| Re: any updates on new 20 ft cat designs -classes
[Re: Aerynt]
#97961 09/02/07 12:37 AM 09/02/07 12:37 AM |
Posts: 902 Norman,OK | That is pretty cool looking, but I just want to ask, it looks like you have a daggerboard/centerboard coming from the center of the boat. Would the structure for that not add alot of weight that could be eliminated by just using regeular dagger boards which it looks like the boat has?
Like I said that is a really cool boat and I am definently not an expert, but those are my thoughts.
[Re: Rolf_Nilsen]
#97963 09/02/07 04:39 AM 09/02/07 04:39 AM |
Posts: 43 NZ | Gree, normally I'd agree with you about the structure and weight, but because of where the mast is (and associated loads)I don't think much as added to accommodate the centerboard. I saw the results of an ansys FEA of the beam/pod arrangement and the largest loads are at the mast step and that area hardly deflects at all, the board loads are minor compared to them. The center location has more to do with the banana boards than anything else and they might be removed soon anyways, they were added as a sort of insurance policy that I don't think is necessary after watching a bunch of LR2 videos. As that boat goes up and down hill and you watch the horizon, the top of the mast is always going forward, the boat just never pitches, even down hill in 12-15 knots and with 8 knot gusts and the crew sitting against the main beam, the bow never goes in more than 40-50mm. Not sure how they do it, but its like watching a train on rails.
Rolf, think I addressed the banana boards above, the 2 snuffers are for the 2 reachers, last I heard the wind can change strength during a race. The centerpod only goes back to the wingmast step, aft of that is a plug in compression tube and forward the prod plugs in also, whats not shown is a small inverted "v" striker under the mast step that is tied to the prod under the forestay and to the bottom of the rear beam. Weights and sail areas are in my first post above, think that the top of the mast is about 10.4m off the water and as I was told, total hull volume is irrelevant to most everything. As for expensive, it already is expensive and I haven't started to build it yet. Aerynt | | | Re: any updates on new 20 ft cat designs -classes
[Re: Aerynt]
#97965 09/02/07 08:54 AM 09/02/07 08:54 AM |
Posts: 902 Norman,OK | Well, I have already read a few people dogging on your design in the general forum, don't listen to them. That thing looks badass, I am sure that if it is well built it will go like hell!
[Re: gree2056]
#97966 09/03/07 02:45 PM 09/03/07 02:45 PM |
Posts: 1,203 uk | Has this one been introduced to the forum yet? http://www.tek-kat.co.uk/gallery.html Its pretty scary to see a cat without a bridle supporting the forestay. The 1st boat is out sailing and looking good at times.
[Re: Carl]
#97967 09/04/07 04:11 PM 09/04/07 04:11 PM |
Posts: 5,590 Naples, FL | Why not foils?
Too much work or too much stuff to break?
Easier/cheaper to develop planing hull?
Is a wave piercing hull better for a 20 ft. design than the standard shape for coastal use?
[Re: Aerynt]
#97968 09/05/07 09:48 AM 09/05/07 09:48 AM |
Posts: 833 St. Louis, MO, | Looks very cool.
At a glance the center of effort for your main and jib look too far aft. Unless you are planning on some type of hooter setup for upwind in addition to the main and jib. Still think when it gets windy and the hooter comes down the helm would be very unbalanced.
Good luck with your project!!!
Mike Hill
Mike Hill N20 #1005
[Re: Aerynt]
#97973 09/12/07 04:36 AM 09/12/07 04:36 AM |
Posts: 9,582 North-West Europe | if you want to learn more then I suggest you do what I did and write a cheque.
Is that what these catsailor forum postings are all about ? Basically we have only seen flat water pictures/video's in what may well have been very stable wind conditions. An old seaman once told me :"On calm seas, every vessel claims mastery of floatation" It will take a whole lot more to proof the concept. Wouter
1 registered members (vasil),
386
guests, and 25
