| Re: Ullman sails on Nacra F18
[Re: sander]
#91538 12/08/06 06:58 AM 12/08/06 06:58 AM |
Posts: 1,203 uk | You could probably use the mainsail if you changed the halyard lock system/head board. The jib and spinny would be sheeting at the wrong angles I think.
[Re: sander]
#91540 12/08/06 10:25 AM 12/08/06 10:25 AM |
As far as I know the Tiger mast is noticeably stiffer overall then the Nacra masts. Therefor using a Tiger main on the Nacra could make you end up with a mainsail that is far too flat to be competitive. There is not much you can do with tuning to correct that. This is certainly a thing to check.
[Re: Wouter]
#91541 12/08/06 10:36 AM 12/08/06 10:36 AM |
Posts: 126 southern Ontario | While on the topic of F18 sails that are not factory for that platform. Are there many yet who get sails cut by an experienced F18 sailmaker that are cut for a certain mast and even crew weight? I ask because I have a Mystere Twister with original main and jib and eventually with the new full battened jib rule, getting a new set of sails, but not from factory (if they are even still around). We run a new Tiger spin that looks great, but would at some point be looking into a main and jib to stay competative. cheers
Ryan Dart 18 #4860
| | | Hey Wout
[Re: Wouter]
#91542 12/08/06 11:19 AM 12/08/06 11:19 AM |
Posts: 364 | Wouldn't a sail cut for a flexible mast (needing bend to flatten) be too full on a stiff mast, rather than too flat? Agree on the non-competitive assessment.
Andrew Tatton
Nacra 20 "Wiggle Stick" #266
Nacra 18 Square #12
| | | Re: Hey Wout
[Re: Andrew]
#91544 12/08/06 12:14 PM 12/08/06 12:14 PM |
Posts: 9,582 North-West Europe | Andrew, Wouldn't a sail cut for a flexible mast (needing bend to flatten) be too full on a stiff mast, rather than too flat? Agree on the non-competitive assessment.
Sander is considering putting sails made for a Tiger (stiff mast) on to a Nacra (flexible mast), exactly the opposite of what you describe. In effect, your statement is beside the point, irrespectibally of the fact that is it in itself a true statement. Wouter
[Re: sander]
#91545 12/08/06 01:38 PM 12/08/06 01:38 PM |
Joined: Mar 2002 Posts: 984 2017 F18 Americas Site Dan_Delave
Posts: 984 2017 F18 Americas Site | I think the spinnaker luff on the Nacra F18 is a bit longer than that of the Tiger. By about 6 inches. The jib should work okay provided both are from self tacking boats setups. The luff of the mains are withing about 1/2 inch of each other, but you would need to change out the headboard. You can do this if you are not interested in the fastest boat. The masts are very far apart in terms of stiffness. If you are getting all the sails for free and using them for pleasure sailing only I would say okay. If you are a racer I would say nay. Jay and Pease Glaser can make you a sail based on your weight and mast bend. The problem may be determining how to relay the mast stiffness to them. Glaser Sails Later, Dan | | | Re: Hey Wout
[Re: sander]
#91547 12/08/06 04:19 PM 12/08/06 04:19 PM |
Posts: 3,906 Clermont, FL, USA | So I guess that would not be a good idea, good to know.
I believe other sailmakers do make sails for the Nacra F18 (North, Glaser?) has anyone ever compared these to the standard performance sails? Stay away from North, they don't appear to have figured out the shape for beach cats.
[Re: sander]
#91548 12/08/06 08:58 PM 12/08/06 08:58 PM |
Posts: 1,669 Melbourne, Australia | As mentioned before, the luff curve of a Tiger main may not match that of a Nacra mast, however if you realy want to, a sail maker can change this. This does not mean the luff curve of a factory Nacra main will be right for your crew weight as well. Sails are very personal and should me matched up with your mast bend properties, crew weight and race conditions (wind, waves).
As for the jib, if the luff length is close, it will be OK. Jibs have a fair bit of adjustment on the clew boards as sheeting angles change with mast rake.
As for kites, luff length is less important as you can always adjust your pole hight or halyard hight. Sheeting angle is the most important part. Most F18s have a fixed sheeting point which I am not a fan off as mast rake will also effect sheeting angle for kites. If you get a kite that has a different length foot, it will throw out your sheeting angle also.
As for sail makers, most of the reputable sail makers (if you choose not to go factory) know what they need to do ie shape and sheeting angles for the major F18 types and can also make personal changes to them to suit your weight / race conditions. For spinnaker shapes, the size of the fleet also comes into play. For small fleets, you want a kite with plenty of grunt for max VMG, whilst large fleet racing you will want a flatter kite for gaining hight if you need to attack or defend on the downwind. Some good aftermarket sail makes include Pablo from Ullman ITA, and Langy. Norths Brisbane, Australia also make some good kites but still working on their working sails. Gran Segel make great Tornado spinnakers, but don’t know if they have been successful with F18s. | | |
22,041
guests, and 407
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online23,788 57 minutes ago | | |
