Gasket Material for Tornado #105811
05/04/07 10:54 AM
05/04/07 10:54 AM
Does anyone know where in Jacksonville, FL I can get gasket material for my centerboard wells on short notice? Any suggestions for temporary gasket fixes so I can do the Mug race tomorrow? Thanks, Mike
Re: Gasket Material for Tornado [Re: ] #105812
05/04/07 11:29 AM
05/04/07 11:29 AM
leave them out completely? It's not like they keep water out of the boat or anything - right?
Re: Gasket Material for Tornado [Re: Jake] #105813
05/04/07 11:39 AM
05/04/07 11:39 AM
Without the gaskets you get lots of drag from the centerboard trunks. The Tornado have kick up centerboards, so the trunks are quite large. Any sailmakers around Jacksonville? They might have some mylar strips lying around.
Re: Gasket Material for Tornado [Re: ] #105814
05/04/07 12:06 PM
05/04/07 12:06 PM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
Duck Tape! Go Racing!
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: Gasket Material for Tornado [Re: Chris9] #105815
05/04/07 02:35 PM
05/04/07 02:35 PM
Thanks for the responses, I will give it a try.
Re: Gasket Material for Tornado [Re: ] #105816
05/04/07 03:45 PM
05/04/07 03:45 PM
Charleston, SC
NCSUtrey Offline
NCSUtrey  Offline
Charleston, SC
Call Layline and ask for the centerboard trunk tape. I'd bet Mike Krantz could get it to Carl Saylor who will be going down there.
Trey
Re: Gasket Material for Tornado [Re: ] #105817
05/04/07 07:26 PM
05/04/07 07:26 PM
Warsaw, IN
F18MattJ Offline
F18MattJ  Offline
Warsaw, IN
West Marine Possible? They may have mylar tape.
Re: Gasket Material for Tornado [Re: ] #105818
05/07/07 11:30 AM
05/07/07 11:30 AM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
I know this is late...but a good emergency substitute would be 1/8" rubber mat cut to size and stuck on with contact cement. This is what the T used to run prior to mylar coming on scene. It is readily available at a lot of hardware stores. Just doesn't last as long at mylar.
Mike.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: Gasket Material for Tornado [Re: Tornado] #105819
05/07/07 02:16 PM
05/07/07 02:16 PM
BobG Offline
BobG  Offline
how about strips out those flexible chopping boards, you will have to overlap them but put the first strip on the rear then overlap as you work forward make sure you let the contact cement set then tap on lightly with block of wood and hammer..
0 registered members (), 362 guests, and 18 spiders.
