| Why don't we use bigger kites? #97000 01/22/07 05:01 AM 01/22/07 05:01 AM |
Posts: 465 Oxford, UK | Just been watching some of the 18' skiff footage on http://www.sailcam.tv/video_flash.php?vid=188 and it's left me wondering why we don't use bigger kite cats? In the half-boat world, mast-top kites are common place, but seemingly not for cats. Obviously you'd have to come up with a way of keeping the mast in one piece, but the monos seem to manage it. My first response is that the kite on the F18s/F16s I've sailed is quite big enough, thank you. But wouldn't a bigger sail just allow you to go deeper at the same speed? Paul | | | Re: Why don't we use bigger kites?
[Re: pdwarren]
#97002 01/22/07 08:06 AM 01/22/07 08:06 AM |
Posts: 12,310 South Carolina | Just been watching some of the 18' skiff footage on http://www.sailcam.tv/video_flash.php?vid=188 and it's left me wondering why we don't use bigger kite cats? In the half-boat world, mast-top kites are common place, but seemingly not for cats. Obviously you'd have to come up with a way of keeping the mast in one piece, but the monos seem to manage it. My first response is that the kite on the F18s/F16s I've sailed is quite big enough, thank you. But wouldn't a bigger sail just allow you to go deeper at the same speed? Paul Some of the big ARC cats do have masthead kites but also have baby stays that run from the mast tip to the ends of the rear beam. If you remember back to the early days of catamaran spinnakers, they were big and full and have been evolving rather quickly into the flat and smaller shapes that we have now. I wouldn't be opposed to seeing some sort of masthead rig come out for development, but I think we might find that our existing setup is pretty optimized. I believe the answer will lie in the same reason we don't run masthead genoa's upwind (except for a few who do so in very light conditions).
Jake Kohl | | | Re: Why don't we use bigger kites?
#97003 01/22/07 12:06 PM 01/22/07 12:06 PM |
Posts: 6,049 Sebring, Florida. | I'm guessing it has to do with apparent wind direction? Allthough the 18' skiffs are very fast, I don't know what their angles are. I know that even when we go downwind fast on a Cat, our apparent wind is well forward in a good blow, not light air. Rick has made the case for hooters instead of spins for cats and the Volvo 40's are also using hooters instead of spins. I don't know why we don't see those on the 18' skiffs though.
Blade F16 #777
[Re: I20RI]
#97006 01/22/07 12:47 PM 01/22/07 12:47 PM |
Posts: 465 Oxford, UK | The wide platform of a cat allows for an open "slot" between the genneher and the mainsail. This accelerates the wind over the back of the mainsail and creates more lift. A mono simply is not wide enough to properly lead a headsail in order to achieve this effect. 18' skiff is wider than your average cat, if I remember right. Not sure whether they're allowed to sheet to the racks, though. Paul | | | Re: Why don't we use bigger kites?
[Re: Timbo]
#97007 01/22/07 12:51 PM 01/22/07 12:51 PM |
Posts: 465 Oxford, UK | I'm guessing it has to do with apparent wind direction? Allthough the 18' skiffs are very fast, I don't know what their angles are. I think they're not too different from asymmetric cats. Certainly the apparent wind is going to be well forward at those speeds. Rick has made the case for hooters instead of spins for cats and the Volvo 40's are also using hooters instead of spins. I don't know why we don't see those on the 18' skiffs though.
What's the different between a hooter and an asymmetric spin? Is a hooter just flatter, or is there more to it than that? Paul | | | Re: Why don't we use bigger kites?
[Re: I20RI]
#97008 01/22/07 01:43 PM 01/22/07 01:43 PM |
Posts: 12,310 South Carolina | The wide platform of a cat allows for an open "slot" between the genneher and the mainsail. This accelerates the wind over the back of the mainsail and creates more lift. A mono simply is not wide enough to properly lead a headsail in order to achieve this effect. If this was true, certainly they would come up with poles to move their sheeting points further out (like a jib pole on a monoslug). In my opinion, I think it's more relative to the balance point between available righting moment, overall weight, and sail area to make the best VMG downwind. Cats have a lot of righting moment and can handle hot angles downwind. As such, our sails are optimized for these hot angles. Skiffs have a little less righting leverage so they run fuller bigger kites.
[Re: I20RI]
#97011 01/22/07 10:08 PM 01/22/07 10:08 PM |
Joined: Jun 2001 Posts: 733 Home is where the harness is..... Will_R
Posts: 733 Home is where the harness is..... | The wide platform of a cat allows for an open "slot" between the genneher and the mainsail. This accelerates the wind over the back of the mainsail and creates more lift. Not true, it's been shown that head sails actually do NOT increase the WS in the slot, they actually decrease it. What they do however, is keep the flow attached to the lee side of the main longer/more consistently which improves it's efficiency and therefore it's performance. | | |
356
guests, and 56
