| Re: What do you tow with
[Re: Robi]
#88904 11/16/06 01:38 PM 11/16/06 01:38 PM |
Posts: 3,528 Looking for a Job, I got credi... | Did you all know that once the Veyron reaches its top speed of 256mph it will run out of fuel in 12minutes! <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> That would be the best 50 miles ever!! <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" /> And its only around 48" tall. CRAZY! Quad turbo 16 cylinder <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> 1000+ HP <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> All wheel drive! Air to water intercooled <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> Yeah its a bad butt car! <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> I did know about that. Makes my 8MPG at full chat sound frugal ! Might have to find a race track to see if I could average 8mpg for a full tank !
F16 - GBR 553 - SOLD I also talk sport here | | | Re: What do you tow with
[Re: Keith]
#88905 11/17/06 12:52 PM 11/17/06 12:52 PM |
Posts: 1,200 Vancouver, BC | Do I win some sort of prize <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" /> I'd personally issue a prize if you have a follow-up pic showing the Tornado pulling the Mini on floating trailer while under sail! I'll need some time to work that out... Mike. | | | Re: What do you tow with
[Re: Tornado]
#88906 11/17/06 01:53 PM 11/17/06 01:53 PM |
Joined: Nov 2006 Posts: 116 41.32 N, 81.35 W Stuart_Douglas
Posts: 116 41.32 N, 81.35 W | Nice discussion on global petro-politics, er...I mean towing. <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
I'll go on record as siding with those that think gasoline is under-priced in the US (given the negative societal impacts from it's mass use that don't get factored into it's price). I look at what's happening with cigarette smoking here as a sign of things to come...people are wising up to the fact that there's a huge burden placed on society from it, the cost of which is being put back into the product via increased taxes. The US will come around. Now that "normal" means $2+/gal., dealers can't move large trucks/SUVs to anyone but those that truly need them or can afford not to care. The US auto industry is hurting because most of it's recent sales revenue has come from truck/SUV sales. Change will happen, we'll all become more responsible one way or another. <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
As for towing, I've been driving Subaru's since the '80's (GL, Legacy, Impreza). They've all towed the Sunfish we just sold without issue, and I expect the same for the cat we'll be getting this winter/spring. You take a hit on the full-time AWD in terms of MPG, but they're not horrible, and they're as reliable as the work-day is long. Now that our daughter's graduated from college, we're once more considering a new car...Forester most likely, maybe an Outback for the H6. | | | Re: What do you tow with
[Re: NCSUtrey]
#88907 11/17/06 02:15 PM 11/17/06 02:15 PM |
Posts: 1,226 Atlanta | But you'd never run out of badass points. yes!!!!!!! | | | Re: What do you tow with
[Re: Stuart_Douglas]
#88908 11/17/06 02:28 PM 11/17/06 02:28 PM |
Posts: 321 Albuquerque NM | don't know how true this is, but I understand that our (US) gasoline has a considerably lower octain than that of other countries, if this is true, does that not play into the cost per gallon?
And now back to our regularly scheduled program.
[b] Sail Like you have a Pair
[Re: Rhino1302]
#88910 11/17/06 03:39 PM 11/17/06 03:39 PM |
Posts: 306 St. Louis, MO | So what is 90 octane US equal to in Europe?
Nick
Current Boat Looking for one
[Re: Rhino1302]
#88912 11/17/06 05:11 PM 11/17/06 05:11 PM |
Posts: 3,528 Looking for a Job, I got credi... | Octane in the US and Canada is measured differently then the rest of the world. 87 Octane in the US equates to somewhere around 92 in Europe. Feck, what do you guys run Turbo cars on ! I'm always looking for 98+ RON.
[Re: scooby_simon]
#88913 11/17/06 08:18 PM 11/17/06 08:18 PM |
Posts: 5,582 “an island in the Pacifi... | Does anyone remember Chevron Custom Supreme? 120 Octane for $.31 a gallon. Those were the really good old days! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: What do you tow with
[Re: hobie1616]
#88914 11/18/06 08:27 AM 11/18/06 08:27 AM |
Posts: 12,310 South Carolina | there is a common misnomer that higher octane = higher performance or is somehow a 'cleaner' fuel. If your engine was designed to run a high octane fuel then you should. However, if your engine was designed to run a minimum of 87 octane, you'll not see much difference going to a higher 95 or even 120 (you could actually see a decrease in performance).
