comptip replacement on Hobie 20 #9093
07/29/02 08:05 PM
07/29/02 08:05 PM
Lawrence, KS
hobien Offline OP
hobien  Offline OP
Lawrence, KS
Anyone know the best technique and materials needed to replace the comptip on a hobie 20
Lifes a reach ...
Re: comptip replacement on Hobie 20 [Re: hobien] #9094
07/29/02 08:22 PM
07/29/02 08:22 PM
catman Offline
catman  Offline
I think your best bet is to contact Hobie first, then get other ideas.
Re: comptip replacement on Hobie 20 [Re: hobien] #9095
07/29/02 11:25 PM
07/29/02 11:25 PM
is it broken off inside the mast?
do you want to keep the comptip?
Re: comptip replacement on Hobie 20 [Re: MauganN20] #9096
07/30/02 07:54 AM
07/30/02 07:54 AM
Lawrence, KS
hobien Offline OP
hobien  Offline OP
Lawrence, KS
The comptip broke about a third of the way from the top, the remainder is still in the mast. Comptip is toast.
Lifes a reach ...
Re: comptip replacement on Hobie 20 [Re: hobien] #9097
07/30/02 08:25 AM
07/30/02 08:25 AM
well when I had to dig the comptip out of my new h17 mast, there was only the stump left inside the extrusion... no matter how we tugged and pulled it would only splinter and fragment, thus staying inside the mast. So we got a heatgun at first, and heated around where the comptip makes contact with the mast. It allowed us to drive a flathead screwdriver in between the comp and the aluminum, but it still wouldn't budge. After pulling a large amout of hair out, we finally just took a propane torch, and just stuck it up inside the mast. As long as you:
a) don't let the comptip burn for an extended period of time so that the aluminum doesn't warp or
b) breathe in the fumes
You should be able to get it out. Mine was epoxied in there, I'm guessing that yours is either silicon sealed or something else.
0 registered members (), 343 guests, and 59 spiders.
