spinnaker halyard #104155
04/18/07 02:59 PM
04/18/07 02:59 PM
binga Offline OP
binga  Offline OP
What is the proper routing for the spinnaker halyard going up the mast on a Taipan 4.9? In front of the diamond spreaders or through them? Or behind the spreaders and back in front of them to the top block? Or fairleads up the mast? Or constant tension on halyard sometimes I forget and it gets wrapped around the spreader? Thanks Andrew
Re: spinnaker halyard [Re: binga] #104156
04/18/07 05:56 PM
04/18/07 05:56 PM
Panama City, Florida
Redtwin Offline
Redtwin  Offline
I don't know about the Taipan 4.9, but we run them through the spreader on the Hobie 20.
Rob V. Nacra 5.2 Panama City
Re: spinnaker halyard [Re: binga] #104157
04/18/07 06:04 PM
04/18/07 06:04 PM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
On a Blade, I run them thru the spreader .... but I tape the corners so that the line doesn't get chaffed or trapped.
USA 777
Re: spinnaker halyard [Re: binga] #104158
04/18/07 06:36 PM
04/18/07 06:36 PM
Central California
ejpoulsen Offline
ejpoulsen  Offline
Central California
Andrew,
On your boat it should run as follows: the halyard exits the pole through the block just in front of the main beam. It runs up the front of the mast in front of the spreaders, trap wires, and side stays on either side of the forestay (I prefer the starboard side) up throught the halyard block to the top of the spinnaker.
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: spinnaker halyard [Re: ejpoulsen] #104159
04/18/07 11:26 PM
04/18/07 11:26 PM
Chicago, IL
Krisu13 Offline
Krisu13  Offline
Chicago, IL
The way I had it on my N6.0 is in front of the mast. I have ran very short line between (attached to) spreaders. Then the spinnaker halyard goes into the loop created between the mast and the short line.
I20
0 registered members (), 2,609 guests, and 268 spiders.
