| Re: Mainsail cut
[Re: Mary]
#90807 11/28/06 10:14 PM 11/28/06 10:14 PM | Anonymous
| Anonymous
Unregistered | With modern sail cloths you won't be able to make many changes to the sail shape with your battens | | | Re: Mainsail cut
[Re: Mary]
#90808 11/29/06 01:09 AM 11/29/06 01:09 AM |
Posts: 9,582 North-West Europe | Mary,
The lower halve of the mainsail is somewhat different in draft and twist profile when it is designed to sail with a jib. Or at least that is what you ideally want.
valtteri, is right. It is possible to tune a 2-up mainsail to sail singlehanded well, but not the other way around. In very competitive sailing I suspect that a custom made singlehander sail will be more competitive though.
Personally, I had my mainsail cut to suit my expected 150 kg combined 2-up crew weigth. I use this all the time when I sail singlehanded and it does surprise me how fast it is in that usage. It is a little more work to tune it right but I'm not killed on the course by other boats. I have too little experience with optimized singlehander sails to comments further on those.
But as stated above; I'm quite happy with the decision I took in 2003 to go for a 2-up mainsail and try to tune it down to 1-up usage. I'm using a relatively flexible alu mast, this may help.
| | | Re: Mainsail cut
[Re: valtteri]
#90810 11/29/06 03:02 AM 11/29/06 03:02 AM |
I tried the different top battens thing (3 top battens) but I'm not using it anymore. It didn't work as intended on my pentex mainsail. I guess I agree with Scarecrow on this one.
All the stiffer battens did was mess up my batten pockets on my boltrope. I had to repair a few of them because the much increased batten tension had split them apart. In short, the stiffer batten set for singlehanding wasn't a succes by any stretch of the imagination. At least not in my case.
| | | Re: Mainsail cut
[Re: Rolf_Nilsen]
#90813 11/29/06 02:12 PM 11/29/06 02:12 PM |
Posts: 9,582 North-West Europe | Ahh Rolf, what you wrote is actually not correct. To compensate for the "bending" of the airstream created by the jib, one want more twist in the top of a sloop main.
Actually to correct for the "bending" of the airstream created by the jib, one want LESS twist in the BOTTOM of a sloop main. The top is best when it is about the same as for a boat without a jib. Afterall the mainsail top of a sloop rigged rig does not really see any bending by the jib, it is too far above the main body body of the jib. And that is exactly what I'm seeing in the pictures. The A-cat appears to have more twist low and probably some more draft there as well.
| | | Re: Mainsail cut
[Re: Rolf_Nilsen]
#90817 11/30/06 03:35 AM 11/30/06 03:35 AM |
Joined: May 2006 Posts: 954 Mumbles Y.C Wales U.K Mark P
Posts: 954 Mumbles Y.C Wales U.K | Are these boats sailing in different directions ? It looks to me as if the camera position is the only difference, being directly behind the A Cat windward hull and 4-6 foot (1.2-1.8m) more too windward behind the F18. However, the sail shapes and particularly twist look remarkably similar. It seems to me as if both types of sail plan are getting flatter and flatter to reduce drag. MP*MULTIHULLS | | | Re: Mainsail cut
[Re: valtteri]
#90819 11/30/06 05:35 AM 11/30/06 05:35 AM |
Joined: Jun 2006 Posts: 177 Sydney/Northern Beaches Bandit
Posts: 177 Sydney/Northern Beaches | As I understand it... Regardless if you 1 or 2 up the amount of twist in the main should be adjustable according to your boat speeds and conditions and your jib should copy that same setting to aviod bad air flow onto the lift aera behind your main. A Sail that can change shape from flat to full is the best cut main but it needs a fully adjustable jib to best compliment watever shape the main sail is set to. A Flat cut main is easier to change too a fuller main with softened batterns and less tension. Where as a Full main requires Very Stiff battens and lots of tension but you will struggle to flaten the sail completly and will procced to stretch and wear out you sail.
Sail 1635
Blue Tongue
2,643
guests, and 351
