| Re: Please give your opinion on ... SMOD/ OD / For
[Re: Mary]
#96723 01/22/07 03:39 PM 01/22/07 03:39 PM |
Posts: 1,187 38.912, -95.37 | Wouter, You did not explain why you don't think it makes sense to have two divisions of Formula 12, low-performance and high-performance.
You could concentrate on the high-performance aspect, like your F12 (which might become F12X), and somebody else could concentrate on the low-performance boats for the younger kids.
Your talents are much better suited to the high-performance end of the picture. Maybe I'm misunderstanding the formula concept here. Would it not allow a boat to be built of straight ply sheets and a very simplistic method, and also allow a tortured ply design, as well as a manufacutred boat of frp or twintex or roto-mold plastic? Would it not allow any sail up to a certain maximum size? Isn't the fact that the 3.66m boat may be capable of taking off like a skinned cat, with a 7 year old alone at the stick, be offset by the fact that Mom or G'ma may accompany them until they feel comfortable sailing alone? Or be capable of two small friends/siblings together or alone with a smaller sail? Seems like creating a boat capable of a broader range of payload is the smart thing to do. It's much easier to dumb down performance. If two divisions with age and/or weight limitations are advantageous for the class, can this be accomplished by limiting sail size and leave the hulls alone? Doesn't Laser do this? From the preliminary target of 55kg the weight has increased less than 20 pounds and probably not significantly impacted by another 20" of hull. Besides, wont yours have handles at all four corners, for going up and down the stairs?
[Re: Rolf_Nilsen]
#96727 01/23/07 06:33 AM 01/23/07 06:33 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | All this started in the extremely popular "Youth Recreation Trend" thread on the Open Forum. It was really very exciting, because people were talking about a very simple, inexpensive, lightweight, cartoppable boat, that anybody can build in their garage, to introduce young children (ages 7-12) to catamarans.
And then the idea of a Formula 12 class came up. I assumed this meant the boats in that class would be 12 feet or less.
And then the discussion turned to a design for a specific boat that would be called an F12.
And the next thing you know, it turned out that the specific boat was actually going to be almost 13 feet long and will be as fast as Hobie 16's. And it is going to cost supposedly $3,000 even if you build it yourself? Whoa!
Am I the only one who sees something wrong with this picture?
Doesn't this totally defeat the purpose of starting a Formula 12 class, which was to keep the designs small and simple and light and home-buildable and inexpensive and relatively SLOW for the benefit of kids who have never even been on a sailboat before? And also inspire people to design and build their own boats within the Formula 12 parameters, if they ever happen?
Isn't the Formula 12 for kids supposed to be an alternative to the Optimist Dinghy? THAT is the competition (not the Hobie 16). And, obviously, any cat, no matter how primitive, is going to be faster and more fun than the Opti.
I am retracting my suggestion about a separate division for boats longer than 12 feet. Forget it. What was I thinking?? If there is going to be a Formula 12 class, it should be for boats at maximum 12 feet long, period.
It is pretty obvious, from the existing 12-footers in Australia, that it is possible to build good-performing boats within that length. If somebody wants to build a longer boat that is a lot faster, fine, but it should not be a Formula 12. And a Formula 12 Class should not be formed at all unless it has an upper parameter of 12-feet for length.
This is just my own opinion, of course. <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" /> P.S. If you want to review the Youth Receation Trend thread on the Open Forum, I have brought it back up to the top. | | | Re: Please give your opinion on ... SMOD/ OD / For
[Re: Rolf_Nilsen]
#96731 01/23/07 08:21 AM 01/23/07 08:21 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | What does the name of the beast matter? Getting some of these boats on the water is the important point at this stage. Would you build one of these (at 12 feet) if you got a set of plans and a building description? I will, but not yet, as there is an F-16 brewing there..
To be a bit on-topic. I definately think it should be a formula class, not OD or SMOD. That way homebuilding and affordability will be a possibility wherever the 'class' might decide to go. Exactly! But only if it is a 12-foot formula class. The smaller the boat, the greater the differences are with only small increments in length. 12'10" is a HUGE difference from 12'. No comparison in terms of performance and speed. And, yes, I WILL try to build a boat if Phill is right about his simpler design, He said, The first shape is aimed at bringing people into the sport and if push comes to shove could be built with a knife, screw driver, saw, plane, hammer and tape measure. The magic in this is not in the refined hull shape but the method of construction, time involved and cost. I think this boat will still give the newcomers what they need to get hooked. THIS idea is exciting, at least to me. | | | Re: Please give your opinion on ... SMOD/ OD / For
[Re: Mary]
#96736 01/23/07 01:25 PM 01/23/07 01:25 PM |
Joined: Apr 2002 Posts: 695 Ft. Pierce, Fl. USA Seeker
Posts: 695 Ft. Pierce, Fl. USA | "Okay, here's the agenda: if you are going to have a Formula 12'10" class, then I think it would be appropriate to grandfather in the Hobie Wave, which is only 2 inches longer"
If that is the root of the problem, it would have been helpful if it had been brought up in the beginning of the discussion. The F16 Class "grandfathered" in boats that did not meet the strict criteria, some compromise might have been reached early on concerning this matter.
