| Keeping the mast stable while trailering... #109822 06/18/07 08:14 AM 06/18/07 08:14 AM |
Posts: 70 Louisiana | I have a TheMightyHobie18 with the "factory" mast bracket for holding it over the rear-crossbar. But after trailering for an hour or so the bracket (and mast) tends to fall to the rear. It has never fell off but I would like to find something that would keep the mast in one spot while trailing.
So how do you keep your mast stable while trailing?
Thanks Todd Hubbell Thiboduax LA
Sailing a 1980 Hobie-18M with 1990 hulls in Southern Louisiana.
| | | Re: Keeping the mast stable while trailering...
[Re: Scubajeep]
#109825 06/18/07 12:45 PM 06/18/07 12:45 PM | Anonymous
| Anonymous
Unregistered | I've had some success with a rubber kayak block that I got from an outdoor sports store, something like this. It has a channel cut on the underside that fits perfectly over my traveler track and prevents it moving backwards. I tie the mast down onto the trailer immediately behind the block. If you do a google search on "kayak block" you'll find a lot similar products. Mark. | | | Re: Keeping the mast stable while trailering...
[Re: Inter_Michael]
#109829 06/19/07 12:24 AM 06/19/07 12:24 AM |
Posts: 2,844 42.904444 N; 88.008586 W | Over the past 20 years of owning beach cats, I have used about all. I like the kayak cradle idea, haven't tried that one yet.
I usually use a large piece of styrofoam, from some shipment box, at work, or elsewhere, and change it about once a year. It's FREE, works well, I often cut the appropriate grooves in it with a serrated kitchen knife. I hold it with a bungee.
F-18 Infusion #626- SOLD it!
[Re: gjoyce56]
#109832 06/20/07 06:30 PM 06/20/07 06:30 PM | Anonymous
| Anonymous
Unregistered | Gary:
Curious. Send pic
dsnell4 at houston.rr.com
Doug | | | Re: Keeping the mast stable while trailering...
[Re: arbo06]
#109834 06/21/07 06:51 AM 06/21/07 06:51 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | We used to use one of those plastic storage cartons, right side up and tied down to the lacing. We cut out two opposing sides to create a cradle to fit the shape of the mast and tied the mast to the crate. (This was a FREE solution, because I had found some discarded crates behind a store.)
One word of caution: In general, for trailering, it is a good idea to NOT carry your mast with the sail track facing down (especially true with Comptips.) | | | Re: Keeping the mast stable while trailering...
[Re: Mary]
#109835 06/21/07 07:01 AM 06/21/07 07:01 AM |
Posts: 887 Crofton, MD | One word of caution: In general, for trailering, it is a good idea to NOT carry your mast with the sail track facing down (especially true with Comptips.) Mary, Could you explain this a little more? I have found that placing mast with sail track down keeps all pressure off of the sail track. If I placed it sail track up then the ropes (Not Bungies) would put considerable force on the sail track. | | | Re: Keeping the mast stable while trailering...
[Re: Chris9]
#109836 06/21/07 08:29 AM 06/21/07 08:29 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | It depends on how you are supporting the mast, but it is something to think about. The mast "works" a lot when you are trailering, so if you have the mast track facing down and it is on padding, the padding can wear through, and the next thing that wears through is the mast track.
A friend arrived at a regatta with his comptip really messed up and no way to put a sail up. He said he had learned his lesson and would never again trailer with the mast track down. I have also seen aluminum masts with the mast track worn down and distorted from rubbing while trailering.
Some of us trailer boats for hundreds or even thousands of miles, and the mast track is the side of the mast most vulnerable to damage.
Like I said, it is just something else to think about when supporting your mast on the trailer. | | | Re: Keeping the mast stable while trailering...
[Re: Mary]
#109837 06/21/07 09:21 AM 06/21/07 09:21 AM |
Posts: 12,310 South Carolina | I keep mine down because it doesn't seem to accumulate dirt and grime as badly that way. I have tailored my mast supports so that they are cutout on the bottom so they do not put pressure on the luff track.
Jake Kohl | | | I have an idea
[Re: Scubajeep]
#109838 06/21/07 10:48 AM 06/21/07 10:48 AM |
Posts: 851 US Western Continental Shelf | This solution addresses what I read as the problem, the mast drifting aftwards.
Start with a one quart bleach bottle. Cut a hole in the top o f the bottle that is large enough for the mast tip, while leaving the bottle handle intact.
Fit this over the mast tip and tie a pair of tension lines to the handle. Tie the other end of each line to each side of the rear cross bar.
GARY
Santa Monica Bay Mystere 6.0 "Whisk" <--- R.I.P. | | |
1 registered members (vasil),
504
guests, and 48
