| Re: Sharp Bows
[Re: grob]
#9709 08/20/02 05:38 PM 08/20/02 05:38 PM |
Posts: 96 Racine, Wisconsin | Are they talking about a FINE ENTRY? I am no expert on this, but the leading edge on my previous Hobie 20 hulls compared to my current Nacra 6.0 NA hulls were not appreciably "sharper". However, the battleship bows of my 6.0 are narrower, more vertical and much quieter thru the water.
Paul Scott Bartelt
2001 NACRA 6.0 NA #546
| | | Re: hull fineness ratio
[Re: Will_R]
#9711 08/21/02 08:59 AM 08/21/02 08:59 AM |
Posts: 12,310 South Carolina | One more thing to keep in mind is the Bow wave effect (that Will hinted too). This effect basically means that as the boat pushes through the water, it causes a wave in front of it (i.e. the bow wave). It takes a lot of power to push through this bow wave or you have to have a planning hull to ride up on top of it in order to ever move faster than this wave. HOWEVER, once the hull length to width ratio exeeds roughly 11 (for example 11' long and 1' wide), the bow wave effect is no longer in play because the boat can slice through the wave instead of having to power over it. This has a lot to do with the additional speed potential for cats and tris.
Jake Kohl | | | Re: "ideal airfoil shape vs hydrofoil shape"
#9712 08/21/02 12:09 PM 08/21/02 12:09 PM |
Joined: Jun 2001 Posts: 292 Long Island, NY Ed Norris
Posts: 292 Long Island, NY | You seem to be asking why a hydrofoil is not penalized by nature for a fine entry, where an airfoil is most efficient with a blunter one.
I believe (corrections welcome) that the shape of an airfoil is designed to avoid turbulence, most often the product of the airstream 'detaching' from the airfoil. Naturally airfoils differ in purpose and so in design, but for a given foil, the 'goal' is to 'hide' as much of your cross section in your given length without inducing turbulence.Detachment is hardest to prevent at the exit, or low-pressure end. So, for maximum efficiency, you put the thickest cross section forward of the center, providing a finer exit than your entry.
Now, air is compressible, which gives you lots of freedom to make the entry blunter than if air weren't compressible - the "bow shock" or bow wave mentioned above is more forgiving in a compressible medium. The "quicker" you get to max cross section without creating turbulance, the finer your exit cdan be. Hence, the more draft you can put in the given length, or the more efficiently you can get your target draft through the air w/out turbulence. So you go as blunt as you can get away with without inducing turbulence.
H2O isn't compressible, at the kinds of forces in play at the surface of the ocean, anyway. So you have less freedom to do a blunt entry, and correspondingly more reward for a fine entry. All the factors about exit and detatchment still apply, you just don't have the freedom to go as blunt in water.
Hope this helps!
Sail Fast,
Ed Norris
[Re: grob]
#9716 08/21/02 03:37 PM 08/21/02 03:37 PM |
Posts: 12,310 South Carolina | it has a lot to do with stability of the foil too - not just efficiency. Think how unforgiving a sharp/thin nosed foil would be to changes in direction.
Jake Kohl | | | Two things
[Re: Will_R]
#9720 08/22/02 03:35 AM 08/22/02 03:35 AM |
Guys please make a distinction between a sharp leading edge and a fine entry or, less-correctly, a sharp bow.
These two things are independent of eachother a blunt bow can still have a sharp leading edge which according to that book can be draggy and a sharp bow can still have a blunt leading edge.
I think the thread started with a question regarding the talk of sharp bows. Like the change from the plumb Inter 18 to the fine entry bow of the Nacra F18. The last is a better cutter and performs better in chop. It also is intended to create a smaller bow wave. The first makes the boat less sensitive to weight placing and helps to reduce pitchpole tendency in the first stages of a dive. The fine entry also caused less rocking of the boat in waves; also indentified by confusion describtion of "wave piercing" bow.
With regard to leading edges to comments about too blunt or to sharp are correct although a hull is nowhere near to a NACA shape and will behave differently as a result.
| | | Re: Two things
[Re: Wouter]
#9721 08/22/02 04:10 AM 08/22/02 04:10 AM |
Posts: 1,449 | I've only skimmed through the post so maybe I've missed something. The way I see it you can't really compare a bow shape with a foil shape because the objectives are different.
The foils main aim in life is to generate lift and with lift comes drag. Obviously the lower the drag the better but if it generates lift it also generates drag,
The bow is not trying to provide lift and if the designer is on the ball among other objectives he'll look at minimising minimise drag.
| | | Re: Two things
[Re: Wouter]
#9722 08/22/02 04:49 AM 08/22/02 04:49 AM |
Posts: 545 Brighton, UK | Just to clarify, the reason I am asking the question is that I am building a folding Multihull, and I am using a hull design which is a NACA shape. (65012) I am intending for the hull to contribute to the lift and so perhaps not need a keel at all. see www.fourhulls.comI am not sure I understand the difference between fine entry and sharp leading edge, am I right in saying a fine entry is a shape with the thickest part of the section further back. | | | Not entirely correct
[Re: Jim Williams]
#9724 08/23/02 05:00 AM 08/23/02 05:00 AM |
The bulb that you are refering to works for different reasons.
The bulb that is underwater creates a counterwave system that is the inverse of the wavesystem that would be caused by the shipshull is the bulb wasn't there. And these two wavesystems that are the inverse (reciprokal) of eachother cancel one another out. Therefor the wave system that is left is much reduces in magnitude and accounts for much less drag.
Also anything that is less tahn say 5 mtr. below the surface doesn't behave as if it were really submerged like a submeraine. The surface is just to near and water and the surface will be disturbed.
And the bulb you see on navy ships near the bow is the sonar housing.
Can these bulbs be used on sailboats ? Yes, but it will only be effective at a certain speed. This is ofcourse no problem for motor ships with a cruise speed but sailboats typcially sail at different speeds depending on the windconditions. Therefor is unlikely that such a bulb is of real interest to sailboat designers. A better solution (compromise) is to have a fine wedge as a bow and less displacement.hence the trend towards sharp bowed monohulls and catamarans.
2,496
guests, and 620
