Re: Buying a N 5.0, what do yall think [Re: ] #105554
05/01/07 11:11 PM
05/01/07 11:11 PM
johnny872005 Offline OP
ya Doug, I plan to race the nacra.
I do plan to try to get someone to come with me and check it out this weekend when it gets picked up just to play safe.
Were you at RR? I didnt see you there last weekend.
$2700 is nice for a 4.3, I'd be scared to run a spin on such a small boat though <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
Can you guys please show me where yall see the repair that I'm not seeing?
thanks
Re: Buying a N 5.0, what do yall think [Re: johnny872005] #105555
05/02/07 12:11 AM
05/02/07 12:11 AM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
There looks to be a patch on the top side of the hull on one of the inside pictures. Also I would check in a few of the pictures it looks like there is some water inside the fiberglass. or at least it might be bulged out
Re: Buying a N 5.0, what do yall think [Re: johnny872005] #105556
05/02/07 12:14 AM
05/02/07 12:14 AM
Thailand
Buccaneer Offline
Buccaneer  Offline
Thailand
Painted hulls? Yikes! <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> If you don't personally know the boats history then be careful. Also adding inspection ports can also be a handy way to access the inside of the hulls for repair... <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Re: Buying a N 5.0, what do yall think [Re: Buccaneer] #105557
05/02/07 08:08 AM
05/02/07 08:08 AM
the entire hulls arnt painted, only that one small portion where the paint is coming off.
Re: Buying a N 5.0, what do yall think [Re: johnny872005] #105558
05/02/07 08:41 AM
05/02/07 08:41 AM
Santiago, Chile
Andinista Offline
Andinista  Offline
Santiago, Chile
Check comments about stringers on this post. This boat doesn´t have them, don´t know exactly what that means (and I´m interested...)
http://www.catsailor.com/forums/showflat...part=1&vc=1
Re: Buying a N 5.0, what do yall think [Re: johnny872005] #105559
05/02/07 09:43 AM
05/02/07 09:43 AM
Graham, NC
WindyHillF20 Offline
Graham, NC
I too believe this boat has been repaired. Peeling paint, glass patch and extra portholes. I wouldn't believe what the owner is telling you. Unless its real cheap have it checked out by someone that knows what they are looking at.
Re: Buying a N 5.0, what do yall think [Re: WindyHillF20] #105560
05/02/07 10:28 AM
05/02/07 10:28 AM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
About the stringers, some of the Nacra's, at least the earlier one were solid fiberglass and they had stringers. THe newer ones are foam/fiberglass laminate. They don't have stringers so this must be newer than 84 I think.
Re: Buying a N 5.0, what do yall think [Re: gree2056] #105561
05/02/07 10:37 AM
05/02/07 10:37 AM
The boat is an 1986 model. If you look at the pictures you'll see it on 2 of the pictures (one has serial the other has the sharpie writing on the inside of the hull
Re: Buying a N 5.0, what do yall think [Re: johnny872005] #105562
05/02/07 10:42 AM
05/02/07 10:42 AM
Yorktown, Va
Rusty Offline
Rusty  Offline
Yorktown, Va
I have had a Nacra 5.2 and two 5.8's. I am looking for a 5.0 or 500 to replace a Hobie 14 I also have. The 5.0 is usually a solid boat but 3 inspection ports does seem excessive. No way it won't weaken the decks some.
Good luck, hope it works out for you.
Re: Buying a N 5.0, what do yall think [Re: Rusty] #105563
05/02/07 11:29 AM
05/02/07 11:29 AM
ya the one turnoff for me thus far is the 3 inspection ports... I wouldn't have the guts to install 1 inspection port, would worry I'd dmg the hull integrity. Yet 3... <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
Oh well he said he's sailed it alot and when I go to pick it up I plan to bring someone that knows more about nacras than I do. Any more sugggestions guys?
Re: Buying a N 5.0, what do yall think [Re: johnny872005] #105564
05/02/07 11:58 AM
05/02/07 11:58 AM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
I am about out of suggestions, my last advice would be that if you feel at all worried about it, don't get it. Be careful and don't get stuck in a boat that you won't like or will be working on constantly.
0 registered members (), 388 guests, and 38 spiders.
