Taipan Rear Beam Casting #92351
12/16/06 12:22 AM
12/16/06 12:22 AM
Victoria, Oztralia
mattaipan Offline OP
Victoria, Oztralia
Hi All
Does anyone have a picture or diagram of what the inner rear beam casting for the taipan looks like?
I'll try and attach a picture, open for suggestions. Am I on the right track?
Thanks
Re: Taipan Rear Beam Casting [Re: mattaipan] #92352
12/16/06 12:29 AM
12/16/06 12:29 AM
Victoria, Oztralia
Victoria, Oztralia
Hi All
Sorry, attachment didn't work.
What I'm thinking of is a U shape aluminium block, the vertical arms of the U run up the fore/aft edges of the inside of the beam, the bottom of the U supports the head of a cap bolt, a smaller hole is drilled into the top surface of the beam to allow access with a hex key.
I hope that is clear, if not, any pictures or diagrams you may have would be appreciated.
Regards
Re: Taipan Rear Beam Casting [Re: mattaipan] #92353
12/16/06 04:22 AM
12/16/06 04:22 AM
Matt,
It is just a flat square block of aluminium about 8 or 10mm thick.
Re: Taipan Rear Beam Casting [Re: phill] #92354
12/16/06 05:00 AM
12/16/06 05:00 AM
Victoria, Oztralia
Victoria, Oztralia
Thanks Phill
Saved the day again. <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
A few weeks ago, I got a 3.2mm slot cutting router bit, and routed the tramp track with it. Worked beautifully.
I'm bedding the beams in tomorrow, just getting it all set up tonight.
I molded in the centreboards the other day, but didn't get the bog to go the sides as much as at the ends, I don't suppose that will matter to much? I was almost going to file out my first attempt and try again, but I'm probably being a bit fussy.
I bought the paint finally on Wednesday, the Luxepoxy and Luxathane, I was surprised by the price, thought it would be a lot more, so that was a pleasant surprise. <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" />
I've ordered some Carbon diamond arms from CST composites, they have to cut down a bit to length but thought they'd be a bit different, I need to make my own collar to suit the mast.
I've got to find a photo of the proctor setup to see where on the mast they actually hinge from, i.e at the scribeline or at the forward rib.
Anyway won't be long now, launch expected to be the first race back after the new year, only about 6 months later than I would have liked, but stuff happens. <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" />
Regards
Matt
Re: Taipan Rear Beam Casting [Re: mattaipan] #92355
12/16/06 09:15 AM
12/16/06 09:15 AM
Panama City, Florida
Redtwin Offline
Redtwin  Offline
I really envy you guys who can build your own boats.
Please send lots of pics of the first sail.
-Rob V.
Rob V. Nacra 5.2 Panama City
