week in week out will be no where near as stiff as a new one. As always it's not allways a clear answer. Cheers, Tiger Mike | | | Re: Which is best?
[Re: C2 Mike]
#86762 10/17/06 04:22 AM 10/17/06 04:22 AM |
Posts: 2,584 +31NL | Depends on how many miles the 3yo boat has done. My experience with tigers - 3yo boat driven by a pussy and well maintained will be fine. Same age boat (even well maintained) but pushed hard week in week out will be no where near as stiff as a new one. As always it's not allways a clear answer.
Cheers, Tiger Mike
Thx for the response, So a three year old cat from a recreational sailor should be of about the same quality as a one year old racer? | | | Re: Which is best?
[Re: Tony_F18]
#86763 10/17/06 04:40 AM 10/17/06 04:40 AM |
Posts: 4,451 West coast of Norway | Apart from how the boat has been handled (beaching, cleaning, storage, cleaning all bearings for sand and salt, tightening beam bolts, capsizes, collisions, damages/repairs etc), the key is stiffness. Two factors determine this for identical boats, what is the max load the boat has seen and how many cycles of loading has it gone trough. You will probably not be able to find anything meaningful about what max loads the boats have seen, but you might do some research on the number of load cycles they have gone trough. A one year old boat from an active racer might well have seen more use than a three year old boat used for weekend sailing. You can also look at their measured weight and do a simple test of platform stiffness. Set one boat up on a level surface, and lift one bow. Measure how high you must lift the bow before the other bow follows. Set the other boat up identically, and measure the same value. You will hopefully not be able to measure a difference. The racing boat might be set up better, equipped better and "tricked out" while the recreational boat might be a stock one from the factory.
Question is what you want to do with the boat and your budget? If you are on a low budget, new sails are a major factor. | | | Re: Which is best?
[Re: Rolf_Nilsen]
#86764 10/17/06 06:29 AM 10/17/06 06:29 AM |
Posts: 6,049 Sebring, Florida. | As Rolf points out, how "new" is the new boat and how New are the new sails? Never been used, latest, greatest, racing sails or run of the mill low milage sails? Are they Dacron or Pentex? Did he race them or not? I would take a close look at both boats because a one year old racing boat might have more new goodies on it, also the lines, mast, beams, rigging, etc. are all only one year old. So take a look at both and see which one suits your needs and budget.
The three year old boat might need new lines, rigging, upgrades, etc. if you want to race and could end up costing as much as if you just bought the new boat AND then a new set of sails for racing. Where was it stored for those 3 years and was it covered or not? Remember to look inside the hulls and up from the bottom at the daggerboard wells for cracks in the hulls.
It has been my observation that many recreational sailors think nothing of driving their boats up onto the beach at speed, sometimes they forget to pull the boards up too... Whereas a racing sailor will usually treat his boat much better, at least on shore.
Blade F16 #777
| | | Re: Which is best?
[Re: Tony_F18]
#86766 10/17/06 11:46 AM 10/17/06 11:46 AM |
Joined: May 2002 Posts: 1,037 Central California ejpoulsen
Posts: 1,037 Central California | As with people, it's not the year; it's the miles that count.
| | | Re: Which is best?
[Re: ejpoulsen]
#86767 10/17/06 12:07 PM 10/17/06 12:07 PM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | As with people, it's not the year; it's the miles that count. Scary! If that's the case, I am a lot older than my years. <img src="http://www.catsailor.com/forums/images/graemlins/ooo.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> | | | Re: Which is best?
[Re: Mary]
#86768 10/17/06 01:13 PM 10/17/06 01:13 PM |
Posts: 602 Wilmington,NC | I think it all depends on how the boat is kept, used and setup. I would not want a boat that was a year old and was not used very much but was kept on the beach near salt water and never cared for( sails never washed off, boat never washed off, no cover, no cat trax, jib left up in sun, spin left in snuffer). I would rather have a boat that was used and the owner kept good care of it (stored mast down, washed and covered, sails kept inside, spin flaked, used cat trax to move around, waxed). Most sailors that use there boats tend to care for them more and keep up with the maintanence. | | | Re: Which is best?
[Re: Dlennard]
#86769 10/17/06 01:58 PM 10/17/06 01:58 PM |
Posts: 1,253 Columbia South Carolina, USA | Buy any boat that Dave Lennard has kept and you will get a well maintained and tricked out craft. WWDLD?
| | | Re: Which is best?
[Re: MauganN20]
#86773 10/22/06 01:59 AM 10/22/06 01:59 AM |
Joined: Mar 2002 Posts: 984 2017 F18 Americas Site Dan_Delave
Posts: 984 2017 F18 Americas Site | Its seriously no joke that half the fleet has WWDLD stickers on their crossbeams because of his rigging (and sailing!) prowess. WWDLD?guesses: We wait (for) Dave Lennard (to) derig Why would Dave Lennard Do (it) We Wish (for) Dave Lennard death I have no idea what you are talking about. | | | Re: Which is best?
[Re: Dan_Delave]
#86774 10/22/06 08:16 AM 10/22/06 08:16 AM |
Posts: 12,310 South Carolina | hahah...we even had bracelets at one time.
"What would David Lennard Do"...and even though he is a rigging fanatic and probably even a little more retentive that myself, he usually is the first one packed up (rigging off the boat too) because he has methodically thought through and prepared the boat and trailer storage for quick derigging and rigging. Chris Zander came up with that one.
Jake Kohl | | |
517
guests, and 100
