| Re: Buying a N 5.0, what do yall think
[Re: johnny872005]
#105555 05/02/07 12:11 AM 05/02/07 12:11 AM |
Posts: 902 Norman,OK | There looks to be a patch on the top side of the hull on one of the inside pictures. Also I would check in a few of the pictures it looks like there is some water inside the fiberglass. or at least it might be bulged out
[Re: johnny872005]
#105556 05/02/07 12:14 AM 05/02/07 12:14 AM |
Posts: 1,479 Thailand | Painted hulls? Yikes! <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> If you don't personally know the boats history then be careful. Also adding inspection ports can also be a handy way to access the inside of the hulls for repair... <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
[Re: WindyHillF20]
#105560 05/02/07 10:28 AM 05/02/07 10:28 AM |
Posts: 902 Norman,OK | About the stringers, some of the Nacra's, at least the earlier one were solid fiberglass and they had stringers. THe newer ones are foam/fiberglass laminate. They don't have stringers so this must be newer than 84 I think.
[Re: johnny872005]
#105564 05/02/07 11:58 AM 05/02/07 11:58 AM |
Posts: 902 Norman,OK | I am about out of suggestions, my last advice would be that if you feel at all worried about it, don't get it. Be careful and don't get stuck in a boat that you won't like or will be working on constantly.
1 registered members (FredL),
2,799
guests, and 283
