Max towing weight 2500 lb? #96608
01/18/07 12:45 PM
01/18/07 12:45 PM
Long Island, NY
Catius Offline OP
Catius  Offline OP
Long Island, NY
I am finally looking to get a hitch on my car installed (Mercedes E320 wagon).
U-Haul tells me that the only hitch they offer is one with 2500 pounds max tow weight. My trailer is steel and the boat is an Mystere 6.0.
Maybe a dumb question, but the offered hitch should be sufficient, right?
Thomas Mystere 6.0
Re: Max towing weight 2500 lb? [Re: Catius] #96609
01/18/07 12:47 PM
01/18/07 12:47 PM
Should be no problem.
Just watch your tongue weight.
Btw, those ratings are determined by lawyers. I once towed a 7000+ flatbed trailer with a small house on top of it with my old trooper's 5000lbs hitch.
(not recommended btw)
Re: Max towing weight 2500 lb? [Re: Catius] #96610
01/18/07 12:48 PM
01/18/07 12:48 PM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
I had to get a galvanized trailer weighed in order to register it last year. The trailer came in at 520 pounds. Unless the Mystere is a REALLY heavy boat, you should be fine with a 2500 lb hitch.
Re: Max towing weight 2500 lb? [Re: ksurfer2] #96611
01/18/07 01:44 PM
01/18/07 01:44 PM
Long Island, NY
Catius Offline OP
Catius  Offline OP
Long Island, NY
I love this forum...
Got an answer to my question in minutes...!
Thanks!
Thomas Mystere 6.0
Re: Max towing weight 2500 lb? [Re: Catius] #96612
01/18/07 01:48 PM
01/18/07 01:48 PM
Likewise, I have an extremely heavy trailer (with ramp for my 150cc scooter, two boxes, 6' extended tongue for clearing the mast behind the RV, etc. My trailer weights about 750lbs and my boat about 400. Throw in one hundred pounds for gear and all and you're still within range.
Re: Max towing weight 2500 lb? [Re: Jake] #96613
01/18/07 03:57 PM
01/18/07 03:57 PM
St. Louis, MO
hobienick Offline
hobienick  Offline
St. Louis, MO
Most of the beachcats on their trailers with gear will weigh in around 1000lbs. You can tow with a Class I (small) hitch just fine. Don't put much more than 100lbs of tounge weight on it though. It will make your car steer poorly if you do.
Nick
Current Boat
Looking for one
Previous Boats
'84 H16
'82 H18 Magnum
'74 Pearson 30
St. Louis, MO
Re: Max towing weight 2500 lb? [Re: hobienick] #96614
01/18/07 04:32 PM
01/18/07 04:32 PM
Atlanta
bvining Offline
bvining  Offline
Atlanta
My A cat plus my Aluminium Trailex trailor is less than most of your boats.
Sorry, I couldnt resist.
Bill
Re: Max towing weight 2500 lb? [Re: bvining] #96615
01/18/07 06:37 PM
01/18/07 06:37 PM
My *NOODLE* don't stink. Top that.
Re: Max towing weight 2500 lb? [Re: MauganN20] #96616
01/18/07 06:39 PM
01/18/07 06:39 PM
South Louisiana, USA
Clayton Offline
Clayton  Offline
Ya' need to use it sometime!!! <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" />
<img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
Re: Max towing weight 2500 lb? [Re: Clayton] #96617
04/02/07 01:18 PM
04/02/07 01:18 PM
Long Island, NY
Catius Offline OP
Catius  Offline OP
Long Island, NY
One more question on this topic. Given that I have a pretty heavy steel trailer and a M6.0 loaded on that, what should be the trailer tire pressure?
Thomas Mystere 6.0
Re: Max towing weight 2500 lb? [Re: Catius] #96618
04/02/07 01:34 PM
04/02/07 01:34 PM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
Depends on the tire. They are all marked on the side with a max rating. Max ratings vary on tires from 35lbs to 80 lbs. A lot of boat trailers tires are rated at a max of 50lbs. I usually keep my tires at around 40lbs on with the max rating at 50lbs.
Mike Hill
www.stlouiscats.com
Re: Max towing weight 2500 lb? [Re: Mike Hill] #96619
04/02/07 02:18 PM
04/02/07 02:18 PM
you mean psi...but yeah, what Mike said. I've got some heavy duty tires to be able to withstand the loads generated by a double-stack and my scooter and they require 80psi. When I just have one boat on the trailer, I drop the pressure down to where I can just see a little deflection in the tire sitting still - usually about 45 lb....er....I mean psi. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
0 registered members (), 5,203 guests, and 552 spiders.
