| Max towing weight 2500 lb? #96608 01/18/07 12:45 PM 01/18/07 12:45 PM |
Joined: Jun 2005 Posts: 149 Long Island, NY Catius OP
Posts: 149 Long Island, NY | I am finally looking to get a hitch on my car installed (Mercedes E320 wagon).
U-Haul tells me that the only hitch they offer is one with 2500 pounds max tow weight. My trailer is steel and the boat is an Mystere 6.0.
Maybe a dumb question, but the offered hitch should be sufficient, right?
Thomas
Mystere 6.0
| | | Re: Max towing weight 2500 lb?
[Re: Catius]
#96610 01/18/07 12:48 PM 01/18/07 12:48 PM |
Posts: 1,152 tampa, fl | I had to get a galvanized trailer weighed in order to register it last year. The trailer came in at 520 pounds. Unless the Mystere is a REALLY heavy boat, you should be fine with a 2500 lb hitch.
If your havin girl problems i feel bad for you son I got 99 problems but my beautiful wife ain't one | | | Re: Max towing weight 2500 lb?
[Re: ksurfer2]
#96611 01/18/07 01:44 PM 01/18/07 01:44 PM |
Posts: 149 Long Island, NY | I love this forum...
Got an answer to my question in minutes...!
Thanks!
Thomas
Mystere 6.0
[Re: Catius]
#96612 01/18/07 01:48 PM 01/18/07 01:48 PM |
Posts: 12,310 South Carolina | Likewise, I have an extremely heavy trailer (with ramp for my 150cc scooter, two boxes, 6' extended tongue for clearing the mast behind the RV, etc. My trailer weights about 750lbs and my boat about 400. Throw in one hundred pounds for gear and all and you're still within range.
Jake Kohl | | | Re: Max towing weight 2500 lb?
#96613 01/18/07 03:57 PM 01/18/07 03:57 PM |
Posts: 306 St. Louis, MO | Most of the beachcats on their trailers with gear will weigh in around 1000lbs. You can tow with a Class I (small) hitch just fine. Don't put much more than 100lbs of tounge weight on it though. It will make your car steer poorly if you do.
Nick
Current Boat Looking for one
[Re: bvining]
#96615 01/18/07 06:37 PM 01/18/07 06:37 PM |
Posts: 3,114 BANNED | My A cat plus my Aluminium Trailex trailor is less than most of your boats.
My *NOODLE* don't stink. Top that. | | | Re: Max towing weight 2500 lb?
[Re: MauganN20]
#96616 01/18/07 06:39 PM 01/18/07 06:39 PM |
Joined: Jun 2001 Posts: 975 South Louisiana, USA Clayton
Posts: 975 South Louisiana, USA | My A cat plus my Aluminium Trailex trailor is less than most of your boats.
My *NOODLE* don't stink. Top that. Ya' need to use it sometime!!! <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" /> | | | Re: Max towing weight 2500 lb?
[Re: Clayton]
#96617 04/02/07 01:18 PM 04/02/07 01:18 PM |
Posts: 149 Long Island, NY | One more question on this topic. Given that I have a pretty heavy steel trailer and a M6.0 loaded on that, what should be the trailer tire pressure?
Thomas
Mystere 6.0
[Re: Catius]
#96618 04/02/07 01:34 PM 04/02/07 01:34 PM |
Posts: 833 St. Louis, MO, | Depends on the tire. They are all marked on the side with a max rating. Max ratings vary on tires from 35lbs to 80 lbs. A lot of boat trailers tires are rated at a max of 50lbs. I usually keep my tires at around 40lbs on with the max rating at 50lbs. Mike Hill www.stlouiscats.com | | | Re: Max towing weight 2500 lb?
[Re: Mike Hill]
#96619 04/02/07 02:18 PM 04/02/07 02:18 PM |
Posts: 12,310 South Carolina | you mean psi...but yeah, what Mike said. I've got some heavy duty tires to be able to withstand the loads generated by a double-stack and my scooter and they require 80psi. When I just have one boat on the trailer, I drop the pressure down to where I can just see a little deflection in the tire sitting still - usually about 45 lb....er....I mean psi. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Jake Kohl | | |
268
guests, and 25
