New mast plug #99334
02/19/07 11:30 PM
02/19/07 11:30 PM
Central California
ejpoulsen Offline OP
Central California
After getting water in my mast yet again, I decided to redo the mast plug...with style...
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: New mast plug [Re: ejpoulsen] #99335
02/20/07 01:16 AM
02/20/07 01:16 AM
Thats very cool and original!
Re: New mast plug [Re: ejpoulsen] #99336
02/20/07 02:01 AM
02/20/07 02:01 AM
Mark P Offline
Mark P  Offline
Nice job, very pretty. Paul take note, less tape more clear silicone.
MP*MULTIHULLS
Re: New mast plug [Re: ejpoulsen] #99337
02/20/07 03:48 AM
02/20/07 03:48 AM
Are you sure that the top of the mast is leaking and not the upper diamond T-terminal tangs holes ?
Re: New mast plug [Re: ejpoulsen] #99338
02/20/07 05:51 AM
02/20/07 05:51 AM
Oxford, UK
pdwarren Offline
pdwarren  Offline
Oxford, UK
Now that's smart. How did you do it?
Re: New mast plug [Re: Wouter] #99339
02/20/07 02:43 PM
02/20/07 02:43 PM
Central California
Central California
Only the tip of the mast was in the water--not even close to the diamonds where they enter the mast; also, when I took my mast down, John D (Blade sailor in SoCal) noticed water dripping out of the top.
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: New mast plug [Re: pdwarren] #99340
02/20/07 02:45 PM
02/20/07 02:45 PM
Central California
Central California
I just printed out the logo, trimmed it and glued it to the foam before covering with silicone.
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: New mast plug [Re: ejpoulsen] #99341
02/20/07 10:29 PM
02/20/07 10:29 PM
Orange County, CA, USA
JJD Offline
JJD  Offline
Nice repair Eric, and thanks for the demonstration of how to get and keep an F16 moving. This weekend SCYA series was a good learning experience for me. Sailed the Blade in 15-20kts wind, capsized, got it back up without assistance (except for the wind), and learned what the spinnaker pole does when subjected to a sudden heavy download. The download was caused when I stepped off the bow into much deeper water than I thought and grabbed the pole for support. <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" /> At least the racing was over for the weekend when it happened. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: New mast plug [Re: JJD] #99342
02/20/07 11:18 PM
02/20/07 11:18 PM
Central California
Central California
JJD,
Great sailing with you--great venue and facility; a little weird sailing with the Tempests, though. Look forward to our next sail.
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: New mast plug [Re: JJD] #99343
02/21/07 09:16 AM
02/21/07 09:16 AM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
I take it you bent or snapped the spi' pole?
USA 777
Re: New mast plug [Re: tback] #99344
02/22/07 11:05 AM
02/22/07 11:05 AM
JJD Offline
JJD  Offline
Snapped it.
I'm digging around locally to see what I can come up with as a suitable replacement. Supplied Blade spinnker pole is 1.5" OD X .065 Wall Al tubing.
Re-posting previous thread on tubing [Re: JJD] #99345
02/22/07 11:25 AM
02/22/07 11:25 AM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
Here is a previous post talking about various aluminum tubing for beams, booms and poles.
F16 Thread on tubing
USA 777
Re: Re-posting previous thread on tubing [Re: tback] #99346
02/22/07 12:34 PM
02/22/07 12:34 PM
How about using a Windsurfer mast, or does it have to be aluminium?
Re: New mast plug [Re: JJD] #99347
02/22/07 10:55 PM
02/22/07 10:55 PM
Dunedin Causeway, FL
David Parker Offline
Try a Sunfish spar. If you live near a Sunfish fleet, find a Sunfish junkie and have them dig up a broken spar. They break at the 11 foot mark. I think they are exactly the dimensions you need. Even new they are only $80.
Re: Re-posting previous thread on tubing [Re: Timbo] #99348
02/22/07 11:15 PM
02/22/07 11:15 PM
I think a windsurfer mast would be much more durable than the aluminum.
Re: New mast plug [Re: David Parker] #99349
02/23/07 12:29 AM
02/23/07 12:29 AM
Ahm negative, a F16 spin pole specially with the newer cut spinnakers you want max spin pole length which is 12ft.
Re: Re-posting previous thread on tubing [Re: Timbo] #99350
02/23/07 03:59 AM
02/23/07 03:59 AM
Hi all,
carbon windsurfer mast the only way to go, as found on "Altered". Cheap when second hand, light and strong <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />.
Regards Gary. <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Re: New mast plug [Re: JJD] #99351
02/23/07 05:48 AM
02/23/07 05:48 AM
1.5 x 0.065 inch = 38 mm x 1.65 mm alu tube.
Now I understand why you guys in the US are bending and snapping the poles so much more often then the other F16 sailors in the world. I think the standard elsewhere is 40x2 mm spi poles = 35% stiffer and stronger. However your US poles are lighter, so it is a "win-some, loose-some" trade-off.
Re: New mast plug [Re: Wouter] #99352
02/23/07 12:15 PM
02/23/07 12:15 PM
Mark P Offline
Mark P  Offline
Whats the percentage weight difference? or to put it another way do you wear a 2-3mm or 4-5mm wetsuit. In other words don't worry about a few grams just go for a reliable pole which doesn't snap. If you are that concerned about weight do as the Stealths do and go for Wouters favourite material CARBON FIBRE <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
MP*MULTIHULLS
Re: New mast plug [Re: Robi] #99353
02/23/07 06:28 PM
02/23/07 06:28 PM
Class rules say 3500 mm or 11'6". Sunfish spar is 14 whole, breaks at 11-12 feet, usually from abrasion/corrosion at the gooseneck. Here's one in use...
0 registered members (), 20,077 guests, and 605 spiders.
Most Online22,490
1 hour ago
