| New boat pics - image intensive (ish) #90215 11/21/06 03:37 PM 11/21/06 03:37 PM |
Joined: Feb 2004 Posts: 3,528 Looking for a Job, I got credi... scooby_simon OP Hull Flying, Snow Sliding.... |
Posts: 3,528 Looking for a Job, I got credi... | All, Sorry, no pics with the sails up as we had to rush that bit due to swirling winds one minute and then nothing the next and bucketing rain. Anyway, did get some pics of the carbon beams and the revised self-tacker. I'll get more pics in 2 weeks (cannot sail next weekend). Front beam: Self tacker : Back beam : Both beams are Carbon Foam sandwich around the beam bolts with bracing as well, the areas under the self tacker also have bracing. JP can confirm the exact structure. Overall impression is that the boat is VERY stiff - we picked the boat up at opposite corners and there was very little (if any) sag on the bows - very impressive. I've commented elsewhere on the shape of the kite and to add that the mainsail looks fantastic. Comments on the Jib when it arrives (it will be on the max luff length thanks to the dropped bridals. Unfortunatly we did not have time to take loads of pictures as the conditions were not kind to us. I'll take loads in 2 weeks time.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: New boat pics - image intensive (ish)
[Re: scooby_simon]
#90217 11/21/06 04:09 PM 11/21/06 04:09 PM |
Posts: 1,382 Essex, UK | That looks sooo cool Simon. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
John does do a nice job, does he not? <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
I do like the self tacker set-up (my Stealth has the low profile Harken version on a flat plate in front of the beam)and I fully expect the platform to be incredibly stiff with those beams.
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: New boat pics - image intensive (ish)
[Re: Jalani]
#90218 11/21/06 04:24 PM 11/21/06 04:24 PM |
Posts: 3,528 Looking for a Job, I got credi... | More boat pron weekend after next.
Boat is safely tucked up at my parents for the next 10 days as I cannot sail next weekend.
The plates are Loooooooong and still cooking in the spare room as John had not long finished them (no I have not yet calculated the aspect ratio !).
If class rules allowed we could actually have had a 6.2m luff / leach as the bridals are a little down the inside of the hulls.
Only other changes are
1, Carbon mast spanner fairly close to the bottom of the mast and a 12:1 DH on the mast. Not sure I will actually use the 12:1 (might just rig as 8:1). 2, 2x Carbo ratchamtics each side for the kite. 3, Higher aspect plates (around 4.7 we think) 4, Higher aspect Jib 5, Higher aspect Kite (did not have time to measure the luff or take pics).
[Re: Tony_F18]
#90220 11/21/06 05:31 PM 11/21/06 05:31 PM |
Posts: 3,528 Looking for a Job, I got credi... | Very nice looking cat, Where did you put the spin halyard cleat? On the mast or the beam? Beam. IMO mast is wrong for single handing as It's not always possible to stand up. I'll be sailing the boat single handed most of the time. Forgot to say the Self taker is removable !
F16 - GBR 553 - SOLD I also talk sport here | | | I really like what you guys have done with it .. !
[Re: scooby_simon]
#90221 11/21/06 06:35 PM 11/21/06 06:35 PM |
Posts: 9,582 North-West Europe | I really like what you guys have done with the boat. Those are really good looking beams and with the eliptical front I think you stand a very good chance on cutting down on spray. I also like the new dolphinstriker strap. Is that custom to you boat or will this also be fitted to all the new stealths. That strap will make the mainbeam very stiff under mast loads and the flatness of the strap will make it cut through waves effortlessly. My impression of the Stealth F16's always was that they were rather stiff in the platform, with the upgrades it surely must be very stiff indeed. And that is good as I've seen the new stiffness data on the Blade design. The competition is definately on. If class rules allowed we could actually have had a 6.2m luff / leach as the bridals are a little down the inside of the hulls.
Yes, but don't actual go that tall. We had to decide on some limit in the rules and it turned out that the mathematical formula used in Texel/SCHRS handicap can hardly distinquish between jibs wit luff lengths in the range of 5.4 to 6.0. We didn't want to limit designes freedom to much in the F16 rules and so we just maxed out this rule. However 6.2 mtr long jibs will be extremely narrow and tall, having an aspect ratio of 10. They are most likely to be very sensitive to trim. Everybody seems to converge to 5.50 mtr long jib luffs and that seems to work out well. Also don't bring the jib too low as it will be between the hulls and therefor when lifting a hull part of the jib will be in bad air coming of the hull. This another reason why other builders don't go past 5.5 mtr luff lengths. 2, 2x Carbo ratchamtics each side for the kite.
Yep, no doubt about it. Good mod ! 3, Higher aspect plates (around 4.7 we think)
That is pretty tall ! Well, you will not be suffering any performance loss in stable medium winds that is for sure. Probably track like a Fox hound. But you'll probably be lifting them early on when the gusts come or the winds increase. Good mod, there was some potential to be gained there. 5, Higher aspect Kite (did not have time to measure the luff or take pics).
