Beam bolt question #96439
01/17/07 06:52 PM
01/17/07 06:52 PM
Central California
ejpoulsen Offline OP
Central California
Do you coat your beam bolts with anything in order to prevent seizing or corroding?
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: Beam bolt question [Re: ejpoulsen] #96440
01/17/07 07:33 PM
01/17/07 07:33 PM
white lithium grease here.
Re: Beam bolt question [Re: ejpoulsen] #96441
01/17/07 09:14 PM
01/17/07 09:14 PM
League City, TX
flumpmaster Offline
flumpmaster  Offline
League City, TX
Copper based anti seize grease
Re: Beam bolt question [Re: flumpmaster] #96442
01/18/07 01:12 AM
01/18/07 01:12 AM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
I follow Jake's suggestion.
Re: Beam bolt question [Re: Dan_Delave] #96443
01/18/07 02:17 AM
01/18/07 02:17 AM
Israel
Erez Offline
Erez  Offline
Israel
I use Vaseline
100% Pure Petroleum Jelly
I renew every month
Erez Ben Shoham http://www.cat-sail.co.il
Re: Beam bolt question [Re: flumpmaster] #96444
01/18/07 08:36 AM
01/18/07 08:36 AM
I'll admit to not knowing much about anti-seize greases, but I do know that when we use them on motor shafts in wash down environments, the anti-seize (that we use) tends to wash away and everything seizes up. Any problems with that grease washing away?
Re: Beam bolt question [Re: Erez] #96445
01/18/07 08:47 AM
01/18/07 08:47 AM
41.32 N, 81.35 W
Stuart_Douglas Offline
41.32 N, 81.35 W
...I renew every month
There in, I think, lies the key...don't treat it as a "set it and forget it" thing.
Re: Beam bolt question [Re: ejpoulsen] #96446
01/18/07 10:17 AM
01/18/07 10:17 AM
Houston
carlbohannon Offline
Houston
I have used the
Copper based anti seize grease (NAPA)
Carbon based anti seize grease (NAPA)
Polymer anti seize (marykate?)
DuPont Krytox durable grease (a grease version of McLube with teflon)
Based on personal experience:
Krytox, no problems (longest the bolts were left untouched was 3 years)
Copper based, no stripped threads but bolts are sometimes hard to get out.
Carbon, 1 stripped thread
Polymer 2 stripped threads
FYI (draw your own conclusions)
Kryox is getting very hard to find and expensive (2 oz is $40)
A lifetime supply of NAPA copper based anti seize grease is about $5
The stripped threads were fixed with SS helicoils bedded in krytox.
Re: Beam bolt question [Re: Jake] #96447
01/18/07 10:52 AM
01/18/07 10:52 AM
Michigan, USA
sparky Offline
sparky  Offline
Michigan, USA
The white lithium grease is provided by Nacra when buying a new boat. Like Jake, this is what I have used and never had any problems with it.
Les Gallagher
Re: Beam bolt question [Re: sparky] #96448
01/18/07 10:59 AM
01/18/07 10:59 AM
Probably a dumb question, but just out of curiosity, is there any kind of soap that works for that? I mean if you are someplace where can't get all that high-tech stuff? Vaseline fits that category, too, of course, as already suggested.
Re: Beam bolt question [Re: Mary] #96449
01/18/07 04:51 PM
01/18/07 04:51 PM
South Louisiana, USA
Clayton Offline
Clayton  Offline
Heck, My old TheMightyHobie18 was almost 20 years old and I never had reason to remove the beam bolts. Why do we need to do that again?
Clayton
Re: Beam bolt question [Re: Clayton] #96450
01/18/07 06:59 PM
01/18/07 06:59 PM
I need to do it to my Hobie 17 becasue of leakage. Need to reseat the crossbars. That is probably his reason. Just a winter project I am putting off till I get out of school in March.
Doug
Re: Beam bolt question [Re: carlbohannon] #96451
01/19/07 12:32 AM
01/19/07 12:32 AM
Central California
Central California
Thanks guys.
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: Beam bolt question [Re: Mary] #96452
01/19/07 08:14 AM
01/19/07 08:14 AM
Any soap would definitely wash away. White lithium grease is available at practically any hardware store (Walmart has it too) but if there may be some sort of "homemade remedy", paraffin wax or something similar might do the trick.
Re: Beam bolt question [Re: Jake] #96453
01/19/07 01:05 PM
01/19/07 01:05 PM
Dan_Delave Offline
Dan_Delave  Offline
I was told that the reason that the Lithium Grease works so well has to do with its conductivity. If you have a really good conductor between dissimilar metals they tend not act on each other. Batteries work because of agressive reactions between dissimilar metals, but if the metals get along there will be no reaction. The best way to describe it is that the Lithuim Grease makes the aluminum seem like Stainless steel and the SS seem like alum to each other. There is no (or very little) reaction between similar metals.
Later,
Dan
Re: Beam bolt question [Re: ejpoulsen] #96454
01/19/07 02:41 PM
01/19/07 02:41 PM
Hollister CA, Plano TX
avalondarlyn Offline
Try "phil wood" bottom bracket grease. you can get it a a good bicycle shop. it seems to repel water and dirt. seems to stay put for a while. works better than white or lewmar grease for me. www.philwood.com
Re: Beam bolt question [Re: Dan_Delave] #96455
01/19/07 07:56 PM
01/19/07 07:56 PM
Dunedin Causeway, FL
David Parker Offline
Nice story. However, it would be hard to support any of that with actual science. What is a "similar" metal anyway? Pick up any chem text and read the chapter on electrochemistry. It's an easy read. Fun, actually, if you're a chem nerd like me.
Lithium salts are used for schizophrenia. Perhaps lithium grease makes metals hear fewer voices in their head... <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />
0 registered members (), 21,282 guests, and 1,383 spiders.
Most Online23,137
1 hour ago
