| The ultimate beach cat, how light is possible? #91810 12/11/06 07:09 AM 12/11/06 07:09 AM |
Posts: 87 Trondheim, Norway | How light is it possible to build a 20 feet platform that is tough enough to endure hard sailing and tough conditions(texel, worrel etc)? Some will say that the M20 at 120kgs is already pushing the limit, and might have pushed it too far as some M20s have proven to be a bit too fragile in rough conditions. Macca, who by the performance and sheer looks of his upgraded Taipan 5,7 obviously knows what he's doing, recently mentioned in the Super Taipan thread that he thought it was possible to push the weight of a 20 feet long,10 feet beam cat down to 105kgs. I know Wouter disagrees, but what about the rest of you? | | | Re: The ultimate beach cat, how light is possible?
[Re: jimi]
#91814 12/11/06 09:10 AM 12/11/06 09:10 AM |
Posts: 9,582 North-West Europe | How light is it possible to build a 20 feet platform that is tough enough to endure hard sailing and tough conditions(texel, worrel etc)? Some will say that the M20 at 120kgs is already pushing the limit, and might have pushed it too far as some M20s have proven to be a bit too fragile in rough conditions. Macca, who by the performance and sheer looks of his upgraded Taipan 5,7 obviously knows what he's doing, recently mentioned in the Super Taipan thread that he thought it was possible to push the weight of a 20 feet long,10 feet beam cat down to 105kgs. I know Wouter disagrees, but what about the rest of you?
I don't really think it is a question of it can or it can't be done. There is a transition area (grey area) where it dependents on what is considered to be "hard sailing". I'm sure a 20 ft x 10 ft wide platform with a sloop rig can be build at 105 kg. How it holds up under varying condition is a different matter. How it will hold up in the (grulling) Worrell 1000 is yet again a seperated issue alltogether. All I was saying in the other post is that Marstrom for some reason decided to forget about the initial 108 kg M20 and replace it with a 120 kg one instead. Remember this boat also doesn't have a jib setup which does really load up the bows ! I think Stephen has is on the right track and I want to expand on that. Reducing the overall weight of a beach catamran gets harder which each additional kg. Say you take the 140 kg Taipan5.7 (incl 5 kg spi setup). The hulls are already pretty lightweight so not much to be gained there. You want the boat to be significantly wider, this means that the use of carbon in the beams will not result in much weightsavings relative to the 5.7 as you'll need all the material you can get to restore platform stiffness. What is left ? Carbon mast ? 5 kg gains. Lets say you win 10-15 kg by using kevlar in the hulls, carbon mast, carbon beams, boom, pole and some other things. That still leaves you at 125 kg. Cuben fibre sails. Another 3 to 4 kg. Lets say you are down at 120 kg. What is now left to win those additional 15 kg of weight ? ... Not much at all. That is why some builders have decided to loose the jib as then the bows can be build lighter again. However it is still a very long way to 105 kg. Remember that Taipan 5.7 isn't an overbuild boat like the F18's. What we are saying here is that we want to make an additional weight savings of 35 kg when a professional builder like Boyer had to work hard to win the first 40 kg. You must come up with some very smart things to do that. It will definately be engineering challenge. Wouter
[Re: jimi]
#91819 12/11/06 11:39 AM 12/11/06 11:39 AM |
As much as I hate to say the following thing it is true nevertheless. A boat design can be TOO light to perform to its full potential.
I won't go into detail at this time, but suffice to say that the ratio of wetted surface area to bouyance (=overall boat weight) does play a factor, as well the ability to hold some momentum when sailing through choppy seas.
Also the first thing a good engineer needs to learn is that it is very traiterous to extrapolate (approximated) behaviour into extreme points.
But these are all topics for another time.
[Re: jimi]
#91824 12/11/06 01:01 PM 12/11/06 01:01 PM |
Posts: 548 MERRITTISLAND, FL | very traiterous to extrapolate I would hate to try and put this into a translator>>> I believe what Wouter is trying to say is that every feature in a design has to be carefully ballanced to make a boat that can be considered good in more than 1 condition. The MacQuaire Innovation speed sailing boat is pretty fast and light but it only goes 1 way on flat water. Upwind performance must be ballanaced with downwind performance, abilty to sail in flat water has to be compromised for performance in waves or chop, no 1 design will do it all. It is possible to build a boat significantly lighter than what is being typically made up there now. The loads on a boat during sailing are not the only consideration you need to make though. Hnadling a boat on land, on and off a trailer and through non-sailing gyrations such as righting after capsize etc. require quite a bit more structure to make something that will last. A min weight boat designed with consideration to the sailing loads only will most likely look like a golf ball after a few weeks due to heal and other body part contact, and you will probably have gone through a few masts and other rig parts as well. From a practical consideration my opinion is that the current A cat is about as low as you would want to go design wise. Even here you only have a 1 up uni rig platform that you will only rarely see going out in winds over 20 knots, and when violently pitch poled stands a pretty good chance of requiring a new mast. The other trade off I have not mentioned hits on the cost. Lighter is better, but below some already explored limits the advantage is questionable at best. If you realy want to save weight the biggest bang for your effort is still a diet. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Matt | | | Re: The ultimate beach cat, how light is possible?
[Re: Matt M]
#91825 12/11/06 01:06 PM 12/11/06 01:06 PM |
Posts: 3,348 | . . .the biggest bang for your effort is still a diet. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Matt <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" /> | | | Re: The ultimate beach cat, how light is possible?
[Re: fin.]
#91826 12/11/06 02:57 PM 12/11/06 02:57 PM |
Posts: 3,528 Looking for a Job, I got credi... | Had this conversation ages ago one night at the sailing club. I had a sailing mate who worked to Lola (race cars in case you did not know). His comments were that given a big budget you could get down to somewhere around 80 kg. It was really down to cost. Buy the best stuff, cook it properly and you get strong and light. BUT it will cost loads ! How much does a race car cost to build - Lots. Mucho expensive carbon !
He did a fag-packet spec, and he was saying that the problems would be the fittings. We got top the point where we were building custom carbon blocks, carbon eyes for the tramp etc. Got silly, but he suggested 80kg was possible, but expensive !
F16 - GBR 553 - SOLD I also talk sport here | | | Re: The ultimate beach cat, how light is possible?
[Re: scooby_simon]
#91827 12/11/06 02:58 PM 12/11/06 02:58 PM |
Posts: 902 Norman,OK | Wow, 80kg!!! That is a little lighter than my Nacra 5.2, I am sailing a battleship compared to some of the stuff out there.
15,633
guests, and 373
