Keeping the mast stable while trailering... #109822
06/18/07 08:14 AM
06/18/07 08:14 AM
Louisiana
Scubajeep Offline OP
Louisiana
I have a TheMightyHobie18 with the "factory" mast bracket for holding it over the rear-crossbar. But after trailering for an hour or so the bracket (and mast) tends to fall to the rear. It has never fell off but I would like to find something that would keep the mast in one spot while trailing.
So how do you keep your mast stable while trailing?
Thanks
Todd Hubbell
Thiboduax LA
Sailing a 1980 Hobie-18M with 1990 hulls in Southern Louisiana.
Re: Keeping the mast stable while trailering... [Re: Scubajeep] #109823
06/18/07 09:50 AM
06/18/07 09:50 AM
NC
calcheck Offline
calcheck  Offline
NC
I use the crude and effective solution for the rear- an old sneaker under the mast and 2 strong bungee cords to hold it down.
John
Re: Keeping the mast stable while trailering... [Re: Scubajeep] #109824
06/18/07 10:23 AM
06/18/07 10:23 AM
South Louisiana, USA
Clayton Offline
Clayton  Offline
Todd,
I fought with that for many years. What worked (using the bracket you have) is after lashing the mast to the bracket I would run the tail end through the traveler cleat. Make sure there is no slack or the bracket will slip. If I did it right there was no problem.
Clayton
Re: Keeping the mast stable while trailering... [Re: Scubajeep] #109825
06/18/07 12:45 PM
06/18/07 12:45 PM
I've had some success with a rubber kayak block that I got from an outdoor sports store, something like this. It has a channel cut on the underside that fits perfectly over my traveler track and prevents it moving backwards. I tie the mast down onto the trailer immediately behind the block. If you do a google search on "kayak block" you'll find a lot similar products.
Mark.
Re: Keeping the mast stable while trailering... [Re: ] #109826
06/18/07 03:44 PM
06/18/07 03:44 PM
WEST. MICH. USA
DVL Offline
DVL  Offline
WEST. MICH. USA
I have a bracket off the trailer that reaches above the rear crossbar. The mast rests in that. It's removable to get the boat off the trailer. no pressure on the boat.
Re: Keeping the mast stable while trailering... [Re: Scubajeep] #109827
06/18/07 08:36 PM
06/18/07 08:36 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
Block of wood routed with channel for track. Female depression into top and carpeted. Place block onto track and drop mast into saddle and mast sits proud of all working gear and looks the part. Stretchy holds mast down into seat.
Re: Keeping the mast stable while trailering... [Re: Scubajeep] #109828
06/18/07 10:53 PM
06/18/07 10:53 PM
California!
Inter_Michael Offline
California!
Murrays had the part (cradle) that affixes to the trailer, above the rear beam. That way, the boat movement is isolated from that of the mast. Good for carbon masts. I think it is more secure than any other way to secure the mast...
my 2 cents...
Re: Keeping the mast stable while trailering... [Re: Inter_Michael] #109829
06/19/07 12:24 AM
06/19/07 12:24 AM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
Over the past 20 years of owning beach cats, I have used about all. I like the kayak cradle idea, haven't tried that one yet.
I usually use a large piece of styrofoam, from some shipment box, at work, or elsewhere, and change it about once a year. It's FREE, works well, I often cut the appropriate grooves in it with a serrated kitchen knife. I hold it with a bungee.
F-18 Infusion
#626- SOLD it!
Re: Keeping the mast stable while trailering... [Re: Todd_Sails] #109830
06/19/07 12:08 PM
06/19/07 12:08 PM
California!
California!
Another great idea is to add a bicycle leg light strap (LED) to the end of the mast for night transport. My old 5.8 mast went thru the radiator of a ford focus one time. (Or should I say the focus tried to go thru me <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> ) You can pick those bungee leg straps up at target/ kmart and any other high end store...about 20 bucks. LED's are blinking red, and it lasts a long time.
Re: Keeping the mast stable while trailering... [Re: Inter_Michael] #109831
06/20/07 04:28 PM
06/20/07 04:28 PM
Long Island
gjoyce56 Offline
gjoyce56  Offline
Long Island
I tried a variety of methods before finally hitting on one that worked.
