Page 1 of 3 1 2 3
Righting Line for Blade #88259
11/05/06 10:03 PM
11/05/06 10:03 PM
Orange County, CA, USA
JJD Offline OP
JJD  Offline OP
Is there any consensus on righting line rigging for the Blade?
Where attached, stored, deployed? How long a line?
At this time, I just have a 3/8" line stuffed in the forward tramp pocket. That will probably take to long to deploy.
Thanks
Re: Righting Line for Blade [Re: JJD] #88260
11/06/06 04:58 AM
11/06/06 04:58 AM
Oxford, UK
pdwarren Offline
pdwarren  Offline
Oxford, UK
I've got a 10mm line, about 5m long, I think. I store it in the tramp pocket, and on the first capsize of the day tie it round the dolphin striker and then chuck it over the top hull.
I used to leave it tied round the dolphin striker, but the bowlines kept undoing themselves as they got pounded by the waves. I lost one rope this way.
I'm sure you could go thinner for weight reasons, but I'm not a big fan of putting fine lines over the hulls and then putting all my weight on them.
Re: Righting Line for Blade [Re: pdwarren] #88261
11/06/06 08:24 AM
11/06/06 08:24 AM
I use an 8mm line, about 4m long, tied AND TAPED around the dolphin striker. The key thing is, it's kept in a pocket that closes with velcro, and it's on the UNDERSIDE of my trampoline just behind the main beam. It's protected from wave bashing by the mainbeam itself and is instantly and easily accessible once the boat's gone over.
It also doesn't take long to stuff the line back in once the boat's 'pointy stick up'.
Re: Righting Line for Blade [Re: pdwarren] #88262
11/06/06 08:40 AM
11/06/06 08:40 AM
Thailand
Buccaneer Offline
Buccaneer  Offline
Thailand
You can also attach a couple of padeyes to the front crossbeam one each side for a 8mm line (non-abrasive) with a bead on each end and a small block at the rear center of the tramp for a bungee to hold the line in place. I’ve seen several Taipans set-up this way and for the lighter platforms its working well and saves time. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Re: Righting Line for Blade [Re: Buccaneer] #88263
11/06/06 09:56 AM
11/06/06 09:56 AM
That is actually a very neat trick. We must add this one to the open-source F16 design.
Re: Righting Line for Blade [Re: Wouter] #88264
11/06/06 10:41 AM
11/06/06 10:41 AM
Any pictures of that setup? I am interested to see how it looks.
Re: Righting Line for Blade [Re: JJD] #88265
11/06/06 09:56 PM
11/06/06 09:56 PM
JJD,
If you are new to the boat and expect to be using the line a little its good to have one that is quick to use.
I use 8mm silver rope. A real cheap synthetic rope that to me seems a bit like flax. It does not seem to absorb water. I tie a knot in it every 12 or 18 inches.
Attached it to either each side of the front beam by popping on saddles undeneath. So the line goes from one side to near the centre of the back beam and then to the other side in the shape of a "V".
This line is kept tight by a 6mm shock chord that goes from the middle of the righting line to a pulley in the middle of the rear beam and forward to the striker post.
This will get you up the quickest because the line is continuous you can grab the lower section and pull in the slack and use it to pull yourself up onto the hull.
So when righting the boat you put the line under your trap hook to take the load.The knots stop the line from slipping when they hit your trap hook.
Lower arm holds up some tension and upper arm pulls in slack to move up to the next knot as the boat starts to come up keeping you at the optimum angle and not lying in the water.
If you need more weight outwards you can put the uper arm out past your head and bounce a little to get the thing moving.
Another way is same type of rope with knots but two of them. Going from front to rear beam with two pulleys and shock cords going forward to the saddle the rope is attached to each side. You have pretty good rear beam clearance on the Blade so you don't drag the "V" line in the water at all but some people just rather two lines.
Anyway there is often more than one good sollution to any given problem and over the years these have worked well for me, on a number of different boats, including the Blade.
Hope this helps.
Re: Righting Line for Blade [Re: Robi] #88266
11/07/06 02:38 AM
11/07/06 02:38 AM
Thailand
Buccaneer Offline
Buccaneer  Offline
Thailand
OK here is what it looks like.. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Red line is bungee - white/blue line is the righting line.
