| Clevis pin replacement. #9124 08/01/02 10:01 AM 08/01/02 10:01 AM | Anonymous OP
| Anonymous OP
Unregistered | I was asked if an aluminum carabiner could be used in place of a clevis pin. A carabiner is quicker to get on and off, but probably not as strong as a clevis pin of the same size. Any thoughts on using a carabiner or another type of connector for rigging lines? | | | Re: Clevis pin replacement. #9125 08/01/02 08:08 PM 08/01/02 08:08 PM |
Posts: 217 | Curious what you want to use the caribiner for. There are many shackles that are easy & quick to use, like a caribiner.
As for caribiner, use stainless, not aluminum.
| | | Re: Clevis pin replacement. #9126 08/01/02 08:18 PM 08/01/02 08:18 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | I think using alum.anything would be very dangerous. I have used a shackle in place of a pin. I did this on my bridles at the hull. This gives me a attachment point for, anchor, spin. pole and removable front tramp.
[Re: catman]
#9127 08/01/02 08:37 PM 08/01/02 08:37 PM |
Posts: 3,116 Annapolis, MD | What you are probably looking for are called quick pins and are available at West marine and all sailing online shops.
They are stainless steel and have a push button that allows the pin to slide on an off a fitting. They come in various lengths and diameters. Various opinions exist on how safe they are for standing rigging.
Aluminum will not hold any rigging loads.
Take care
crac.sailregattas.com
| | | Re: Clevis pin replacement. #9129 08/02/02 01:16 PM 08/02/02 01:16 PM |
Posts: 23 | Hi:
The answer isn't as simple as yes or no. It depends on how much loading is on the pin to begin with. For example, if you wanted to hook a shock cord to a becket that had a 3/16" diameter SS pin, there is no reason you couldn't use an aluminum pin. On the other hand, if the pin was holding your rig up, I'd be very careful what I used. You should be able to find published working loads for various pin diameters and materials used in normal configurations and then evaluate the application for yourself. WRT aluminum, corrosion issues can quickly reduce the strength of pins that are exposed to salt water, particularly if the pins are in close proximity to stainless steel or carbon fiber. For all pins, wear on the pin, pitting, and any scratches (particularly circumferential) that are on the surface will substantially reduce the strength of the pin.
So a short answer is yeah you could do it if the carabiner was very lightly loaded, not in a critical application, not exposed to corrosive environments, and if the condition of the carabiner was evaluated on a frequent basis. If it were my boat, I'd go about the weight saving in a different way, such as losing pounds off my gut - a cheap and highly effective way to reduce the "as sailed" weight of a boat.
-Greg
19,185
guests, and 1,162
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online22,490 13 hours ago | | |