So if I read between the lines correctly, the disagreement over the 12' Vs the 12'-10" issue was just a ploy to keep the F12 performance level sub par when compared to the Hobie Wave. Insuring it would never be a serious threat to the Wave on the race course… There by protecting the established Wave one design class, and eliminating the threat of a F12 class that could offer a higher performance, less expensive alternative.
Bob | | | Re: Please give your opinion on ... SMOD/ OD / For
[Re: Seeker]
#96737 01/23/07 01:46 PM 01/23/07 01:46 PM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Wow, Bob, I never even thought of all that. Brilliant!
Actually, guys, I was just kidding about the Wave, because it would be ridiculous to have a 13-foot boat in a 12-foot formula class. Almost as ridiculous as a 12'10" boat. | | | Re: Please give your opinion on ... SMOD/ OD / For
[Re: Mary]
#96738 01/23/07 04:22 PM 01/23/07 04:22 PM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | Right.., If it is to be named "Formula 12 Class" then it should be 12' or under. Otherwise, you could simply name it the "Formula 13 Class!" Hmmm! or would that be an unlucky number and destroy the class? <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" /> Or, heck, name it "George" but at least name it something it represents. BY the way, The Wave at 13' with a bowsprit and roller furling Hooter is almost as fast as the H16. Add a trapeze and two kids would have a ball on a very substantial, bullet-proof, and very buoyant craft. Check it out at http://www.catsailor.com/waves/superwave_overall.htmlRick | | | Re: Please give your opinion on ... SMOD/ OD / For
[Re: RickWhite]
#96739 01/23/07 04:44 PM 01/23/07 04:44 PM |
Posts: 4,451 West coast of Norway | I have got an even better idea. Why not go after the F-16 class, with their 16'4" length, or the F-18 with their 18'1" length? Excuse me, but you seem a bit obsessive on the length question. Especially at this rather tender stage. Call it "Project George" and lets move on, or at least use arguments that mean something. There is nothing except some marketing in a name, but arguments like weight, speed, building process etc. really matters. I'll repeat what I see as the primary goal of "the class" targeting 8-14 year olds: cheap, homebuildable, easily transported and FUN FUN FUN. | | | Re: Please give your opinion on ... SMOD/ OD / For
[Re: Rolf_Nilsen]
#96740 01/23/07 05:01 PM 01/23/07 05:01 PM |
Posts: 1,187 38.912, -95.37 | formula 3.9 [color:"red"] F3.9 [/color] [color:"blue"]Formula3.9 [/color] [color:"orange"]f3dot9 [/color]
[Re: Rolf_Nilsen]
#96742 01/23/07 05:29 PM 01/23/07 05:29 PM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | There is nothing except some marketing in a name, but arguments like weight, speed, building process etc. really matters. I'll repeat what I see as the primary goal of "the class" targeting 8-14 year olds:
"cheap, homebuildable, easily transported and FUN FUN FUN." Unfortunately, the focus of a Formula 12 class is something that was never resolved, at least as far as I could tell, and there still seems to be a big division of opinions as to what the target market is and what kind of boat would best serve it. There was a great deal of discussion about it on the Open Forum, but that all stopped when the Formula 12 Forum was opened. So I still feel kind of up in the air as to the goals and purpose of a Formula 12 class. I was envisioning it for ages 7-12. I see Wouter's boat as more for ages 13-18 and adult, as well. I envision a fairly slow, cute boat that tacks well. Wouter's boat is designed for much higher performance and has a very high-tech look. Having a large rig and a small rig is fine, but I still think it is too much boat for the little kids. I want something that I can build very inexpensively and have fully rigged for $900 or less. Wouter's boat, even home-built, he said will be at least $3,000, which is way out of my price range. I want something that is so easy to build that even I can do it. Wouter's boat looks too difficult for me to tackle. I would like to see something that could be an alternative to the Opti in club programs. Wouter's boat looks to me like it would be an alternative to the Laser in club programs. I guess one of the problems, too, is that there don't seem to be any mothers with young children on this forum to give some perspective on what they would want for their children. In terms of the young children, what the mothers will go for is really the key to the whole thing. In terms of the age range I see for Wouter's boat, the kids themselves are going to have more of a say in what they would like. | | |
20,780
guests, and 1,475
