Drill and Fill #117589
09/18/07 10:38 PM
09/18/07 10:38 PM
Norman,OK
gree2056 Offline OP
gree2056  Offline OP
Norman,OK
I am in the process of rigging my 5.2 with a spin and am wanting to drill holes in the bows to attach bridles for the spin pole to.
I can handle the drilling but what should I fill the hole with. I can work fiberglass well but it always is so ugly, I saw some paste stuff that might work, would that be easier?
Anyone have advice?
Re: Drill and Fill [Re: gree2056] #117590
09/18/07 11:25 PM
09/18/07 11:25 PM
The bridles for the spin pole on my FX attach to where the bridles for the mast attach to the hull.
Re: Drill and Fill [Re: gree2056] #117591
09/18/07 11:30 PM
09/18/07 11:30 PM
west system with structural filler would be my suggestion. You could use some chopped glass as well but I think the structural filler would be fine. But then again, there are smarter than me engineering types around that could give you a little more info.
here is what I would do- drill the hole- not a very big one though. Put a piece of tape over one side. Inject west sytem with maybe a little structural filler into the hole to make sure it is all in contact with the surrounding glass/etc. You could then add more structural filler to the epoxy making it almost a paste and put it in there.
Re: Drill and Fill [Re: Karl_Brogger] #117592
09/18/07 11:31 PM
09/18/07 11:31 PM
Norman,OK
gree2056 Offline OP
gree2056  Offline OP
Norman,OK
I know on alot of boats that bridles attach near the bows plus ones at the same point the bridles for the forestay attach.
Re: Drill and Fill [Re: gree2056] #117593
09/19/07 08:01 AM
09/19/07 08:01 AM
Northern VA
bsquared Offline
bsquared  Offline
Northern VA
I did this on my H20. Drilled about a 1/2" hole on one side; whipped up some peanut butter-thick West with filler, and filled in the hole and as far around the hole as I could get it. After that dried, then I could drill a 3/16" hole through the middle of the fill, and through both sides of the bow. Ran hi-tech line through, with a washer and a knot on one side. When I wasn't using the chute, could easily pull the line leaving only the small (and waterproof) hole. Sand the big hole side flush and hit it with a touch of white spray paint and you'll never see it.
Re: Drill and Fill [Re: bsquared] #117594
09/19/07 09:00 AM
09/19/07 09:00 AM
Norman,OK
gree2056 Offline OP
gree2056  Offline OP
Norman,OK
So you used West System. I have never worked with it, I assume that West Marine would carry it?
0 registered members (), 16,971 guests, and 417 spiders.
Yesterday at 04:54 AM
