| Stepping Mast with New, Shorter Shrouds #111943 07/17/07 04:25 PM 07/17/07 04:25 PM |
Joined: Nov 2006 Posts: 26 Mesa, Arizona RickInMesa OP
Posts: 26 Mesa, Arizona | I replaced my shrouds on my 1971 Hobie 16, and now I find it really difficult to set up my boat. I still have the shorter forestay, and I added a second chainplate to the bridle, which makes it possible to pin it together. The difficulty comes from the fact that the mast is raked back so far that it wants to fall when stepped.
Before I got my new shrouds, I found that if I parked my trailer facing downhill a little, the mast would lean far enough forward that most of the forces would be borne by the shrouds. I would tie the jib halyard to a rope, routing it through the bridle and then through my jib cam-cleat. When pulled snug, this would act as "insurance" that the mast wouldn't fall back, and I could climb down and pin the forestay. Now, however, the forces on that halyard/rope are so high that it makes me worried. Among other things, it puts a great deal of force on the jib traveler track, and I've already re-riveted that once!
I usually sail alone. Do those of you who sail alone have the same problem with the shorter shrouds and lots of mast rake? Do you worry about the mast toppling off?
Rick | | | Re: Stepping Mast with New, Shorter Shrouds
[Re: RickInMesa]
#111945 07/17/07 05:41 PM 07/17/07 05:41 PM |
Posts: 5,582 “an island in the Pacifi... | Set the shrouds in a higher hole in the chainplates. Once the mast is stepped reset them in the lower holes. Hang on to the trap handle while the pins are out. US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: Stepping Mast with New, Shorter Shrouds
[Re: mmiller]
#111947 07/18/07 03:27 PM 07/18/07 03:27 PM |
Posts: 26 Mesa, Arizona | Wade, before I changed the shrouds to the newer ones, I had to replace the mast base. It does fit into the mast step casting on the front crossbar fairly well; I use the "hinge" technique, and during the raising process the hinge keeps the base aimed right at the hole in the mast step... as long as I attach the hinge properly, that is. It's labeled "top", and if I get it backwards, the ball will NOT drop into the cup.
hobie1616, your advice is exactly on the mark; thanks. I felt very nervous about disconnecting the shrouds, even when holding a trap handle, because a breeze or a moment's inattention could cause the mast to fall. So the last time I sailed, I set the shrouds to the third or fourth hole in the chainplate... and forgot that I had done so. The inch or two on each side makes a big difference during setup.
Matt, thanks for the advice. I have a new forestay waiting to be installed. It looks like I'll need to drill out the block for the jib halyard, though, and attach the forestay with a clevis pin and a cotter pin. Right? The jib block sheave seems to be assembled with stainless rivets.
I know, I know... I should just go all the way to the "Aussie" jib system. Cost is a concern, though. I'd like to keep doing this in small increments, if I can.
Rick | | |
227
guests, and 38
