| Re: P16 - Nacra 5.0 comparison
[Re: Andinista]
#99479 02/21/07 12:04 PM 02/21/07 12:04 PM |
Posts: 902 Norman,OK | I have never sailed on either but I have been around a p16. They look fun but also they look heavy. Has he thought about a Hobie 16 or 17. Both those boats are pretty good boats and can be found cheap. The 16 catchs a bad rep about pitchpoling but in reality it isn't that bad. It is just weight sensitive which actually makes it a fun boat to sail because you movements matter.
There was talk on here about the 5.0 not to long ago, you might search for it. It is a pretty nice high performance boat.
[Re: gree2056]
#99480 02/21/07 12:59 PM 02/21/07 12:59 PM |
Posts: 6,049 Sebring, Florida. | I've sailed both, the 5.0 felt faster, maybe it's lighter. If he's not going to race it, he should get which ever one is in better shape, sails, rig, etc. Both are good boats for play. Neither one will pitch you quite like a Hobie 16 can! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Blade F16 #777
[Re: Andinista]
#99481 02/22/07 09:45 PM 02/22/07 09:45 PM |
Posts: 364 | It's a complete toss-up. The boats are essentially equal in speed, buoyancy, pointing, and weight capacity. The small differences: Nacra must "foot" rather than point high to the wind; it doesn't matter as the lower angle is compensated by extra speed, and both boats will arrive at the weather mark (equally sailed, with equal sails) at almost the same time. I think the Nacra has a slightly higher maximum speed potential, and I KNOW it's a wetter boat - many is the time I've come in from a windy sail on my 5.O with the mainsail soaked with water up to the spreader on the mast, and without ever flipping too! Oh yeah, it's slightly more difficult to flip the 5.O.
PS: Just re-read the original post. The 5.O is definitely more resistant to pitchpoling. Altho I've never PPed either boat, I've worried more on the Prindle, and I've buried my 5.O to the main beam MANY times. Again, good luck.
Andrew Tatton
Nacra 20 "Wiggle Stick" #266
Nacra 18 Square #12
[Re: hokie]
#99483 02/23/07 11:28 AM 02/23/07 11:28 AM |
Posts: 902 Norman,OK | Another thing I would like to add is kinda along the same lines as the last guy. The 5.0 is very modern looking....sadly that might matter a little to people. I mean I see a P16 or a H16 and think...huh look at that old boat even when it might be a new model. But the 5.0 is shaped like some of the hot boats out there right right now. That was a big influence for me the buy the 5.2 rather than a Hobie 17 or 18.
[Re: Andinista]
#99485 02/23/07 04:12 PM 02/23/07 04:12 PM |
Joined: Jun 2001 Posts: 890 Dunedin Causeway, FL David Parker
Posts: 890 Dunedin Causeway, FL | Hey, don't give up on pointing high with a boardless boat. I sail solo in a shallow area with a LOT of boardless boats and lots of skilled sailors sailing them. Experience will teach you how to make your boat point high. Hans Geisler will can outpoint most any boat on his old GCat 5 meter because he sails it correctly.
I've owned a Prindle-16, SuperCat 17 and a Mystere 5.0. Each hull is boardless but each is RADICALLY different in how it’s hull is cut and how it gets the job done. Each requires a VERY different touch to make them point high. On each boat it took me nearly a year to have some magic moment, some lightning bolt from Neptune, where I discovered the ever-so-subtle trick for pointing high on that particular boat. I can say with some certainty that I now can point as high as any boardless boat and as high as most board boats sailed by "average" sailors.
What is the trick? Relentless attention to weight placement to point high without pinching. EVERY wind shift, every lift, every head, you must adjust weight position. Move FORWARD and I mean WAY forward to point. Stop adjusting the sail and start adjusting your weight. On the SuperCat I lived with one foot forward of the front beam. I'm solo remember. The Mystere was the most rewarding for performance gains due to weight balance and it’s just like your N5.0 (skegs). With the slightest lift you sheet IN on a puff and slide forward, trap low, and drive the bows down, down, down while steering the boat up, up, up. Do NOT chicken out and sheet out on puffs. Anticipate the lifts or puffs and move forward early. Rookies always sit back and show their bows. Instead, bury the bow and show everyone your transom. Of course, you’ll get killed doing this on a Hobie 16.
Foot off? No...I gave that up. You only need that because you killed your speed avoiding a lift/puff. Footing is speed in the wrong direction. Footing and/or sheeting out is like a rookie skiing. When learning to ski, you foolishly turn up the hill to slow down, reducing power and killing speed. Recovery is slow and you’re going across the hill, not down. Then one day you’ll learn that it is the TURN ITSELF that slows you down, regardless of direction. Now you turn hard DOWN the hill to slow down, directly into the power! Now when you ski you turn down the STEEPEST part of the hill to slow down. The power is increasing when your speed momentarily decreases. When you ease up on the turn, acceleration is instantaneous, fierce, hot! Same in surfing…stall in the pocket, then punch it to go like hell. Like a flywheel…store it up for later release.
Upwind, it’s like wild thing downwind. NEVER lose speed, drive into power, not away. When the wind blows, go right at it, go after it, point high, bear away slightly, and point up again. Squeeze the lemon…
Sorry, I’m getting all excited. Nipples hard, the whole deal. <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" /> Time to go sailing!
Anyway, point high. Sail fast, take chances, safety third. | | | Re: P16 - Nacra 5.0 comparison
[Re: Andinista]
#99487 02/27/07 08:58 AM 02/27/07 08:58 AM |
Posts: 902 Norman,OK | I think that the 5.2 has more floatation than the Hobie 17. I am not sure but I hear people talk about worrying about overloading the 17 while the 5.2 can handle alot of weight.
I would look around for a 5.2, granted they are no longer made but neither is the Hobie 17. THey are once again canceling production on it. The 5.2 looks a little more modern and you don't have to worry about the 17's bad sails.
[Re: gree2056]
#99488 02/27/07 09:52 AM 02/27/07 09:52 AM | Anonymous
| Anonymous
Unregistered | Guys:
I have put three adults and a child on my 17 and it STILL tried to lift a hull. Yes for racing you will be slow with more than one. BUT I was even moving in very light air with three adults. You just have to know how to sail your boat.
Doug | | | Re: P16 - Nacra 5.0 comparison
[Re: ]
#99489 02/27/07 10:04 AM 02/27/07 10:04 AM |
Posts: 12,310 South Carolina | the question isn't about moving - it's about how much hull is out of the water and how soon the bow will drive in with the extra weight. I've seen a Hobie 18 with eight adults on board...they were moving but there wasn't much hull above the water.
Jake Kohl | | | Re: P16 - Nacra 5.0 comparison
[Re: MauganN20]
#99491 02/27/07 02:02 PM 02/27/07 02:02 PM |
Posts: 902 Norman,OK | The 14 can handle two adults but you will hardly have any free board at all. I just have never been around a 17 and don't know what it is capable of.
1,303
guests, and 36
