Foil Profile #100334
03/10/07 05:46 AM
03/10/07 05:46 AM
I am crafting new foils for a Hobie 20. What is the latest thinking on the optimum profile? Is it the same for rudder and dagger-board?
Regards
Chet
Re: Foil Profile [Re: ] #100335
03/11/07 01:20 PM
03/11/07 01:20 PM
maui
jollyrodgers Offline
maui
hello,
i don't know if the latest thinking is any different than 60-90's thinking, but here is a link to a foil that would work pretty well for a rudder. http://marlongofast.tripod.com/zipped_aeronotes/NACAfoil.htm
6% may be a hair thin, but a naca63 series foil will be good for rudder and board.
keep in mind that hand shaping may not yield a perfect replica of whatever foil you are trying to shape. if you find the ultimate foil to replicate you would need to use a cnc machine to create it if you want valid test results for that particular foil.
you can make templates for the foil you choose to check a hand shaped blade.
Re: Foil Profile [Re: ] #100336
03/12/07 12:55 PM
03/12/07 12:55 PM
Hollister CA, Plano TX
avalondarlyn Offline
NACA 12. from what i've learned on the subject. this is a good basic profile. i used www.flyingfoam.com Bob there was a very nice and the price was right. maybe check with hobie as to what there foil is so they match the wells. i had Bob cut the cores. this is for a dagger board. as for rudders a naca 12 s/b close. maybe something slightly thicker/shorter chord. let the pro's chime in but i belive naca 12 is what is used on the inter 20 daggers. the rudders are a much more complex foil
Re: Foil Profile [Re: avalondarlyn] #100337
03/12/07 05:59 PM
03/12/07 05:59 PM
ncik Offline
ncik  Offline
Naca 12 series are good general purpose sections.
The naca 63 and 64 series are becoming more popular, especially for higher speed sailing boats.
If you can't be bothered putting a somewhat tricky concave section in, as the 63 or 64 series sections do, the 12 series is more than appropriate.
Profile wise, parallel for most of the length with tapered tips. The tips are pretty much up to your preference as there are a lot of different theories about.
Re: Foil Profile [Re: ncik] #100338
03/12/07 06:56 PM
03/12/07 06:56 PM
California
mmiller Offline
mmiller  Offline
California
The original H20 daggerboard shape was hand crafted by Phil Edwards. The rudders are certainly quite different than the daggers. We are expecting to be given the go ahead to race the 20 with the same blade as on most other Hobies, so the EPO2 will be a good choice. They work very well on the 20. We can not offer any help on either foils specs / dimensions. There are no "plans" on them. Both are readily available for purchase, so if this is a "project"... have fun with it and let us know what you ended up with.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: Foil Profile [Re: ] #100339
03/12/07 08:32 PM
03/12/07 08:32 PM
It's probably of little use, but I'm using a 63-010 NACA foil section for our US1meter keel (www.teamseacats.com). This is the section I really want but may have to go a tad bit thicker (perhaps to a -015) in order to get the structure needed inside the keel. I'm working out the details of the lead bulb/keel/hull structure on the computer for the next couple of weeks. The 63 series is a good all-round lifting foil with a good average between drag and high-ish stall angle....though I wonder if sacrificing a little drag in return for a high stall angle is really that important on a daggerboard.
Re: Foil Profile [Re: Jake] #100340
03/12/07 10:48 PM
03/12/07 10:48 PM
ncik Offline
ncik  Offline
probably not really with a 1m because they manoeuvre so quickly without losing much speed.
Re: Foil Profile [Re: ncik] #100341
03/16/07 06:18 AM
03/16/07 06:18 AM
This 63 or 64 profile sounds pretty good. How can I get my hands on a picture?
The link earlier in the postings to naca 0006 shows something not quite concave.
Regards
Chet
Re: Foil Profile [Re: ] #100342
03/16/07 06:54 AM
03/16/07 06:54 AM
Typically you start with a complicated formula or x&y coordinates to draw the foil. I've got the 63 series setup in a 3-D design table such that I can change any parameter (including the % of thickness). How long and what thickness do you want (10% is pretty standard)? I'll be glad to give you a 1:1 drawing.
Re: Foil Profile [Re: Jake] #100343
03/16/07 07:41 AM
03/16/07 07:41 AM
here's the 63-010...let me know what format you would like it in too.
Re: Foil Profile [Re: ] #100344
03/16/07 09:55 AM
03/16/07 09:55 AM
Jake that looks great. You are truly a nice guy.
My length is 15 1/2" and max width about 1 1/2" so 10% is fine. I can easily enlarge drawings so a pdf file would suit.
Regards
Chet
Re: Foil Profile [Re: ] #100345
03/16/07 10:21 AM
03/16/07 10:21 AM
nice guy? nah...just a geek who enjoys this stuff. PDF attached (hopefully). Scale is 1:2
Re: Foil Profile [Re: Jake] #100346
03/16/07 12:05 PM
03/16/07 12:05 PM
In that case how about NACA 64?
Regards
Chet
Re: Foil Profile [Re: ] #100347
03/16/07 01:59 PM
03/16/07 01:59 PM
yup, a couple of minutes to plug in the numbers...
again 1:2
Re: Foil Profile [Re: Jake] #100348
03/17/07 08:07 PM
03/17/07 08:07 PM
Victoria, Oztralia
mattaipan Offline
mattaipan  Offline
Victoria, Oztralia
Hi Jake
Just wondering, seeing as you seem to be on a roll...
Whether you might put one up at 63-008, for me, chord length of 290mm.
Regards
Re: Foil Profile [Re: mattaipan] #100349
03/17/07 10:33 PM
03/17/07 10:33 PM
sure - when I get back to my work computer on Monday, I'll plug it in.
Re: Foil Profile [Re: Jake] #100350
03/18/07 01:06 AM
03/18/07 01:06 AM
Many airfoil coordinates are available for download from: http://www.ae.uiuc.edu/m-selig/ads/coord_database.html
The 63-008 coordinates are available here: http://www.pdas.com/profiles.htm#63-008
Setting it up in a spreadsheet and printing the outline for a chord of 290mm is relatively trivial, if you dont want to wait until monday.
Are you going to use the 63-008 as daggerboards?
Re: Foil Profile [Re: Rolf_Nilsen] #100351
03/18/07 02:21 AM
03/18/07 02:21 AM
Victoria, Oztralia
mattaipan Offline
mattaipan  Offline
Victoria, Oztralia
Yes thats possibly going to be the plan, I have on good authority from someone you and I both know Rolf that 8% would be fine, although he was thinking 0008 series section, but I've drawn it out and looked at factory boards and they look nothing alike, so I thought I'd compare them to the 63008 section and see what they look like.
I have a set of timber boards that should do the job for starters but once I've gotten the shape worked out, I'm planning to make a mould and my own boards.
Regards
Re: Foil Profile [Re: mattaipan] #100352
03/19/07 08:36 AM
03/19/07 08:36 AM
Regards
Attached at 2:1...I could almost make this 1:1 and fit...however, watch your paper sizes, this is the US 8.5" X 11" sheet size.
Re: Foil Profile [Re: Jake] #100353
03/20/07 01:29 AM
03/20/07 01:29 AM
Victoria, Oztralia
mattaipan Offline
mattaipan  Offline
Victoria, Oztralia
Hi Jake
Thanks for that, I think I would have been able to take 1:1, I'm not much with computers, but I'll have a play later and see if I can enlarge it. The drawing I mean <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Regards
0 registered members (), 16,262 guests, and 1,190 spiders.
Most Online22,490
Yesterday at 08:14 AM
