nacra 5.0 modification #8733
07/14/02 07:08 AM
07/14/02 07:08 AM
Cadiz, Spain
nearher Offline OP
nearher  Offline OP
Cadiz, Spain
Hello,
I have a nacra 5.0. I use it for recreation (not for racing) and I want to use a front beam jib sheeting system like those of the nacra fun series nacra 450 , 500, 570.Tthat way the trampoline will be more comfortable.
Is that feasible? Has anyone done the same? Where can I find a plan of the nacra 5.0 with ALL dimensions specified?
Thanks
Re: nacra 5.0 modification [Re: nearher] #8734
07/14/02 10:43 AM
07/14/02 10:43 AM
Mods of putting blocks on the front beam have been done, but the first problem
you will run into is that the foot of the jib is too long. you will have to have the
sail modified (shortened) if you want to do this type of mod. Another possibility
is to purchase a nacra 500 jib. It should still fit the forestay. The 500 jib is
shorter than the 5.0 jib to accomodate the new block design.
0 registered members (), 362 guests, and 51 spiders.
