Re: wet sanding question [Re: Jake] #93139
12/31/06 09:13 AM
12/31/06 09:13 AM
Jake,
what happened to the preferred vertglass?
Re: wet sanding question [Re: Jake] #93140
12/31/06 11:22 AM
12/31/06 11:22 AM
Eastern NC, USA
tshan Offline
tshan  Offline
Eastern NC, USA
Ditto on the NuFinish. Works like a champ.
A couple other questions:
1. Do you guys stick to the same routine (grades of sanding, buffing, polishing) when preparing daggerboards and rudders?
2. On my new boat, I've hand buffed and polished it - but have not done any sanding/heavy duty buffing. The finish seems to be nice. When should one consider a complete makeover? Depends on the wear and tear, I'd assume.
Re: wet sanding question [Re: PTP] #93141
12/31/06 12:20 PM
12/31/06 12:20 PM
Jake,
I dunno - I guess I haven't gone that route with the cat simply because I plan on redoing some gelcoat and removing the vertglas can be involved.
Re: wet sanding question [Re: tshan] #93142
01/05/07 03:43 PM
01/05/07 03:43 PM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
When one does wet-sanding do you always perform this task by hand sanding? Or use an electric sander until you get to a certain (fine) grade paper?
USA 777
Re: wet sanding question [Re: tback] #93143
01/05/07 04:01 PM
01/05/07 04:01 PM
Atlanta
bvining Offline
bvining  Offline
Atlanta
I wouldnt wet sand with electricity - water plus electricity is bad mojo. I dont know of any waterproof sanders and wouldnt trust them if they did exist. Wet sanding requires you dunking the sandpaper into fresh water to keep the paper fresh, or by running water over the surface you are sanding. Either way, you need more water than would be safe around electricity.
If you asking - Can I dry sand up to a certain grit and then wet sand? Then the answer is yes, that works fine. Keep in mind that wet sanding keeps the paper free from clogging and keeps the paper fresh, so in my experience it actually works quite fast and "feels" like you are removing more material than a comparable grit dry sand.
But whatever you do, dont try to wet sand with an electric sander.
Bill
Re: wet sanding question [Re: tback] #93144
01/05/07 04:09 PM
01/05/07 04:09 PM
Eastern NC, USA
tshan Offline
tshan  Offline
Eastern NC, USA
Hmmmm, sounds like some one is getting ready for Tradewinds. No pulling any of these fancy tricks.....
Re: wet sanding question [Re: tshan] #93145
01/05/07 04:54 PM
01/05/07 04:54 PM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
Actually, my question was more geared around the thread of SportMax boxes and got me thinking about building a 'glass box (as descibed on that thread.)
As for Tradewinds, I do have some repair to my daggerboards from sailing last week in shallow waters. Seems like I'm building up my daggerboards about every other month.
...but no Tom ... no tricks from me. I'll be busy keeping my mainsail and spi' dry <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> and watching your sailing tactics from far behind.
USA 777
Re: wet sanding question [Re: bvining] #93146
01/05/07 06:46 PM
01/05/07 06:46 PM
Actually pneumatic sanders are often employed for wet sanding. However, it really goes so quickly that you don't need the power and you'll find that you need the extra personal control with a simple foam block.
0 registered members (), 21,292 guests, and 415 spiders.
2 hours ago
