| Beam bolt question #96439 01/17/07 06:52 PM 01/17/07 06:52 PM |
Joined: May 2002 Posts: 1,037 Central California ejpoulsen OP
Posts: 1,037 Central California | Do you coat your beam bolts with anything in order to prevent seizing or corroding?
| | | Re: Beam bolt question
[Re: flumpmaster]
#96444 01/18/07 08:36 AM 01/18/07 08:36 AM |
Posts: 12,310 South Carolina | Copper based anti seize grease I'll admit to not knowing much about anti-seize greases, but I do know that when we use them on motor shafts in wash down environments, the anti-seize (that we use) tends to wash away and everything seizes up. Any problems with that grease washing away?
Jake Kohl | | | Re: Beam bolt question
#96447 01/18/07 10:52 AM 01/18/07 10:52 AM |
Posts: 371 Michigan, USA | The white lithium grease is provided by Nacra when buying a new boat. Like Jake, this is what I have used and never had any problems with it.
Les Gallagher
[Re: sparky]
#96448 01/18/07 10:59 AM 01/18/07 10:59 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Probably a dumb question, but just out of curiosity, is there any kind of soap that works for that? I mean if you are someplace where can't get all that high-tech stuff? Vaseline fits that category, too, of course, as already suggested. | | | Re: Beam bolt question
[Re: Clayton]
#96450 01/18/07 06:59 PM 01/18/07 06:59 PM | Anonymous
| Anonymous
Unregistered | I need to do it to my Hobie 17 becasue of leakage. Need to reseat the crossbars. That is probably his reason. Just a winter project I am putting off till I get out of school in March.
Doug | | | Re: Beam bolt question
[Re: Mary]
#96452 01/19/07 08:14 AM 01/19/07 08:14 AM |
Posts: 12,310 South Carolina | Probably a dumb question, but just out of curiosity, is there any kind of soap that works for that? I mean if you are someplace where can't get all that high-tech stuff? Vaseline fits that category, too, of course, as already suggested. Any soap would definitely wash away. White lithium grease is available at practically any hardware store (Walmart has it too) but if there may be some sort of "homemade remedy", paraffin wax or something similar might do the trick.
[Re: Dan_Delave]
#96455 01/19/07 07:56 PM 01/19/07 07:56 PM |
Joined: Jun 2001 Posts: 890 Dunedin Causeway, FL David Parker
Posts: 890 Dunedin Causeway, FL | There is no (or very little) reaction between similar metals. Nice story. However, it would be hard to support any of that with actual science. What is a "similar" metal anyway? Pick up any chem text and read the chapter on electrochemistry. It's an easy read. Fun, actually, if you're a chem nerd like me. Lithium salts are used for schizophrenia. Perhaps lithium grease makes metals hear fewer voices in their head... <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" /> | | |
22,089
guests, and 499
