| Capturing base of H14 mast for raising #87063 10/22/06 01:24 PM 10/22/06 01:24 PM |
Joined: Sep 2003 Posts: 270 Nepean (Ottawa) Ontario Canada Frozen OP
Posts: 270 Nepean (Ottawa) Ontario Canada | The mast base (on the xbar) on my h14 has holes for a pin, but the mast has nothing that I can figure out for holding it in place (capturing it) for raising the mast.
I did a search on mast stepping and saw nothing appropriate.
Cheers Alan F
Tiger
| | | Re: Capturing base of H14 mast for raising
[Re: hobie1616]
#87067 10/23/06 06:42 PM 10/23/06 06:42 PM |
Posts: 270 Nepean (Ottawa) Ontario Canada | OK
had to blow up the diagrams to see it, but I see the mast step link kit P/N 213800 .
Seems as if there is a hole drilled in the mast rotation limiter in the base in their diagrams.
Cheers Alan F
Tiger
[Re: Frozen]
#87068 10/23/06 07:48 PM 10/23/06 07:48 PM |
Posts: 5,582 “an island in the Pacifi... | Seems as if there is a hole drilled in the mast rotation limiter in the base in their diagrams. It's 90 degrees from the left and right rotation stop. US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: Capturing base of H14 mast for raising
[Re: hrtsailor]
#87070 10/24/06 09:58 AM 10/24/06 09:58 AM |
Posts: 1,187 38.912, -95.37 | The other pin will have a hole for a split ring that you tie a light line to, so you don't lose it. I usually stick the loose pin under a loop in the tramp lacing so it isn't just hanging on the string. We keep the step pin loose and unattached, stowing it in the tackle box. That way were sure it's there when we return from sailing and not snagged by the crew and dropped in the lake. <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" /> Of course you can always use a phillips screw driver in a pinch. Another reason for keeping it loose is we've forgotten to pull it out and mangled the hinge before we figured out why the mast was NOT rotating <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />
[Re: _flatlander_]
#87071 10/24/06 07:46 PM 10/24/06 07:46 PM |
Posts: 4,119 Northfield Mn | Its also a good idea to pull the link off of the boat on a 14 or 16 because the mast base can hit the link when its raked way back. I haven't had it hit on my 14, but I've mangle a couple on my 16 before I learned.
[Re: Karl_Brogger]
#87072 10/24/06 10:06 PM 10/24/06 10:06 PM |
Posts: 493 Minnesota | I like to leave my link on and keep the pin tied nearby. If you de-mast while sailing, due to a shroud coming loose, you can re-mast without returning to your launch point. (I don't rake my mast much, so this works for me.) But I have occationally bent my link, during capsizing.
11,217
guests, and 411
