F18 spin pole dimensions #100237
03/08/07 09:09 AM
03/08/07 09:09 AM
Columbia South Carolina, USA
dave mosley Offline OP
anyone got the 411 on wall thickness, length, any other pertinent info for NACRA and Tiger spin poles?
What about the new round aluminum booms for N20, Tiger and F18?
Thanks
Re: F18 spin pole dimensions [Re: dave mosley] #100238
03/08/07 09:35 AM
03/08/07 09:35 AM
I'm pretty sure it's 2" OD with a .065" wall thickness....will measure tonight.
Re: F18 spin pole dimensions [Re: Jake] #100239
03/08/07 07:19 PM
03/08/07 07:19 PM
whoops...1.5" OD...F18 is 140" long, N20 pole is 142.75" long.
Re: F18 spin pole dimensions [Re: dave mosley] #100240
03/08/07 10:18 PM
03/08/07 10:18 PM
St. Louis, MO
JoeLeonard Offline
JoeLeonard  Offline
St. Louis, MO
Thanks
I don't have dimensions for you, but I will suggest you stay clear of the round boom on the N20's. The only N20's that were equiped from the factory with round booms were the Alter cup boats last year, and that (per my understanding) was due to a shortage on the ususal rectangular booms. The round booms on the 20 were too flexible and caused problems with sail shape under hard sheeting loads. Most of us have already swapped out the round booms for the rectangular. (including me)
JL N20 # 1041 "Lucille" A-cat USA 44
Re: F18 spin pole dimensions [Re: JoeLeonard] #100241
03/09/07 02:11 PM
03/09/07 02:11 PM
Charleston, SC
NCSUtrey Offline
NCSUtrey  Offline
Charleston, SC
Just so that everyone knows, a sunfish spar has the same specs as a stock nacra aluminum pole...
Trey
Re: F18 spin pole dimensions [Re: Jake] #100242
03/11/07 09:16 AM
03/11/07 09:16 AM
Dunedin Causeway, FL
David Parker Offline
I hope some other F18 folks add their comments here. I'm pretty sure the Capricorn uses a 2 inch pole. I've asked this same question before with no proper answer.
It's interesting to note that Jake's numbers for the F18 pole match the F16 pole...11.5 feet long (3500 mm) and 1.5 inches diameter. The Metric (SI) version at 40 mm x 2 mm is stronger than the American (38 mm x 1.65 mm). We can't get the 40mm stuff here. And true, a used Sunfish spar fits those dimensions.
John Williams, what does your Cap spin pole measure?
Re: F18 spin pole dimensions [Re: David Parker] #100243
03/13/07 11:32 AM
03/13/07 11:32 AM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
The Tiger pole is 1 5/8 diameter. I do not know the wall thickness. Same section as the round boom. The older Nacra F18 pole was 1 1/2 inch diameter. I do not know if the Infusion is slightly bigger around.
Dan
0 registered members (), 18,087 guests, and 1,120 spiders.
14 hours ago