Re: Righting Line for Blade [Re: Buccaneer] #88267
11/07/06 03:18 AM
11/07/06 03:18 AM
Thailand
Buccaneer Offline
Buccaneer  Offline
Thailand
Padeye and rope bead front beam. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Re: Righting Line for Blade [Re: Buccaneer] #88268
11/07/06 07:56 AM
11/07/06 07:56 AM
AHA! sweet looking system. I like it. Thanks for sharing.
Re: Righting Line for Blade [Re: Robi] #88269
11/07/06 11:13 PM
11/07/06 11:13 PM
JJD Offline OP
JJD  Offline OP
Thanks for the quick responses guys.
I appreciate all the help and advice I get.
Saw a similar setup to these on a local A cat but wasn't sure it would adapt to a Blade.
I'll try it.with Phill's knots.
John D.
Re: Righting Line for Blade [Re: JJD] #88270
11/07/06 11:51 PM
11/07/06 11:51 PM
Central California
ejpoulsen Offline
ejpoulsen  Offline
Central California
John,
I have the same system as Buccaneer. I works great but would be a pain with the periodic knots Phill uses because they will catch on the bungeed ring.
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: Righting Line for Blade [Re: ejpoulsen] #88271
11/08/06 01:38 AM
11/08/06 01:38 AM
Eric,
In my system there is no bungee ring with the knots.
Not needed as the bungee is not supposed to slide along the line. It is a bungee and stretches. In the beginning I had it without knots but found it much better with them.
Re: Righting Line for Blade [Re: phill] #88272
11/08/06 06:42 AM
11/08/06 06:42 AM
Sydney/Northern Beaches
Bandit Offline
Bandit  Offline
I have a slight vairation to this setup.
The bungee and the A section of rope is the same but my rope doesn't end at the front beam with a bead, it continues to the rear beam on both sides hugging the hull before its TIED OFF. You can then grab the line anywhere between the front and rear beam on the raised hull to manover your wieght to the best angles required and for 2 up there is room for both to grab the line.
Sail 1635 Blue Tongue
Re: Righting Line for Blade [Re: Bandit] #88273
11/08/06 08:19 AM
11/08/06 08:19 AM
Thailand
Buccaneer Offline
Buccaneer  Offline
Thailand
Good point maybe good for doubles but this will also move your balance point considerably more towards the aft. For solo righting with the Taipan system wrap the line with bead around your trap hook twice sit back and she'll normally come over first try. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Re: Righting Line for Blade [Re: Buccaneer] #88274
11/08/06 09:14 AM
11/08/06 09:14 AM
Does pulling from the upper beam rather than throwing the line over the hull produce less righting force?
Re: Righting Line for Blade [Re: ] #88275
11/08/06 09:27 AM
11/08/06 09:27 AM
Oxford, UK
pdwarren Offline
pdwarren  Offline
Oxford, UK
No, but it will increase the amount of tension on the rope needed to lower your body to any given angle. So, if you use knots and your trapeze hook, it's probably not a big issue. If you're trying to hold the rope by hand, you may find that you can't get your body as low.
Re: Righting Line for Blade [Re: pdwarren] #88276
11/09/06 02:06 AM
11/09/06 02:06 AM
Melb. Aust
Trevor Offline
Trevor  Offline
Melb. Aust
What sort of crew weight per platform weight ratio is needed to get the boat on its feet from either a complete turtle or floating on its side?
I generally go with getting on trap while on the beach : if the hull lifts, it will come up if turtled. But there was a post detailing a method where all the weight is shifted to one corner, sinking it and allowing the opposing end to come up.
Mozzie 1828
Sugarloaf Sailing Club
Melbourne
Re: Righting Line for Blade [Re: Trevor] #88277
11/09/06 07:55 AM
11/09/06 07:55 AM
Oxford, UK
pdwarren Offline
pdwarren  Offline
Oxford, UK
I've never had any trouble getting the Blade back up on my own, and I'm about 85kg. I've only ever capsized the Blade in a fairly decent wind, and I think I'd have trouble in very light wind.
I've not turtled the Blade, but I've had done with other boats. The only technique I know for righting (without a powerboat) is to sit on very back of the leeward hull, so that the bow of the windward hull lifts. The boat will (eventually) end up on its side.
Re: Righting Line for Blade [Re: pdwarren] #88278
11/09/06 09:12 AM
11/09/06 09:12 AM
Paul you and me are the same weight. If there is no wind, do not plan on bringing your blade up singlehanded. Been there done that too many times.
Page 1 of 3 1 2 3
0 registered members (), 19,133 guests, and 1,208 spiders.
Most Online22,490
13 hours ago