Very good for singlehanded sailing. Alot of luff length and a flat kite should be really effective when singlehanding. From you describtion it almost sounds like you have a spi luff that is taking from skiffs. These too have very rounded luffs. Often this means they are cut to sail really deep. Wouter
[Re: scooby_simon]
#90222 11/21/06 08:04 PM 11/21/06 08:04 PM |
Joined: May 2002 Posts: 1,037 Central California ejpoulsen
Posts: 1,037 Central California | After having just looked at the boat yard of Stealths there in Datchet, I must say that JP has made several nice looking changes..
[Re: ejpoulsen]
#90223 11/22/06 02:50 PM 11/22/06 02:50 PM |
Posts: 3,528 Looking for a Job, I got credi... | From you describtion it almost sounds like you have a spi luff that is taking from skiffs. These too have very rounded luffs. Often this means they are cut to sail really deep. It may sound like it, but no, having had a think about this, I think the kite will go VERY flat when I want it to, but when I need it to, it will go very full. More pictures below, sorry over exposed and I don't have time to photoshop them. Front beam and Mast spanner - note the rain and sun. It was a very "odd" day Rear bem and Rudder Pic from the back, note the dropped firring on the bow. ![[Linked Image]](http://www.catsailor.com/bb_files/91148-DSCF0500.JPG)
[Re: scooby_simon]
#90224 11/22/06 03:57 PM 11/22/06 03:57 PM |
Scooby,
You ARE going to bring that boat over to Zandvoort Global Challenge in 2007, right ?
Blade has been taking all the attention on mainland EU, it is time that Blade gets some serious competition and your boat is absolutely the right boat to do it with.
Besides I want to see it up close and personal !
[Re: Wouter]
#90225 11/22/06 04:20 PM 11/22/06 04:20 PM |
Scooby,
I am hoping to. I am 99% going to be at the Nationals as this is easier and cheaper to attend. Zandvoort is not certain, but I hope to.
[Re: scooby_simon]
#90226 11/23/06 03:35 AM 11/23/06 03:35 AM |
Joined: Aug 2003 Posts: 41 Geneva, Switzerland johnfullerton
Posts: 41 Geneva, Switzerland | Hi
I like the look of the carbon beams. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
I see you got a footstrap on the back of each hull.
How are these attached to the hull ?
Bye
Sarah and John Stealth 551 RS400 871
[Re: john p]
#90228 11/24/06 05:51 PM 11/24/06 05:51 PM |
Posts: 3,528 Looking for a Job, I got credi... | I also like the new dolphinstriker strap. Is that custom to you boat or will this also be fitted to all the new stealths. That strap will make the mainbeam very stiff under mast loads and the flatness of the strap will make it cut through waves effortlessly. Wouter, The strap dolphinstriker will only be available on the Carbon Beam option, the Alu beam Dolphin striker would not fit so John had to find another solution and this was it. This is also true for the removable self tacker.
[Re: scooby_simon]
#90231 11/29/06 05:04 AM 11/29/06 05:04 AM |
Joined: May 2006 Posts: 954 Mumbles Y.C Wales U.K Mark P
Posts: 954 Mumbles Y.C Wales U.K | I'm very Impreza'd Scooby. Looks as if John has just raised the benchmark amongst the F16 manufactures. If it goes as good as it looks you could be the first human cannon ball in the F16 Circus. Good luck this weekend I hope the weather is favourable and you manage to wipe the smile of your face by Christmas. P.S don't be shy with the photo's. MP*MULTIHULLS | | | Re: New boat pics - image intensive (ish)
[Re: Mark P]
#90232 11/29/06 12:12 PM 11/29/06 12:12 PM |
Posts: 3,528 Looking for a Job, I got credi... | I'm very Impreza'd Scooby. LOL.... More boat pron <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Sorry, no sails up pics yet. Did not get time, as you can see from these pics it is starting to get dark.. mast rotation comes up from under the tramp. ![[Linked Image]](http://www.letshaveachat.com/gallery/gallery2/d/120-1/130_3068.JPG) Then the tails are lead to the side decks thru a small block, then the a cleat ![[Linked Image]](http://www.letshaveachat.com/gallery/gallery2/d/127-1/130_3070.JPG) Tail then continues thru the deck tramp eyes - thinking here is that if I pull by the cleat, it somes out, but if I pull behind the fist eye, I pull more roatation out of the mast. ![[Linked Image]](http://www.letshaveachat.com/gallery/gallery2/d/130-1/130_3071.JPG) Having looked at the pics, I've set this up wrong as I need the rope to go one more ring back before going down as I will not be able to let off any rotation with the plates up. Double Ratchamatics, Kite goes to aft one first. ![[Linked Image]](http://www.letshaveachat.com/gallery/gallery2/d/145-1/130_3077.JPG) Forestay bridal is about 7 cm from the top of the boat in the inside. ![[Linked Image]](http://www.letshaveachat.com/gallery/gallery2/d/139-1/130_3075.JPG) Mast up with Boom and spanner: [img] http://www.letshaveachat.com/gallery/gallery2/d/148-1/130_3078.JPG[/img] 2:1 trapeze adjusters: [img] http://www.letshaveachat.com/gallery/gallery2/d/151-1/130_3080.JPG[/img] Not much clutter up front without the jib: [img] http://www.letshaveachat.com/gallery/gallery2/d/154-1/130_3082.JPG[/img]
2,688
guests, and 504
