10:1 main sheet system - pictures of roving #87164
10/24/06 11:40 PM
10/24/06 11:40 PM
League City, TX
flumpmaster Offline OP
League City, TX
The new Nacra Infusion comes with a 10:1 main sheet system. I helped one of our club members rig his new boat and it took quite a few attempts at roving the blocks before we found a system that worked with low friction and did not twist the top block (causing the sheet to slide off the sheeves).
The system uses the Harken 57mm 5 pulley block on top. The black thing below the cleat is a big pair of rollers that aid in cleating/uncleating when the cleat is not pointing directly at you. Similar to the Harken extreme angle fairlead, but works even better. Not sure where you can buy them - they came with the boat.
Hope this saves someone a bit of time when they are roving a 10:1 with this set of blocks.
Chris.
Re: 10:1 main sheet system - pictures of reeving [Re: flumpmaster] #87165
10/25/06 09:18 AM
10/25/06 09:18 AM
Straight Outta Hell
Boudicca Offline
Boudicca  Offline
Straight Outta Hell
Chris-
couldja post either a real closeup pic of that fairlead, or look real careful at it and see whether it is a single unit or whether it is fabricated? - well, in any case I'd want a real good closeup pic, please. It looks a good thing for the Fboat.
Y'all ARE coming in for Shearwater, YES? Ederer is racing his 18HT, Jay should be aboard C.W...
This sig would be something witty, but the censors are against that.
Re: 10:1 main sheet system - pictures of reeving [Re: Boudicca] #87166
10/25/06 10:18 AM
10/25/06 10:18 AM
Wilmington,NC
Dlennard Offline
Dlennard  Offline
Wilmington,NC
The fairlead is just some of the rudder rollers with longer bolts. The rollers don't roll in the fairlead. The blocks look good but do you think that the eye strap and plate can suport the load of the double blocks. The ones I have seen have the double blocks attached to the top of the lower triple.
Re: 10:1 main sheet system - pictures of reeving [Re: Dlennard] #87167
10/25/06 12:33 PM
10/25/06 12:33 PM
That would explain the unused becket on the double block.
Re: 10:1 main sheet system - pictures of reeving [Re: _flatlander_] #87168
10/25/06 01:46 PM
10/25/06 01:46 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
The cordage companies must LOVE these setups! <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" />
US Sail Level 2 Instructor
US Sail Level 3 Coach
12:1 main sheet system - pictures of reeving [Re: flumpmaster] #87169
10/26/06 10:55 AM
10/26/06 10:55 AM
Straight Outta Hell
Boudicca Offline
Boudicca  Offline
Straight Outta Hell
http://flumpmaster.dnsalias.com/drupal-4.3.2/node/view/2165
see for closeup pix of fairlead rollers. I expect these are just bits of Delrin rod drilled to accept the longer bolts attaching it to the cleat. Add the 'cap' crossover end (fairlead) thingy which is commercially available, and you've got the kewl long-roller fairlead.
See below for pic of 12:1...
Re: 10:1 main sheet system - pictures of reeving [Re: Boudicca] #87170
10/26/06 08:38 PM
10/26/06 08:38 PM
League City, TX
League City, TX
Sadly there is a clash with Wursfest on Canyon Lake <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" />
0 registered members (), 369 guests, and 31 spiders.
