Rear Hull foam pads #115761
08/28/07 10:06 AM
08/28/07 10:06 AM
Chattanooga, TN
jody Offline OP
jody  Offline OP
Chattanooga, TN
I am trying to find the foam supports for the sterns that people are using on the beach when the cat is on cat traxs. Any one know who sells em?
thanks
Jody Blade F16 724 Plays with Sharp Objects
Re: Rear Hull foam pads [Re: jody] #115762
08/28/07 10:32 AM
08/28/07 10:32 AM
Coopersburg, PA
V
Vinny_M Offline
Vinny_M  Offline
V
Coopersburg, PA
I use pool noodles with a line through the middle to tie around the sterns. They have worked just fine for me and I only have to replace them about 2x a season.
~vinny~
Re: Rear Hull foam pads [Re: Vinny_M] #115763
08/28/07 10:54 AM
08/28/07 10:54 AM
SC
zander Offline
zander  Offline
SC
Jody,
I made my own by laminating a few sheets of closed cell foam together. Then I cut them to shape and glued outdoor carpet around them leaving a tab to put in grommets for bungie.
Always borrow money from a pessimist. He won't expect it back.
Re: Rear Hull foam pads [Re: jody] #115764
08/28/07 12:03 PM
08/28/07 12:03 PM
Houston
carlbohannon Offline
Houston
John Tomko of San Antonio was making them. He made a set for my Marstrom A.
Re: Rear Hull foam pads [Re: jody] #115765
08/28/07 12:11 PM
08/28/07 12:11 PM
Annapolis Md.
LuckyDuck Offline
LuckyDuck  Offline
Annapolis Md.
F-16 Falcon #212
Re: Rear Hull foam pads [Re: LuckyDuck] #115766
08/28/07 12:22 PM
08/28/07 12:22 PM
H
Hullflyer1 Offline
Hullflyer1  Offline
H
I use the spacers in the spare tire well of VW Jettas. It is used to take up the space between a full size tire and a donut. I had a friend who worked in a VW dealership. I use 4 of them and they have been under a Nacra 6.0 on the beach for over 5 years, and look like they will easily go for another 5.
Re: Rear Hull foam pads [Re: jody] #115767
08/28/07 12:31 PM
08/28/07 12:31 PM
Dan_Delave's recipe for the swim noodle version
foam cradles
Thanks again Dan
Re: Rear Hull foam pads [Re: _flatlander_] #115768
08/29/07 08:41 AM
08/29/07 08:41 AM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
[color:"blue"]Dan_Delave's recipe for the swim noodle version
foam cradles
Thanks again Dan [/color]
Glad you like them John. I thought I put a drawing with that post. I know I made a sketch of it. I will see when I get home and post it if I can find it.
Later,
Dan
Re: Rear Hull foam pads [Re: Dan_Delave] #115769
08/29/07 10:19 AM
08/29/07 10:19 AM
Lindale, Texas Inland freshwa...
Wallybear Offline
Wallybear  Offline
Dan, A drawing would be good. I was somewhat confused by the descrption. But then again, at times I am easily confused. <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />
Re: Rear Hull foam pads [Re: Wallybear] #115770
08/29/07 12:23 PM
08/29/07 12:23 PM
Petaluma, CA
David_Melcon Offline
Petaluma, CA
Left my rigid stern cradles on the beach last week and made these up last night. 8 octagonal noodles were a dollar each
at K-Mart end of season sale, 1/2" pvc was in the barn along
with old 1/8" clothes line. The 3x2 models are for my ancient A-Class and the 4x3 models for the Tornado. All I need now are the plastic hooks to put on some scrap shock cord. Elegant and cheap solution to the cradle problem.
David
Re: Rear Hull foam pads [Re: Wallybear] #115771
08/30/07 02:33 PM
08/30/07 02:33 PM
Dan_Delave Offline
Dan_Delave  Offline
Does this make sense?
Later,
Dan
Re: Rear Hull foam pads [Re: Dan_Delave] #115772
08/30/07 04:26 PM
08/30/07 04:26 PM
Wallybear Offline
Wallybear  Offline
DUH! Makes perfect sense now.
Thanks
Walter
0 registered members (), 21,789 guests, and 479 spiders.
Yesterday at 04:54 AM
