| Broke my hot stick..... #89732 11/14/06 05:36 PM 11/14/06 05:36 PM |
Posts: 70 Louisiana | I have a fiborglass hot stick that broke about 8 inches from the end (where you hold it). The break is a clean break all around (no splinters). Does anyone have any sugestions on how to fix it?
Thanks Todd Hubbell Thibodaux, LA
Sailing a 1980 Hobie-18M with 1990 hulls in Southern Louisiana.
| | | Re: Broke my hot stick.....
[Re: MauganN20]
#89735 11/15/06 11:40 AM 11/15/06 11:40 AM |
Posts: 248 Colorado | I might try one or two other things:
Get an aluminum tube that has nearly the same outer diameter (OD) as the hiking stick's inner diameter (ID), and use this to support the broken pieces from the inside. The aluminum doesn't have to be really stout. An old lawn chair with the right diameter tubing would work. Use rivets to hold it in place, then fiberglass from the outside as MauganN20 suggests. You also may want to first sand the stick where you apply fiberglass to remove the sheen and give the resin something rough to cling to.
Rather than using your hands to squeeze out resin (definitely wear gloves no matter what), clamp a window squeegee to a table and turn the stick against it in the direction the glass cloth was rolled on. Squeegee each layer independently, then let the first layer get tacky - not dry - then apply the second layer in the opposite direction and squeegee again. Also, wet the cloth completely with resin before applying it to the stick and skip the tape.
You'll have a hotstick that's tougher in the repaired section than anywhere else.
H-20 #896
[Re: Rolf_Nilsen]
#89741 11/15/06 03:30 PM 11/15/06 03:30 PM | Anonymous
| Anonymous
Unregistered | If you've broken a telescopic tiller extension 6 inches from then end. Why not just clean up the break and glue a squash ball on the end? How often do you max out your extension?
[Re: fin.]
#89743 11/15/06 06:35 PM 11/15/06 06:35 PM | Anonymous
| Anonymous
Unregistered | If the wind is light this week end, I'm gonna use a $10 telescoping extension from Home Deopt. Anyone care to guess how long it will last? I would guess longer than 2 years 4 months. | | | Re: Broke my hot stick.....
[Re: fin.]
#89745 11/15/06 08:38 PM 11/15/06 08:38 PM | Anonymous
| Anonymous
Unregistered | If you need the length thats a different ball game I'm 5'6" so its not an issue. If you don't need the length a small bolt through the top (covered with the ball) would fix the popping off issue. | | |
1 registered members (FredL),
2,406
guests, and 222
