Downhaul Ratio with Mylar Sails #99245
02/19/07 05:30 AM
02/19/07 05:30 AM
Peter_Foulsum Offline OP
After persevering with the old 6:1 ratio on my relatively new mylar sail and seeing a club rival become immediately more competitive with an 8:1 ratio with an old dacron sail I thought I'd bite the bullet and try it out. Thanks to Gary Maskiel for indicating that I should use at least 8:1 with a mylar mainsail. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
So far I haven't been any slower but conditions haven't been ideal with it either being too windy and breaking a chainplate <img src="http://www.catsailor.com/forums/images/graemlins/crazy.gif" alt="" />(see VMCA website) or too light with 270 degree windshifts and drifting in doldrums. Also setup problems with not removing some old blocks and restricted downhaul block to block <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" />
Has anybody else had similar experiences ? I'm keen to get some feedback.
Peter
Mosquito 1814
Macka Mozzie
Re: Downhaul Ratio with Mylar Sails [Re: Peter_Foulsum] #99246
02/19/07 05:19 PM
02/19/07 05:19 PM
Port Noarlunga, SA, Australia
Darryn Offline
Darryn  Offline
I run 8:1, a cascade system, 4:1 driving a 2:1. Most importantly it must release fully so the system friction cannot restrict the sail from bagging up. Using good blocks and small diameter rope will make the rope run better through the blocks. Makes a lot of difference on my current sail with kevlar tapes holding it together and worked to a lesser extent on my old mylar sail though it would stay a little bit stretched after the first downhaul application. Dacron would be like stretching a piece of spaghetti.
Adjustability while trapezing at full stretch saves leaning in and guesstimating downhaul settings and allows the downhaul to be tweaked rather then dropping mainsheet in gusts.
Darryn
1704
Re: Downhaul Ratio with Mylar Sails [Re: Darryn] #99247
02/20/07 06:01 AM
02/20/07 06:01 AM
Darryn,
Thanks for he feedback. Do you have any images or diagrams of the setup ? I'm a little confused imagining how it all goes together. <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" /> Also what diameter rope do you use; 5mm or 6mm or something smaller ?
Peter <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />
Mosquito 1814
Macka Mozzie
Re: Downhaul Ratio with Mylar Sails [Re: Peter_Foulsum] #99248
02/20/07 05:07 PM
02/20/07 05:07 PM
Darryn Offline
Darryn  Offline
I will get a picture for you Peter, ropes sizes are 3mm dyneema for 2:1 and 5mm for 4:1.
Darryn
Re: Downhaul Ratio with Mylar Sails [Re: Peter_Foulsum] #99249
02/20/07 05:17 PM
02/20/07 05:17 PM
East Gippsland, Australia
Tim_Mozzie Offline
Tim_Mozzie  Offline
Peter
Have a look at this page on the F16 forum:
Blade F16 cascaded downhaul
There are drawings and explanation of how the 8:1 and 12:1 cascaded systems are set up on the blade.
I used to have an 8:1 internal system which I could also make 12:1 but these days I've just gone back to a simple 6:1 setup which gives me all the purchase I need with a lot less rope lying around the place. It may be that I only need 6:1 because I'm using a very flexible mast.
Tim Shepperd
Mosquito 1775
Karma Cat
Re: Downhaul Ratio with Mylar Sails [Re: Tim_Mozzie] #99250
02/20/07 06:38 PM
02/20/07 06:38 PM
Darryn Offline
Darryn  Offline
I am using very similar setup to 8:1 referred to but have replaced centre pulley on 2:1 with a hook which I can detach from mast. I only need a small amount of downhaul travel to go from Max to Nil so my 2:1 ropes are short, I would not be able to attach pulley to sail if 2:1 rope was captive. A picture will explain it better.
Darryn
Re: Downhaul Ratio with Mylar Sails [Re: Darryn] #99251
02/22/07 07:31 AM
02/22/07 07:31 AM
Darryn/Tim,
Thanks heaps for the info. It all makes sense.
I'll jury rig something together and try it out this weekend. <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Peter
Mosquito 1814
Macka Mozzie
Re: Downhaul Ratio with Mylar Sails [Re: Tim_Mozzie] #99252
02/25/07 05:19 AM
02/25/07 05:19 AM
Tim,
I tried the 8:1 jury rig set up but found that the pulleys on the rope ends got caught on things like the spanner mounting or got too close to the diamond wires. <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" /> Also found that I needed too much rope to feed onto the upper section just to reach around the path then tie off onto the end pulley.
Once I go the downhaul working the rope could be shortened significantly. Maybe I had the upper rope section too long.
I reverted to my normal setup (non cascade) with a bit of concentration in putting the ropes through the right pulleys and found a marked improvement in performance. I even had the leaders in sight for the whole race. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Will try it again next week.
Peter
Mosquito 1814
Macka Mozzie
Re: Downhaul Ratio with Mylar Sails [Re: Peter_Foulsum] #99253
02/25/07 04:42 PM
02/25/07 04:42 PM
Darryn Offline
Darryn  Offline
Hi Peter, it takes a bit of stuffing round to get the 2:1 ropes lengths correct, you need to measure how much downhaul travel required then double it and find a spot on your mast that has that much clear space for the pulleys on the tail of the 2:1 to travel. Sounds confusing doesn't it?
