| Re: wet sanding question
#93140 12/31/06 11:22 AM 12/31/06 11:22 AM |
Posts: 1,121 Eastern NC, USA | Ditto on the NuFinish. Works like a champ.
A couple other questions:
1. Do you guys stick to the same routine (grades of sanding, buffing, polishing) when preparing daggerboards and rudders?
2. On my new boat, I've hand buffed and polished it - but have not done any sanding/heavy duty buffing. The finish seems to be nice. When should one consider a complete makeover? Depends on the wear and tear, I'd assume.
[Re: PTP]
#93141 12/31/06 12:20 PM 12/31/06 12:20 PM |
Posts: 12,310 South Carolina | Jake, what happened to the preferred vertglass? I dunno - I guess I haven't gone that route with the cat simply because I plan on redoing some gelcoat and removing the vertglas can be involved.
Jake Kohl | | | Re: wet sanding question
[Re: tshan]
#93142 01/05/07 03:43 PM 01/05/07 03:43 PM |
Posts: 1,246 Orlando, FL | When one does wet-sanding do you always perform this task by hand sanding? Or use an electric sander until you get to a certain (fine) grade paper?
USA 777
[Re: tback]
#93144 01/05/07 04:09 PM 01/05/07 04:09 PM |
Posts: 1,121 Eastern NC, USA | Hmmmm, sounds like some one is getting ready for Tradewinds. No pulling any of these fancy tricks.....
Tom | | | Re: wet sanding question
[Re: tshan]
#93145 01/05/07 04:54 PM 01/05/07 04:54 PM |
Posts: 1,246 Orlando, FL | Actually, my question was more geared around the thread of SportMax boxes and got me thinking about building a 'glass box (as descibed on that thread.)
As for Tradewinds, I do have some repair to my daggerboards from sailing last week in shallow waters. Seems like I'm building up my daggerboards about every other month.
...but no Tom ... no tricks from me. I'll be busy keeping my mainsail and spi' dry <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> and watching your sailing tactics from far behind.
USA 777
[Re: bvining]
#93146 01/05/07 06:46 PM 01/05/07 06:46 PM |
Posts: 12,310 South Carolina | Actually pneumatic sanders are often employed for wet sanding. However, it really goes so quickly that you don't need the power and you'll find that you need the extra personal control with a simple foam block.
Jake Kohl | | |
2,652
guests, and 166
