| Scarfing #96203 01/15/07 02:54 AM 01/15/07 02:54 AM |
Posts: 393 Camden NSW | Does anyone in NSW/Sydney know where I can get marine ply scarfed at.
The Person I went to at first has decided to get out of joinery.
Regards William | | | Re: Scarfing
[Re: wildtoy]
#96204 01/15/07 03:09 AM 01/15/07 03:09 AM |
Posts: 461 Victoria, Oztralia | Where your getting the ply from? If not theres sure to be some boatbuilders in Sydney that work with timber. If you've got a router theres a couple of easy ways to do it. Have you googled scarfing, theres heaps of jigs you can make from all different tools, routers, circular saws and by hand of course.
If you get your sheets scarfed by someone else, they'll probably want to join it to, because they prefer not to risk the damage that can happen when moving it from a to b.
Regards
Matt Harper
Homebuilt Taipan 4.9
| | | Re: Scarfing
[Re: mattaipan]
#96205 01/15/07 03:13 AM 01/15/07 03:13 AM |
Posts: 393 Camden NSW | Ive picked up the ply from a place in richmond out west.Ive looked up google and it didnt come up with anything and I wouldnt mind the pple scarfing the wood to join it.
I just dont want to do this part cause I rather get someone with a bit of experience to do it(just in case the boat decides to split while out there <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />) | | | Re: Scarfing
[Re: wildtoy]
#96206 01/15/07 05:09 AM 01/15/07 05:09 AM |
Posts: 21 | the scarf joints in my boat were done at home using a hand plane and cleaned up with a sanding block, using a technique found on the internet, Google - Brian dixon's Easy Plywood scarf bevel cutting technique. use west resin to glue, i sat mine on the floor of the shed with polystyrene under it to stop it getting cold from the concrete. my hulls use a hull doubler that covers the main scarf joint at the main beam, as used in the origina plans and the Ken Lott plans.
| | | Re: Scarfing
[Re: wildtoy]
#96207 01/15/07 05:16 AM 01/15/07 05:16 AM |
Posts: 7 | Scarffings not that bad - we just use a combination of a hand plane and belt/disk sander, and the job is pretty good. You don't need to aim for perfection - the epoxy is going to cope with gaps pretty well. Other builders reckon that a butt joint is ok, but I disagree, and I wouldn't use one on a mozzie, but finger joints aren't too hard to set up (with the right jig) and seem to be getting popular (although that may be down to the prevalance of CNC produce kits). However, I spotted this scarfing jig the other day: http://oneoceankayaks.com/stitchglue/plyshophtm/scarfjig2.htmand was thinking of giving it a shot on the weekend. | | | Re: Scarfing
[Re: Bilby]
#96208 01/15/07 06:13 AM 01/15/07 06:13 AM |
Posts: 461 Victoria, Oztralia | Hi Bilby
I actually made that one, but I didn't really have a decent blade in the saw, and the scraps I used I wasn't happy with, so next time I would buy a new blade, very sharp and I suppose you'd want one with more teeth than less.
In the end, I fixed my router on it sides onto this jig, with the cutter sticking out basically where the saw blade is, I could only do one sheet at a time, and just ran them through like a table saw, it took 15 minutes by the time I plugged the router in, til I had the sheets on the floor to be joined, but I did get an extra pair of hands that were passing by at the time, to help me feed the sheets through.
Regards
Matt Harper
| | | Re: Scarfing
[Re: BiteMe]
#96214 01/17/07 08:10 PM 01/17/07 08:10 PM |
Posts: 393 Camden NSW | hi Steve Talked to little Johnny and he was a bit worried when I told him that I had to stress the wood/joint to make the hull shape. He thinks it wouldnt be strong enough. He gave a number of another person and he reckons an overlapping joint would do the same job and would be alright to stress. Has anyone got any feed back with using an overlapping joint to join hulls. regards william | | | Re: Scarfing
[Re: Rolf_Nilsen]
#96217 01/18/07 04:57 AM 01/18/07 04:57 AM |
Posts: 1,382 Essex, UK | I agree with Rolf here. The thought of doing the joint is worse than actually doing it. It's a relatively simple task to make a strong scarf joint. The key points are:
1. Make sure there is enough 'meat' in the joint. 8:1 is the minimum but go to 10:1 if you can. 2. Ensure that the mating faces are flat and the same angle 3. Ensure that the mating faces are free from dust and debris 4. Use a good quality stiff epoxy, correctly mixed by measuring (I include colloidal silica in the mix). 5. Don't use excessive pressure when joining the pieces so that they creep. Fixing to a bench with some way of gripping/holding the workpiece rather than the joint is good. You can then use light pressure to hold the vjoint closed.
Once done and cured, it's surprising just how much bending a scarf joint can take. On some of my early 2mm and 3mm test pieces it was the ply that failed a distance away from the joint rather than the joint!
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: Scarfing
[Re: greyarea]
#96219 01/19/07 05:50 AM 01/19/07 05:50 AM |
Posts: 393 Camden NSW | Was thinking about using a circular saw to do the scarf cut. Im building the boat for next season so Ive got a good 7-8 months to build it. | | |
16,728
guests, and 1,093
