| Re: Getaway Repairs
[Re: ceweed]
#96363 01/16/07 09:40 AM 01/16/07 09:40 AM |
Posts: 321 Albuquerque NM | Hi folks I'm new to the forum & impressed by what I've seen so far. You, no doubt have not read the "Test" thread have you? <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
[b] Sail Like you have a Pair
| | | Re: Getaway Repairs
[Re: ceweed]
#96364 01/16/07 11:47 AM 01/16/07 11:47 AM |
Posts: 1,252 California | We had a total transom separation of one of the hulls and I'm worried that if I simply repair the pintle cracks of the other hulls the structure holding the pintles may still not be strong enough. There is no way to weld the materials that the Getaway is built from. Transom failure should be reviewed by your dealer and or country's distributor. The hull may have some warranty compensation available depending on age. | | | Re: Getaway Repairs
[Re: Hullflyer1]
#96366 01/17/07 12:02 AM 01/17/07 12:02 AM |
Posts: 9 | Which hull is damaged? I may have a used one, also what is your location? I am in Delray Beach, Fla many thanks for the offer , I'm in Dukhan , appx 100km south of Baharain & accross the water from Saudi. The problem I have is getting the company ( something to do with petroleum & qatar ) to organise collection. last I heard we had hulls awaiting collection from Hobie GB for one of the getaways. its a procedural nightmare <img src="http://www.catsailor.com/forums/images/graemlins/crazy.gif" alt="" /> | | | Re: Getaway Repairs
[Re: mmiller]
#96367 01/17/07 12:16 AM 01/17/07 12:16 AM |
Posts: 9 | We had a total transom separation of one of the hulls and I'm worried that if I simply repair the pintle cracks of the other hulls the structure holding the pintles may still not be strong enough. There is no way to weld the materials that the Getaway is built from. Transom failure should be reviewed by your dealer and or country's distributor. The hull may have some warranty compensation available depending on age. We have had 2 hull replacements held for us , but getting the company to organise collection is proving to be a saga . That leaves us with one getaway with cracks at the pintles . What supports the steelwork behind the pintles ? On the one that separated there seemed to be appx 8mm depth foam but the foam seems friable & not contributing to the strength . | | |
659
guests, and 155
Mod | | Forums26 Topics22,405 Posts267,056 Members8,150 | Most Online2,167 Dec 19th, 2022 | | | |
