shroud tension #10088
09/04/02 02:40 PM
09/04/02 02:40 PM
Disc20 Offline OP
Disc20  Offline OP
Hey Guys,
Need some advice.
I've got a 20 foot trimaran. The boat is very stiff, absolutly no articulation in the hulls. I've got a fractional square top rig with a carbon (no spreaders) rotating pole and boom.
Question: I sail in 10-15 knots normally. Keeping all this in mind do you think I should keep the stays loose or tight. I can't seem to find the proper balance. The only time I got a clear feeling was in a drifter race with a loose rig.
Looking forward to your insight.
Re: shroud tension [Re: Disc20] #10089
09/05/02 07:15 PM
09/05/02 07:15 PM
Arkansas, USA
Kirt Offline
Kirt  Offline
Arkansas, USA
Well, knowing no more than the minimal amount you posted, I can only give you some generalities. I assume by "pole" you mean mast? And since it's rotating I assume it's some teardrop (likely w/ no spreaders) shape and you have a headsail(s) like a jib or genoa- IF all this is true then-
1) Talk to your sailmaker-
2) You want tight shrouds in 10-15 (at least upwind) because if loose the headstay will "sag" to leeward and hurt your ability to point, as well as allowing the mast to sag to leeward hurting power (this may or may not be an issue under these conditions). In light air this is not the issue and then looser shrouds can help by allowing the mast to rotate properly (usually not an issue in higher winds)-
Just my opinions but hope it helps-
Kirt
Kirt Simmons Taipan #159, "A" cat US 48
0 registered members (), 2,742 guests, and 379 spiders.
