Ripped mainsail- Suggestions? #9437
08/13/02 12:25 PM
08/13/02 12:25 PM
Arkansas, USA
Kirt Offline OP
Kirt  Offline OP
Arkansas, USA
Was out practicing the "Wild Thing" over the weekend and got a little too "wild"- Ended up going through the lower panel (window!) of my old Goodall mylar mainsail (and I really love that sail!)- Managed to sail in and all the tears are confined to the lower panel between the reinforced areas (pretty much the window ripped out).
So- as I see it I have three options-
1) Trash the sail- :-(
2) Cut the bottom off and add a new clew grommet and cunningham/downhaul grommet to use as a "super high wind" 4.9 sail or to mess around with on my P 15 or H 14.
3) Have the bottom panel replaced/repaired and keep it as a spare 4.9 mainsail.
Ideas or comments??
Kirt
Kirt Simmons Taipan #159, "A" cat US 48
Re: Ripped mainsail- Suggestions? [Re: Kirt] #9438
08/13/02 02:57 PM
08/13/02 02:57 PM
Netherlands
geert Offline
geert  Offline
Netherlands
Hello Kirt,
I would choose to let it repair, if possible.
A couple of months ago we managed to fall in my kevlar mainsail and had a rip for about 2 meters along the luff, at about 10cm distance from the luff.
It was repaired for about 80$, with and am quite happy with it. You can see it has been repared when you take a good look at it but it doesn't seem to affect the sail's performance.
Geert
Taipan 4.9 Ned 186
Repair it [Re: geert] #9439
08/14/02 02:14 AM
08/14/02 02:14 AM
When I was looking to buy my new mainsail I was a little anxious about the window as I found that part to go most often. The sailmaker currently mkaing my new mainsail assured me that the window can easily be repaired when ripped. So I guess yours can be repaired just the same.
I also have a large window in my sail now.
0 registered members (), 322 guests, and 47 spiders.