There's a point at which under so much heat and pressure inside an engine the fuel vapor will ignite without the presence of a spark (like in a diesel engine). Higher octane fuels auto-ignite at higher pressure and temperature levels than lower octane fuels allowing engine designers to design in higher compression ratios (or use turbos and superchargers). Long piston strokes, turbos, or superchargers cram more fuel/air into an engine resulting in higher compression and additional power but require a higher octane fuel to prevent the fuel vapor from igniting before th e spark plug lights it up resulting in "knock" - a dangerous condition that can do substantial damage inside the engine if left unchecked (most modern cars have knock-sensors that detect this condition and will try to compensate by adjusting the air/fuel ratio).
Jake Kohl | | | Re: What do you tow with
#88915 11/18/06 09:33 AM 11/18/06 09:33 AM |
Posts: 6,049 Sebring, Florida. | But...if you really want to run 100 octane low lead, go to your nearest small airport and buy it at the pumps there, and bring your wallet, it's about $3.50 a gallon these days.
Blade F16 #777
#88916 11/18/06 10:27 AM 11/18/06 10:27 AM |
Posts: 5,582 “an island in the Pacifi... | there is a common misnomer that higher octane = higher performance or is somehow a 'cleaner' fuel. If your engine was designed to run a high octane fuel then you should. However, if your engine was designed to run a minimum of 87 octane, you'll not see much difference going to a higher 95 or even 120 (you could actually see a decrease in performance).
There's a point at which under so much heat and pressure inside an engine the fuel vapor will ignite without the presence of a spark (like in a diesel engine). Higher octane fuels auto-ignite at higher pressure and temperature levels than lower octane fuels allowing engine designers to design in higher compression ratios (or use turbos and superchargers). Long piston strokes, turbos, or superchargers cram more fuel/air into an engine resulting in higher compression and additional power but require a higher octane fuel to prevent the fuel vapor from igniting before th e spark plug lights it up resulting in "knock" - a dangerous condition that can do substantial damage inside the engine if left unchecked (most modern cars have knock-sensors that detect this condition and will try to compensate by adjusting the air/fuel ratio). I ran the Custom Supreme in a '63 Ford 427 with 13.5 to 1 compression. You really could see the gas gauge move. <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: What do you tow with
[Re: hobie1616]
#88917 11/19/06 10:45 AM 11/19/06 10:45 AM |
Joined: Jun 2001 Posts: 75 Ljubljana, Slovenia mayhem
Posts: 75 Ljubljana, Slovenia | When I was in the US, I towed my N60 with a Nisan Sentra. Did fine up to 60mph (100Km/h), but milage when from 40mpg to 20mpg and windage from trucks meant I could never pass anything at any speed. As important as the car, is the trailer-- get a good quality one, preferably light-- I am in love with Trailex. It will compensate for 30+hp and an extra 800lbs (400kg) of car size.
Eric mentioned European diesels. I now now with a Mazda6 wagon. 140-160km (90-100mph) with a well strapped down A-cat is no problem. Fuel consumption is still above 25mpg even at that speed. 2/3 of all European cars sold are now diesels. They get 30% better mileage, just as quiet (except perhaps a slight difference at idle), start just as easy; however, they have so much more torque that you never need to shift to stay in the power. This is not the same diesel technology offered in VWs in the USA or found in even the newest Dodge-Cummings. As I understand the problem was sulfer found in US Diesel fuel-- this would destroy the modern Euro direct injection diesels. The result, USA diesels had to use only the old technology. About 1 year ago, the US forced the fuel companies to remove this sulfer-- now you should be starting to get them. I highly recommend trying one when they start showing up in dealers.
Matt | | | Re: What do you tow with
[Re: fin.]
#88919 11/20/06 12:01 AM 11/20/06 12:01 AM |
Posts: 851 US Western Continental Shelf | Currently I tow the Mystere 6.0 on it's steel trailer with a 2005 Toyota Corolla that drives from the front with a 1.8 liter engine. Previously I used a 1998 Subaru Legacy L that had an All Wheel Drive 2.2 liter engine.
While I do miss the traction of the AWD car, the 1.8 liter Toyota is far more powerful, has way better fuel economy, and has far less mechanical problems than did the Subaru.
Before the Legacy, I owned another Legacy. Before that I had a 1.8 liter turbo charged Subaru GL wagon. Nothing has been as good as the Toyota for towing.
When the Toyota was new, the cheap tires had trouble on wet surfaces. New tires have taken care of that problem.
I'll miss my AWD when I need to go snow skiing. 'Till then, I have enjoyed the trouble free service of the Toyota.
GARY (solved the infamous P.O.S. Subaru Hesitation problem)
Santa Monica Bay Mystere 6.0 "Whisk" <--- R.I.P. | | | Re: What do you tow with
#88921 11/21/06 04:29 PM 11/21/06 04:29 PM |
Posts: 3,348 | | | |
508
guests, and 120