I have attached a photo I took in my shed, I was waiting for a rigged up pic but didn't sail on the weekend.
Darryn
Re: Downhaul Ratio with Mylar Sails [Re: Darryn] #99254
03/05/07 05:32 AM
03/05/07 05:32 AM
Darryn,
I've given up on the cascading system and am finetuning the standard setup. <img src="http://www.catsailor.com/forums/images/graemlins/crazy.gif" alt="" /> My cleating blocks are at the front of the mast so the cascading blocks were just fouling on everything. Maybe if I use the front blocks for an outhaul system and put new cleating blocks at the rear then I might have a chance. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
In the interim I noticed that when I used the downhaul the double blocks at the top tended to slip (they are mounted on a loop through the eyelet). I've since made the loop as short as possible so that I don't loose any downhaul purchase. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Maybe that will give me that little bit more. We'll see how it works at the state titles. <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
Peter
Mosquito 1814
Macka Mozzie
Re: Downhaul Ratio with Mylar Sails [Re: Peter_Foulsum] #99255
05/11/07 12:31 AM
05/11/07 12:31 AM
Lake Bonney, SA
dkd Offline
dkd  Offline
Lake Bonney, SA
Peter,
This is what the arrangement we use for our masts looks like. This one was the protype and has now seen 3 seasons without being looked at, which I think is not a bad run from a downhaul system. The newer ones look the same externally but with small improvements internally....running 6 to 1 internally with an external doubler giving a total of 12:1 downhaul...and it works well.
trying to attach pic...
Re: Downhaul Ratio with Mylar Sails [Re: dkd] #99256
05/13/07 06:09 AM
05/13/07 06:09 AM
dkd,
Thanks for the image. 12:1 certainly would give heaps of downhaul purchase. How much stretch do you get with the 12:1 setup before you have to really fight with the downhaul sheet ? The only problem would be if you turtled the Mozzie and ended up with a mast full of salt water. How does the mast step attach to the base plate ? It certainly looks like a very clean setup.
Is that a mast rotation spanner at the bottom of the mast ?
Do you have any other images you can post with the complete setup ?
Peter
Mosquito 1814
Macka Mozzie
Re: Downhaul Ratio with Mylar Sails [Re: Peter_Foulsum] #99257
05/13/07 09:32 PM
05/13/07 09:32 PM
Lake Bonney, SA
dkd Offline
dkd  Offline
Lake Bonney, SA
Peter,
Stretch???....you referring to rope stretch, that depends on brand of rope used but we are getting nil from the stuff we use. It has enough purchase that my youngest's crew can haul it down to the black band with not too much problem.
Water getting into the mast...well if you have got it into a position where it can enter, I think you would have other problems too, it is only open at the very base where the exit blocks are.
Yes the mast sits on the bottom assembly, so the step and plate are one unit.
Yes again, that it the mast rotation spanner, located anywhere else it fouls the blocks and lines that are internal, and we like it low and running back off of the centre beam, not off of the boom like some other set ups.
I will get some other pics and email them directly to you unless there are others interested.....might do both.
Food for thought and another option.
David
Re: Downhaul Ratio with Mylar Sails [Re: dkd] #99258
05/14/07 08:15 AM
05/14/07 08:15 AM
David,
Sorry for my bad wording. <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" /> I meant the extent of downhaul measured at the mast/tack. You sort of answered the question anyway because you can only go to the black band. I suppose it would be good to know how much movement you get from the no downhaul position to the black band position.
As for running the downhaul inside the mast my personal preference is to run it on the outside and keep the mast sealed. I've seen a couple of instances where enthusiastic helpers have de-rigged a Mozzie and pulled the internal downhaul rope out of the mast resulting in removal and replacement of the mast base prior to the next race. <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" />
Looks like another thread is about to start regarding base mounted mast spanners. <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
How do you mount the spanner inside the mast ? Is it rigid or is it free to move vertically. ? Is it resting on the saddle in the image ? Where do you run the adjustment lines from the centre beam ? Do they run out to the sides or do you just use a swivel and cleat off the beam ? More images please.
Peter
Mosquito 1814
Macka Mozzie
Re: Downhaul Ratio with Mylar Sails [Re: Peter_Foulsum] #99259
05/15/07 01:52 AM
05/15/07 01:52 AM
Lake Bonney, SA
dkd Offline
dkd  Offline
Lake Bonney, SA
Peter,
Enthusiastic helpers,,,hmmm...we have not had a problem but guess that is always a chance of it happening. Guess that is an education thing, but not hard to stop....lots of rope to pull before it goes inside anyway.
The spanner is fixed...can't move in any direction and is sleeved into the mast base....we have found it works for us, and is probably a "throw back" to the A class, again.
Everything leads to the sides of the boat, mast rotation, down haul etc...and both crews are happy with it, after all it is their bits of string.
The saddle is the bottom of youngest's boom vang....still not convinced that it is needed but we have been moving it around to find a simple but easy fixing point.
Will get you pics when boats go back together, winter maintenance and all that, along with 2 new masts coming and other new bits for the other one.....bring on next season...it will be fun
David
0 registered members (), 1,023 guests, and 41 spiders.