Went to Home Depot, bought a 10 foot length of 1.5 inch pipe and a sort of U-shaped cup (has a base and 4 screw holes around the flange. Think a half tube with a flange.
Drilled four pilot holes in the trailer frame, screwed in the "cup" ... cut the pipe to around 32 inches ... creased it slightly along the seam (Hand sledge and metal spike/chisel) so it would fold a bit and fit into the cup ... and after reading this thread, drilled two holes about half way up for a U-shaped thingee I had lying around .... Used an old dockline to stablize it sideways and forward (it was plenty stiff, but I figured, why not?) and bingo.
I'll use the tubing for something else I'm sure ($15), the cup (around $4) came with big sheet metal screws. Total cost with NY tax $22.22.
Every bit as good as anything else I've seen ...
Happy to e-mail an image if you want
gary
Re: Keeping the mast stable while trailering... [Re: gjoyce56] #109832
06/20/07 06:30 PM
06/20/07 06:30 PM
Gary:
Curious. Send pic
dsnell4 at houston.rr.com
Doug
Re: Keeping the mast stable while trailering... [Re: warbird] #109833
06/21/07 05:36 AM
06/21/07 05:36 AM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
I have what Warbird describes. It is perfect.
Re: Keeping the mast stable while trailering... [Re: arbo06] #109834
06/21/07 06:51 AM
06/21/07 06:51 AM
We used to use one of those plastic storage cartons, right side up and tied down to the lacing. We cut out two opposing sides to create a cradle to fit the shape of the mast and tied the mast to the crate. (This was a FREE solution, because I had found some discarded crates behind a store.)
One word of caution: In general, for trailering, it is a good idea to NOT carry your mast with the sail track facing down (especially true with Comptips.)
Re: Keeping the mast stable while trailering... [Re: Mary] #109835
06/21/07 07:01 AM
06/21/07 07:01 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
Mary,
Could you explain this a little more? I have found that placing mast with sail track down keeps all pressure off of the sail track. If I placed it sail track up then the ropes (Not Bungies) would put considerable force on the sail track.
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: Keeping the mast stable while trailering... [Re: Chris9] #109836
06/21/07 08:29 AM
06/21/07 08:29 AM
It depends on how you are supporting the mast, but it is something to think about. The mast "works" a lot when you are trailering, so if you have the mast track facing down and it is on padding, the padding can wear through, and the next thing that wears through is the mast track.
A friend arrived at a regatta with his comptip really messed up and no way to put a sail up. He said he had learned his lesson and would never again trailer with the mast track down. I have also seen aluminum masts with the mast track worn down and distorted from rubbing while trailering.
Some of us trailer boats for hundreds or even thousands of miles, and the mast track is the side of the mast most vulnerable to damage.
Like I said, it is just something else to think about when supporting your mast on the trailer.
Re: Keeping the mast stable while trailering... [Re: Mary] #109837
06/21/07 09:21 AM
06/21/07 09:21 AM
I keep mine down because it doesn't seem to accumulate dirt and grime as badly that way. I have tailored my mast supports so that they are cutout on the bottom so they do not put pressure on the luff track.
I have an idea [Re: Scubajeep] #109838
06/21/07 10:48 AM
06/21/07 10:48 AM
US Western Continental Shelf
hobiegary Offline
hobiegary  Offline
This solution addresses what I read as the problem, the mast drifting aftwards.
Start with a one quart bleach bottle. Cut a hole in the top o f the bottle that is large enough for the mast tip, while leaving the bottle handle intact.
Fit this over the mast tip and tie a pair of tension lines to the handle. Tie the other end of each line to each side of the rear cross bar.
GARY
Santa Monica Bay
Re: Keeping the mast stable while trailering... [Re: warbird] #109839
06/21/07 06:16 PM
06/21/07 06:16 PM
arbo06 Offline
arbo06  Offline
here is a few shots
Re: Keeping the mast stable while trailering... [Re: arbo06] #109840
06/21/07 06:17 PM
06/21/07 06:17 PM
arbo06 Offline
arbo06  Offline
xxx
Re: Keeping the mast stable while trailering... [Re: arbo06] #109841
06/21/07 06:21 PM
06/21/07 06:21 PM
arbo06 Offline
arbo06  Offline
zzz
0 registered members (), 4,630 guests, and 1,261 spiders.
