need help to fix #99103
02/17/07 12:06 AM
02/17/07 12:06 AM
Adelaide South Australia
ratherbsailing Offline OP
We have just sold our f18 and picked up this timber taipan but it has a few problems can the brains trust please help with ideas on fixing these problems. thanks in advance.
1 gudgen plate has pushed through transom who ever built only used 1 peice of 4mm ply as transom with no stregthening.
2 has been run into and caused crack.
3 has old centre casings witch are aprox 2 inches bigger(longer) than they need to be would like to block them to make shorter.
hope you can help
Re: need help to fix [Re: ratherbsailing] #99104
02/17/07 12:06 AM
02/17/07 12:06 AM
more photos
Re: need help to fix [Re: ratherbsailing] #99105
02/17/07 12:10 AM
02/17/07 12:10 AM
side of hull sorry first one is fuzzy
Re: need help to fix [Re: ratherbsailing] #99106
02/17/07 05:09 AM
02/17/07 05:09 AM
Thailand
Buccaneer Offline
Buccaneer  Offline
Thailand
The gudgeon plate repair is easy just go thru the inspection port. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> That crack looks more difficult where exactly is it located anyway?
Re: need help to fix [Re: Buccaneer] #99107
02/17/07 05:27 AM
02/17/07 05:27 AM
Victoria, Oztralia
mattaipan Offline
mattaipan  Offline
Victoria, Oztralia
The transom according to the taipan plans, has a piece of hardwood 65mm wide x 6mm thick runnung top to bottom, when I put mine in, I glued and put a layer of glass over the whole lot.
The crack in the hull looks like a bit more work, as said previously, where abouts is it?
Centreboards according to oz class rules;
Aft edge of centreboard 3615mm - 3635mm (from bow datum point) when fitted to the hull.
Regards
Re: need help to fix [Re: mattaipan] #99108
02/17/07 10:46 PM
02/17/07 10:46 PM
Thanks for the ideas will glue and glass peice of ceder onto transom fill and redrill. As for crack in the side a friend who is a boat builder is going to fix thanks for all your help.
0 registered members (), 442 guests, and 40 spiders.
