Newbie Questions #101915
03/28/07 05:11 PM
03/28/07 05:11 PM
NSW
kingcowie Offline OP
NSW
I have just bought a Taipan 4.9 whihc has a couple of challenges and also some questions. My aft beam only has hold bolts on the outboard side not the inboard side (See attach picture). Secondly my front beam has an inboard bolt that is lose and will not tighten, can someone explain to me how the front beam is tied to the two pods. Thanks in advance. kingcowie
Re: Newbie Questions [Re: kingcowie] #101916
03/28/07 05:36 PM
03/28/07 05:36 PM
ncik Offline
ncik  Offline
Picture doesn't seem to have uploaded completely.
Sounds like the forward beam bolt is threaded, if so, it will need to be replaced. Are you sure the nut underneath the deck isn't spinning?
Re: Newbie Questions [Re: ncik] #101917
03/28/07 09:05 PM
03/28/07 09:05 PM
NSW
NSW
Thanks there is no nut in the underside, it appears to be glassed in as the outboard side also is tight but cant feel nut underneat.
Am i missing a bolt for the rear beam..
SJK Taipan Silver Fern
Re: Newbie Questions [Re: kingcowie] #101918
03/28/07 09:09 PM
03/28/07 09:09 PM
NSW
NSW
try the attachement again
Re: Newbie Questions [Re: kingcowie] #101919
03/28/07 10:20 PM
03/28/07 10:20 PM
ncik Offline
ncik  Offline
If you can't tighten the bolt, it's threaded, or nut is missing. Just try to remove all the bolts and inspect anyway. The boat looks well used so it would be a good idea to pull everything apart to inspect and/or replace anyway.
In the photo, I think you'll find a bolt head if you stick a screw driver down that hole in the beam.
Try to find the nuts. Or stick a camera in the hull to take a photo with flash on. Or try to take the beam end cap off and shine a touch into the beam to see the bolt head.
Re: Newbie Questions [Re: kingcowie] #101920
03/28/07 10:24 PM
03/28/07 10:24 PM
Central California
ejpoulsen Offline
ejpoulsen  Offline
Central California
The inboard bolts on the rear beam are probably there--they are Allen heads that seat on the bottom of the beam. Look through the hole with a flashlight and you will see. Photo attached of the rear beam being attached with an Allen wrench sunk into the hole tightening the bolt.
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: Newbie Questions [Re: ejpoulsen] #101921
03/29/07 12:13 AM
03/29/07 12:13 AM
NSW
NSW
Thanks Guys,
Spot on the rear beam inboard is supported by a cap screw.
Thanks but i will take your advice and strip both beams off to check out.
Re: Newbie Questions [Re: kingcowie] #101922
03/29/07 03:08 AM
03/29/07 03:08 AM
Victoria, Oztralia
mattaipan Offline
mattaipan  Offline
Victoria, Oztralia
Hi All
A friend of mine had the same problem when he overtightened his beam bolts, in the end we removed the main beam and put in stainless helicoils to save having to remove the plates.
Regards
0 registered members (), 2,530 guests, and 406 spiders.
